查看: 2156|回复: 0
单片机DAC0808交流信号实时转换程序Proteus仿真,通过数码管显示
ID:582255 发表于 2021-1-29 14:47 | 显示全部楼层 |阅读模式
1.对输入的交流信号进行实时转换
2.通过LCD进行实时显示
3.proteus仿真
  1. //ICC-AVR application builder : 00-1-16 4:13:00
  2. // Target : 8535
  3. // Crystal: 4.0000Mhz
  4. #include <io8535v.h>
  5. #include <macros.h>
  6. #define uchar unsigned char
  7. #define uint unsigned int
  8. #include <adc.h>
  9. #include <led_dsp.h>
  10. #include <dac.h>
  11. void port_init(void)
  12. {
  13. PORTA = 0x00;
  14. DDRA  = 0x00;
  15. PORTB = 0xFF;
  16. DDRB  = 0xFF;
  17. PORTC = 0x00;
  18. DDRC  = 0xff;
  19. PORTD = 0xF0;
  20. DDRD  = 0x0F;
  21. }
  22. void main (void)
  23. {
  24. uchar i;
  25. //stop errant interrupts until set up
  26. CLI(); //disable all interrupts
  27. port_init();
  28. adc_init();
  29. dac_init ();
  30. MCUCR = 0x00;
  31. GIMSK = 0x00;
  32. SEI(); //re-enable interrupts
  33. //all peripherals are now initialised
  34. while (1)
  35. {
  36.         change_data(adc_val);
  37.          scan_led(disp_buffer);
  38. //         put_to_dac();
  39.         }
  40. }
adc.zip (76.19 KB, 下载次数: 30)
参与人数 1黑币 +30 收起 理由
admin + 30 共享资料的黑币奖励!
