- #include <reg52.H>
- #include <intrins.h>
- sbit lcd_sclk=P1^0; /*接口定义:lcd_sclk就是D0*/
- sbit lcd_sid=P1^1; /*接口定义:lcd_sid就是D1*/
- sbit lcd_rs=P1^2; /*接口定义:lcd_rs就是DC*/
- sbit lcd_cs1=P1^3; /*接口定义:lcd_cs1就是OLED的片选CS1*/
- sbit Rom_OUT=P1^4; /*字库IC接口定义:Rom_OUT就是OUT*/
- sbit Rom_CS=P1^5; /*字库IC接口定义Rom_CS就是字库IC的CS2*/
- #define uchar unsigned char
- #define uint unsigned int
- #define ulong unsigned long
- uchar code bmp1[];
- uchar code jiong1[]={/*-- 文字: 囧 --*/
- /*-- 宋体12; 此字体下对应的点阵为:宽x高=16x16 --*/
- 0x00,0xFE,0x82,0x42,0xA2,0x9E,0x8A,0x82,0x86,0x8A,0xB2,0x62,0x02,0xFE,0x00,0x00,
- 0x00,0x7F,0x40,0x40,0x7F,0x40,0x40,0x40,0x40,0x40,0x7F,0x40,0x40,0x7F,0x00,0x00};
- uchar code lei1[]={/*-- 文字: 畾 --*/
- 0x80,0x80,0x80,0xBF,0xA5,0xA5,0xA5,0x3F,0xA5,0xA5,0xA5,0xBF,0x80,0x80,0x80,0x00,
- 0x7F,0x24,0x24,0x3F,0x24,0x24,0x7F,0x00,0x7F,0x24,0x24,0x3F,0x24,0x24,0x7F,0x00};
- /*写指令到LCD模块*/
- void transfer_command_lcd(int data1)
- char i;
- lcd_rs=0;
- lcd_sclk=0;
- for(i=0;i<8;i++)
- if(data1&0x80) lcd_sid=1;
- else lcd_sid=0;
- lcd_sclk=1;
- _nop_();
- lcd_sclk=0;
- data1<<=1;
- /*写数据到LCD模块*/
- void transfer_data_lcd(int data1)
- char i;
- lcd_rs=1;
- lcd_sclk=0;
- for(i=0;i<8;i++)
- else lcd_sid=0;
- lcd_sclk=1;
- _nop_();
- lcd_sclk=0;
- data1<<=1;
- /*延时*/
- void delay(int n_ms)
- int j,k;
- for(j=0;j<n_ms;j++)
- for(k=0;k<110;k++);
- /*等待一个按键,我的主板是用P2.0与GND之间接一个按键*/
- void waitkey()
- repeat:
- if (P2&0x01) goto repeat;
- else delay(6);
- else
- delay(40);;
- /*LCD模块初始化*/
- void initial_lcd()
- lcd_cs1=0;
- Rom_CS = 1;
- // lcd_reset=0; /*低电平复位*/
- delay(20);
- //lcd_reset=1; /*复位完毕*/
- delay(20);
- transfer_command_lcd(0xAE); //display off
- transfer_command_lcd(0x20); //Set Memory Addressing Mode
- transfer_command_lcd(0x10); //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
- transfer_command_lcd(0xb0); //Set Page Start Address for Page Addressing Mode,0-7
- transfer_command_lcd(0xc8); //Set COM Output Scan Direction
- transfer_command_lcd(0x02);//---set low column address
- transfer_command_lcd(0x10);//---set high column address
- transfer_command_lcd(0x40);//--set start line address
- transfer_command_lcd(0x81);//--set contrast control register
- transfer_command_lcd(0x7f);
- transfer_command_lcd(0xa1);//--set segment re-map 0 to 127
- transfer_command_lcd(0xa6);//--set normal display
- transfer_command_lcd(0xa8);//--set multiplex ratio(1 to 64)
- transfer_command_lcd(0x3F);//
- transfer_command_lcd(0xa4);//0xa4,Output follows RAM content;0xa5,Output ignores RAM content
- transfer_command_lcd(0xd3);//-set display offset
- transfer_command_lcd(0x00);//-not offset
- transfer_command_lcd(0xd5);//--set display clock divide ratio/oscillator frequency
- transfer_command_lcd(0xf0);//--set divide ratio
- transfer_command_lcd(0xd9);//--set pre-charge period
- transfer_command_lcd(0x22); //
- transfer_command_lcd(0xda);//--set com pins hardware configuration
- transfer_command_lcd(0x12);
- transfer_command_lcd(0xdb);//--set vcomh
- transfer_command_lcd(0x20);//0x20,0.77xVcc
- transfer_command_lcd(0x8d);//--set DC-DC enable
- transfer_command_lcd(0x14);//
- transfer_command_lcd(0xaf);//--turn on oled panel
- lcd_cs1=1;
- void lcd_address(uchar page,uchar column)
- transfer_command_lcd(0xb0 + column); /*设置页地址*/
- transfer_command_lcd((((page+2) & 0xf0) >> 4) | 0x10); /*设置列地址的高4位*/
- transfer_command_lcd(((page+2)& 0x0f) | 0x00); /*设置列地址的低4位*/
- /*全屏清屏*/
- void clear_screen()
- unsigned char i,j;
- lcd_cs1=0;
- Rom_CS = 1;
- for(i=0;i<8;i++)
- transfer_command_lcd(0xb0+i);
- for(j=0;j<132;j++)
- transfer_data_lcd(0x00);
- lcd_cs1=1;
- /*显示128x64点阵图像*/
- void display_128x64(uchar *dp)
- uint i,j;
- lcd_cs1=0;
- for(j=0;j<8;j++)
- lcd_address(0,j);
- for (i=0;i<128;i++)
- transfer_data_lcd(*dp); /*写数据到LCD,每写完一个8位的数据后列地址自动加1*/
- dp++;
- lcd_cs1=1;
- /*显示16x16点阵图像、汉字、生僻字或16x16点阵的其他图标*/
- void display_graphic_16x16(uint page,uint column,uchar *dp)
- uint i,j;
- lcd_cs1=0;
- Rom_CS = 1;
- for(j=2;j>0;j--)
- lcd_address(column,page);
- for (i=0;i<16;i++)
- dp++;
- page++;
- lcd_cs1=1;
- /*显示8x16点阵图像、ASCII, 或8x16点阵的自造字符、其他图标*/
- void display_graphic_8x16(uint page,uchar column,uchar *dp)
- uint i,j;
- lcd_cs1=0;
- for(j=2;j>0;j--)
- for (i=0;i<8;i++)
- dp++;
- page++;
- lcd_cs1=1;
- /*显示5*7点阵图像、ASCII, 或5x7点阵的自造字符、其他图标*/
- void display_graphic_5x7(uint page,uchar column,uchar *dp)
- uint col_cnt;
- uchar page_address;
- uchar column_address_L,column_address_H;
- page_address = 0xb0+page-1;
- lcd_cs1=0;
- column_address_L =(column&0x0f)-1;
- column_address_H =((column>>4)&0x0f)+0x10;
- transfer_command_lcd(page_address); /*Set Page Address*/
- transfer_command_lcd(column_address_H); /*Set MSB of column Address*/
- transfer_command_lcd(column_address_L); /*Set LSB of column Address*/
- for (col_cnt=0;col_cnt<6;col_cnt++)
- dp++;
- lcd_cs1=1;
- /****送指令到晶联讯字库IC***/
- void send_command_to_ROM( uchar datu )
- uchar i;
- for(i=0;i<8;i++ )
- if(datu&0x80)
- lcd_sid = 1;
- else
- lcd_sid = 0;
- datu = datu<<1;
- lcd_sclk=0;
- lcd_sclk=1;
- /****从晶联讯字库IC中取汉字或字符数据(1个字节)***/
- static uchar get_data_from_ROM( )
- uchar i;
- uchar ret_data=0;
- lcd_sclk=1;
- for(i=0;i<8;i++)
- Rom_OUT=1;
- lcd_sclk=0;
- ret_data=ret_data<<1;
- if( Rom_OUT )
- ret_data=ret_data+1;
- else
- ret_data=ret_data+0;
- lcd_sclk=1;
- return(ret_data);
- /*从相关地址(addrHigh:地址高字节,addrMid:地址中字节,addrLow:地址低字节)中连续读出DataLen个字节的数据到 pBuff的地址*/
- /*连续读取*/
- void get_n_bytes_data_from_ROM(uchar addrHigh,uchar addrMid,uchar addrLow,uchar *pBuff,uchar DataLen )
- uchar i;
- Rom_CS = 0;
- lcd_cs1=1;
- lcd_sclk=0;
- send_command_to_ROM(0x03);
- send_command_to_ROM(addrHigh);
- send_command_to_ROM(addrMid);
- send_command_to_ROM(addrLow);
- for(i = 0; i < DataLen; i++ )
- *(pBuff+i) =get_data_from_ROM();
- Rom_CS = 1;
- ulong fontaddr=0;
- void display_GB2312_string(uchar y,uchar x,uchar *text)
- uchar i= 0;
- uchar addrHigh,addrMid,addrLow ;
- uchar fontbuf[32];
- while((text[i]>0x00))
- if(((text[i]>=0xb0) &&(text[i]<=0xf7))&&(text[i+1]>=0xa1))
- /*国标简体(GB2312)汉字在晶联讯字库IC中的地址由以下公式来计算:*/
- /*Address = ((MSB - 0xB0) * 94 + (LSB - 0xA1)+ 846)*32+ BaseAdd;BaseAdd=0*/
- /*由于担心8位单片机有乘法溢出问题,所以分三部取地址*/
- fontaddr = (text[i]- 0xb0)*94;
- fontaddr += (text[i+1]-0xa1)+846;
- fontaddr = (ulong)(fontaddr*32);
- addrHigh = (fontaddr&0xff0000)>>16; /*地址的高8位,共24位*/
- addrMid = (fontaddr&0xff00)>>8; /*地址的中8位,共24位*/
- addrLow = fontaddr&0xff; /*地址的低8位,共24位*/
- get_n_bytes_data_from_ROM(addrHigh,addrMid,addrLow,fontbuf,32 );/*取32个字节的数据,存到"fontbuf[32]"*/
- display_graphic_16x16(y,x,fontbuf);/*显示汉字到LCD上,y为页地址,x为列地址,fontbuf[]为数据*/
- i+=2;
- x+=16;
- else if(((text[i]>=0xa1) &&(text[i]<=0xa3))&&(text[i+1]>=0xa1))
- /*国标简体(GB2312)15x16点的字符在晶联讯字库IC中的地址由以下公式来计算:*/
- /*Address = ((MSB - 0xa1) * 94 + (LSB - 0xA1))*32+ BaseAdd;BaseAdd=0*/
- fontaddr = (text[i]- 0xa1)*94;
- fontaddr += (text[i+1]-0xa1);
- i+=2;
- x+=16;
- else if((text[i]>=0x20) &&(text[i]<=0x7e))
- unsigned char fontbuf[16];
- fontaddr = (text[i]- 0x20);
- fontaddr = (unsigned long)(fontaddr*16);
- fontaddr = (unsigned long)(fontaddr+0x3cf80);
- get_n_bytes_data_from_ROM(addrHigh,addrMid,addrLow,fontbuf,16 );/*取16个字节的数据,存到"fontbuf[32]"*/
- display_graphic_8x16(y,x,fontbuf);/*显示8x16的ASCII字到LCD上,y为页地址,x为列地址,fontbuf[]为数据*/
- i+=1;
- x+=8;
- else
- i++;
- void display_string_5x7(uchar y,uchar x,uchar *text)
- unsigned char i= 0;
- unsigned char addrHigh,addrMid,addrLow ;
- if((text[i]>=0x20) &&(text[i]<=0x7e))
- unsigned char fontbuf[8];
- fontaddr = (unsigned long)(fontaddr*8);
- fontaddr = (unsigned long)(fontaddr+0x3bfc0);
- get_n_bytes_data_from_ROM(addrHigh,addrMid,addrLow,fontbuf,8);/*取8个字节的数据,存到"fontbuf[32]"*/
- display_graphic_5x7(y,x,fontbuf);/*显示5x7的ASCII字到LCD上,y为页地址,x为列地址,fontbuf[]为数据*/
- i+=1;
- x+=6;
- else
- i++;
- //===============main program===================
- void main(void)
- while(1)
- Rom_CS=1;
- lcd_cs1=0;
- initial_lcd();
- clear_screen(); //clear all dots
- display_128x64(bmp1);
- delay(10000);
- clear_screen();
- display_GB2312_string(0,1,"12864,带中文字库"); /*在第1页,第1列,显示一串16x16点阵汉字或8x16的ASCII字*/
- display_GB2312_string(2,1,"16X16简体汉字库,"); /*显示一串16x16点阵汉字或8x16的ASCII字.以下雷同*/
- display_GB2312_string(4,1,"或8X16点阵ASCII,");
- display_GB2312_string(6,1,"或5X7点阵ASCII码");
- delay(10000);
- clear_screen();
- display_GB2312_string(0,16,"中景园电子");
- display_GB2312_string(2,1,"主要生产OLED模块");
- display_GB2312_string(4,1,"顾客至上真诚服务");
- display_GB2312_string(6,1,"诚信与质量第一!");
- delay(10000);
- clear_screen();
- display_GB2312_string(0,1,"GB2312简体字库及");
- display_GB2312_string(2,1,"有图型功能,可自");
- display_GB2312_string(4,1,"编大字或图像或生");
- display_GB2312_string(6,1,"僻字,例如:");
- display_graphic_16x16(6,97,jiong1); /*在第7页,第81列显示单个自编生僻汉字“囧”*/
- display_graphic_16x16(6,113,lei1); /*显示单个自编生僻汉字"畾“*/
- delay(10000);
- clear_screen();
- display_GB2312_string(0,1,"<!@#$%^&*()_-+]/"); /*在第1页,第1列,显示一串16x16点阵汉字或8*16的ASCII字*/
- display_string_5x7(3,1,"<!@#$%^&*()_-+]/;.,?[");/*在第3页,第1列,显示一串5x7点阵的ASCII字*/
- display_string_5x7(4,1,"XY electronics Co., ");/*显示一串5x7点阵的ASCII字*/
- display_string_5x7(5,1,"Ltd. established at ");/*显示一串5x7点阵的ASCII字*/
- display_string_5x7(6,1,"year 2010.Focus OLED ");/*显示一串5x7点阵的ASCII字*/
- display_string_5x7(7,1,"Mobile:13265585975");/*显示一串5x7点阵的ASCII字*/
- display_string_5x7(8,1,"Tel:0755-32910715");/*显示一串5x7点阵的ASCII字*/
- delay(10000);
- display_GB2312_string(0,1,"啊阿埃挨哎唉哀皑"); /*在第1页,第1列,显示一串16x16点阵汉字或8x16的ASCII字*/
- display_GB2312_string(2,1,"癌蔼矮艾碍爱隘鞍"); /*显示一串16x16点阵汉字或8x16的ASCII字.以下雷同*/
- display_GB2312_string(4,1,"氨安俺按暗岸胺案");
- display_GB2312_string(6,1,"肮昂盎凹敖熬翱袄");
- delay(10000);
- display_GB2312_string(0,1,"鬟鬣麽麾縻麂麇麈");
- display_GB2312_string(2,1,"麋麒鏖麝麟黛黜黝");
- display_GB2312_string(4,1,"黠黟黢黩黧黥黪黯");
- display_GB2312_string(6,1,"鼢鼬鼯鼹鼷鼽鼾齄");
- delay(10000);
- uchar code bmp1[]={
- //-- 调入了一幅图像:D:\我的文档\My Pictures\12864-555.bmp --*/
- //-- 宽度x高度=128x64 --
- 0x00,0x06,0x0A,0xFE,0x0A,0xC6,0x00,0xE0,0x00,0xF0,0x00,0xF8,0x00,0x00,0x00,0x00,
- 0x00,0x00,0xFE,0x7D,0xBB,0xC7,0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,0xC7,0xBB,0x7D,
- 0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,
- 0x0C,0xFE,0xFE,0x0C,0x08,0x20,0x60,0xFE,0xFE,0x60,0x20,0x00,0x00,0x00,0x78,0x48,
- 0xFE,0x82,0xBA,0xBA,0x82,0xBA,0xBA,0x82,0xBA,0xBA,0x82,0xBA,0xBA,0x82,0xFE,0x00,
- 0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0xFF,
- 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0xFF,0xFF,0x00,0x00,0xFE,0xFF,0x03,
- 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0xFF,0xFE,0x00,0x00,0x00,0x00,0xC0,0xC0,
- 0xC0,0x00,0x00,0x00,0x00,0xFE,0xFF,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,
- 0xFF,0xFE,0x00,0x00,0xFE,0xFF,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0xFF,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0x0C,
- 0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0xFF,0xFF,0x00,0x00,0x00,0x00,0xE1,0xE1,
- 0xE1,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0xFF,0xFF,0x00,0x00,0xFF,0xFF,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0xFF,
- 0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x1F,
- 0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x1F,0x0F,0x00,0x00,0x0F,0x1F,0x18,
- 0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x1F,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x0F,0x1F,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,
- 0x1F,0x0F,0x00,0x00,0x0F,0x1F,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x1F,
- 0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0xE2,0x92,0x8A,0x86,0x00,0x00,0x7C,0x82,0x82,0x82,0x7C,
- 0x00,0xFE,0x00,0x82,0x92,0xAA,0xC6,0x00,0x00,0xC0,0xC0,0x00,0x7C,0x82,0x82,0x82,
- 0x7C,0x00,0x00,0x02,0x02,0x02,0xFE,0x00,0x00,0xC0,0xC0,0x00,0x7C,0x82,0x82,0x82,
- 0x7C,0x00,0x00,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x24,0xA4,0x2E,0x24,0xE4,0x24,0x2E,0xA4,0x24,0x00,0x00,0x00,0xF8,0x4A,0x4C,
- 0x48,0xF8,0x48,0x4C,0x4A,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x20,0x10,0x10,
- 0x10,0x10,0x20,0xC0,0x00,0x00,0xC0,0x20,0x10,0x10,0x10,0x10,0x20,0xC0,0x00,0x00,
- 0x00,0x12,0x0A,0x07,0x02,0x7F,0x02,0x07,0x0A,0x12,0x00,0x00,0x00,0x0B,0x0A,0x0A,
- 0x0A,0x7F,0x0A,0x0A,0x0A,0x0B,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x20,0x40,0x40,
- 0x40,0x50,0x20,0x5F,0x80,0x00,0x1F,0x20,0x40,0x40,0x40,0x50,0x20,0x5F,0x80,0x00,
