查看: 1857|回复: 0
宿舍超声波感应台灯 基于arduino、超声波模块,蓝牙模块,继电器模块
ID:426797 发表于 2020-10-26 19:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
const int Trigpin=2;
const int Echpin=3;
float cm;
char i;
void setup() {
  // put your setup code here, to run once:
  pinMode(Trigpin,OUTPUT);
  pinMode(Echpin,INPUT);
  pinMode(10,OUTPUT);
  pinMode(8,OUTPUT);
  pinMode(9,OUTPUT);
  digitalWrite(10,HIGH);
  digitalWrite(8,HIGH);
  digitalWrite(9,HIGH);
  Serial.begin(9600);
int cmm()
  digitalWrite(Trigpin, LOW);
  delayMicroseconds(2);
  digitalWrite(Trigpin, HIGH);
  delayMicroseconds(10);
  cm = pulseIn(Echpin, HIGH) / 58.8235; //
//cm = (int(cm * 100.0)) / 100.0; //
  return cm;
void openlight()
  digitalWrite(10,LOW);
  digitalWrite(8,LOW);
void closelight()
void loop() {
  // put your main code here, to run repeatedly:
  if(Serial.available())
  char i=Serial.read();
  while(i=='a')
    openlight();
      char j=Serial.read();
    if(j=='b') {
       break;}
  while(i=='b')
    closelight();
  {char j=Serial.read();
  if(j!='b') {
   break;}
  else{
  int a=cmm();
  if(a>0&&a<=110)
  {delay(500);
    int b =cmm();
  if(b>0&&b<=110){
    delay(15000); }
