实验成功能够显示字符,程序源码如下
- #include <stm32f10x.h>
- #include "stm_systick.h"
- #include "hem12864.h"
- #include "stm_gpio_init.h"
- #include "FONT.H"
- //#define HEM12864_RS PDout(10)
- //#define HEM12864_RST PDout(9)
- //#define HEM12864_CS PDout(8)
- //u8 charA[] ={0x08,0xF8,0x88,0x88,0x88,0x70,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x11,0x0E,0x00};/*"B",0*/
- //u8 chartemp[] = {0x10,0x60,0x02,0x8C,0x00,0x00,0xFE,0x92,0x92,0x92,0x92,0x92,0xFE,0x00,0x00,0x00,0x04,0x04,0x7E,0x01,0x40,0x7E,0x42,0x42,0x7E,0x42,0x7E,0x42,0x42,0x7E,0x40,0x00};/*"?",0*/
- void hem12864_gpio_init(void)
- RCC->APB2ENR |= 1 << 5;//开GPIOD时钟
- GPIOD->CRH &= 0xFFFF0000;
- GPIOD->CRH |= 0x00002222;//GPIOD0~11推挽输出
- GPIOD->ODR |= 0x7 << 8;
- GPIOD->ODR &= 0 << 11;
- RCC->APB2ENR |= 1 << 3;//开GPIOB时钟
- GPIOB->CRH &= 0x0F0FFFFF;
- GPIOB->CRH |= 0x20200000;//PB13/PB15推挽输出
- GPIOB->ODR |= 1 << 13;//PB13上拉
- GPIOB->ODR |= 1 << 15;//PB15上拉
- void HEM12864_SPI_Init(void)
- RCC->APB1ENR |= 1 << 14;//开SPI2时钟
- GPIOB->CRH |= 0xB0B00000;//PB13/PB15复用
- SPI2->CR1 |= 0 << 10;//全双工模式
- SPI2->CR1 |= 1 << 9;//软件NSS管理
- SPI2->CR1 |= 1 << 8;
- SPI2->CR1 |= 1 << 2;//SPI主机
- SPI2->CR1 |= 0 << 11;//8Bit数据格式
- SPI2->CR1 |= 1 << 1;//空闲模式下SCK为1 CPOL=1
- SPI2->CR1 |= 1 << 0 ;//数据采样从第二个时钟边沿开始,CPHA=1
- //对SPI2属于APB1的外设,时钟频率最大为36M。
- SPI2->CR1 |= 4 << 3; //FSCK = Fpclk1/32
- SPI2->CR1 |= 0 << 7;//MSB first
- SPI2->CR1 |= 1 << 6;//SPI设备使能
- u8 SPI2_ReadWriteByte(u8 TxData)
- u16 retry=0;
- while((SPI2->SR&1<<1)==0) //等待发送区空
- retry++;
- if(retry>=0XFFFE)return 0; //超时退出
- SPI2->DR=TxData; //发送一个Byte
- retry=0;
- void HEM12864_Init(void)
- HEM12864_RST = 0;
- Delay_us(40000);
- HEM12864_RST = 1;
- HEM12864_CS = 0;
- HEM12864_RS = 0;
- SPI2_ReadWriteByte(0x30);
- Delay_us(120);
- SPI2_ReadWriteByte(0X30);
- Delay_us(40);
- SPI2_ReadWriteByte(0X0F);
- Delay_us(120);
- SPI2_ReadWriteByte(0X01);
- Delay_us(10000);
- SPI2_ReadWriteByte(0X06);
- //=========================LCD??????======================
- #define LCDA0 PDout(10)
- #define LCDRS PDout(9)
- #define HEM12864_CS PDout(8)
- #define LCDSK PBout(13)
- #define LCDSI PBout(15)
- sbit LCDA0=P2^5; //????
- sbit LCDSK=P2^6; //????
- sbit LCDSI=P2^7; //????
- sbit LCDRS=P2^4; //????
- void LCDInit(); //?????
- void LCDWritecom(char com); //??????,????/????(0??,1??)
- void LCDShiftWrite(char dat); //???????
- void LCDSetXY(char x, char y); //??????
- //void LCDcls(char); //????,????????value
- extern unsigned char code hzcode[][128]; //
- extern unsigned char code gbcode[][32]; //
- extern unsigned char code asc816code[][16]; //
- extern unsigned char code asc1832code[][64]; //
- extern unsigned char code arrow[]; //
- void lcd12864_display_on(void) //显示开
- LCDWritecom(0xaf);
- void lcd12864_display_off(void)//显示关
- LCDWritecom(0xae);
- void lcd12864_display_normal(void) //正常显示
- LCDWritecom(0xa6);
- void lcd12864_display_reverse(void) //反白显示
- LCDWritecom(0xa7);
- void lcd12864_display_all_point_off(void) //全屏正常显示
- LCDWritecom(0xa4);
- void lcd12864_display_all_point_on(void) //全屏点亮
- LCDWritecom(0xa5);
- void lcd12864_rst(void)
- LCDRS=0; //LCD 复位有效(L)
- Delay_us(1000); // 延时1ms , Datasheet 要求至少大于1us
- LCDRS = 1; //LCD 复位无效(H)
- Delay_us(1000); //硬件复位
- LCDWritecom(0xe2); //寄存器复位
- Delay_us(1000);
- void LCDInit()
- HEM12864_CS = 0;
- Delay_us(1000);
- // 电源管理初始
- lcd12864_display_on(); //0xaf显示器开,0xae显示器关
- LCDWritecom(0x2f); ///0x2f升压电路,电压管理电路,
- //电压跟随电路均开(0x28-0x2f为设置上电控制模式)
- LCDWritecom(0x25); //0x20-0x27为V5电压内部电阻调整设置
- LCDWritecom(0x81); //电量设置模式
- LCDWritecom(0x0f); //0x01-0x3f电量寄存器设置模式
- // 根据屏的方向初始化安装方向(复位后默认下面配置)
- LCDWritecom(0xa0); //0xa0为Segment正向,0xa1 为Segment反向
- //(0xa0-0xa1为ADC方向选择)
- LCDWritecom(0xc8); //0xc0正向扫描,0xc8反射扫描
- // 显示管理初始(复位后默认下面配置)
- lcd12864_display_normal(); //0xa6正向显示,0xa7反向显示
- lcd12864_display_all_point_off(); //0xa4正常显示,0xa5全屏点亮
- // 指示器设置
- LCDWritecom(0xac); //
- LCDWritecom(0x00); //
- //背压比设置
- LCDWritecom(0xf8); //
- // LCDcls(0); //????????,????0
- // LCDCS = 0; //CS=0.?:??????CS,???????.
- LCDA0 = 0; //A0=0,????
- LCDShiftWrite(com);
- void LCDWritedata(char data)
- LCDA0 = 1; //A0=1,????
- LCDShiftWrite(data);
- // LCDCS = 1; //CS=1.?:??????CS,???????.
- unsigned char i; //??????
- unsigned char Series,Temp; //??????
- LCDSK = 0; //SCL=0
- Series = dat;
- for(i=0; i<8; i++)
- Temp=Series & 0x80; //???7?
- if(Temp) //??Temp=1,??SI=1.??Temp+0,??SI=0
- LCDSI = 1; //SI=1
- else
- LCDSI = 0; //SI=0
- LCDSK = 1; //SCL=1????
- Series = Series << 1; //??1?
- void LCD12864_Pos(u8 x,u8 y)
- u8 pos;
- if (x==1) {x=0x80;}
- else if (x==2) {x=0x90;}
- else if (x==3) {x=0x88;}
- else if (x==4) {x=0x98;}
- else x=0x80;
ST7567.zip
(3.6 KB, 下载次数: 4)
