#include<reg52.h>
#include "main.h"
void delay(uint z)//延时函数
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void di() //蜂鸣器报警声音
beep=0;
delay(500);
beep=1;
void write_com(uchar com)
{//写液晶命令函数
rs=0;
rd=0;
lcden=0;
P0=com;
delay(3);
lcden=1;
delay(3);
lcden=0;
void write_date(uchar date)
{//写液晶数据函数
rs=1;
rd=0;
lcden=0;
P0=date;
delay(3);
lcden=1;
delay(3);
lcden=0;
void init()
{//初始化函数
uchar num;
EA=1;//打开总中断
EX1=1;//开外部中断1
IT1=1;//设置负跳变沿触发中断
flag1=0;//变量初始化
t0_num=0;
s1num=0;
week=1;
// dula=0;
LSA=0;
LSB=0;
LSC=0;//关闭数码管显示
// wela=0;
lcden=0;
rd=0;
/*以下几行在首次设置DS12C887时使用,以后不必再写入*/
write_ds(0x0A,0x20);//打开振荡器
write_ds(0x0B,0x26);//设置24小时模式,数据二进制格式
//开启闹铃中断
set_time();//设置上电默认时间
write_com(0x38);//1602液晶初始化
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
for(num=0;num<15;num++)//写入液晶固定部分显示
write_date(table[num]);
delay(1);
write_com(0x80+0x40);
for(num=0;num<11;num++)
write_date(table1[num]);
delay(1);
void write_sfm(uchar add,char date)
{//1602液晶刷新时分秒函数4为时,7为分,10为秒
char shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+0x40+add);
write_date(0x30+shi);
write_date(0x30+ge);
void write_nyr(uchar add,char date)
{//1602液晶刷新年月日函数3为年,6为分,9为秒
char shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+add);
void write_week(char we)
{//写液晶星期显示函数
write_com(0x80+12);
switch(we)
case 1: write_date('M');delay(5);
write_date('O');delay(5);
write_date('N');
break;
case 2: write_date('T');delay(5);
write_date('U');delay(5);
write_date('E');
break;
case 3: write_date('W');delay(5);
write_date('E');delay(5);
write_date('D');
break;
case 4: write_date('T');delay(5);
write_date('H');delay(5);
write_date('U');
break;
case 5: write_date('F');delay(5);
write_date('R');delay(5);
write_date('I');
break;
case 6: write_date('S');delay(5);
write_date('A');delay(5);
write_date('T');
break;
case 7: write_date('S');delay(5);
write_date('N');
break;
void keyscan()
if(flag_ri==1)
{//这里用来取消闹钟报警,任一键取消报警
if((s1==0)||(s2==0)||(s3==0)||(s4==0))
delay(5);
while(!(s1&&s2&&s3&&s4));
di();
flag_ri=0;//清除报警标志
if(s1==0)//检测S1
delay(5);
if(s1==0)
s1num++;//记录按下次数
if(flag1==1)
if(s1num==4)
s1num=1;
flag=1;
while(!s1);
di();
switch(s1num)
{//光标闪烁点定位
case 1: write_com(0x80+0x40+10);
write_com(0x0f);
break;
case 2: write_com(0x80+0x40+7);
break;
case 3: write_com(0x80+0x40+4);
break;
case 4: write_com(0x80+12);
break;
case 5: write_com(0x80+9);
break;
case 6: write_com(0x80+6);
break;
case 7: write_com(0x80+3);
break;
case 8: s1num=0;
write_com(0x0c);
flag=0;
write_ds(0,miao);
write_ds(2,fen);
write_ds(4,shi);
write_ds(6,week);
write_ds(7,day);
write_ds(8,month);
write_ds(9,year);
break;
if(s1num!=0)//只有当S1按下后,才检测S2和S3
if(s2==0)
delay(1);
if(s2==0)
while(!s2);
di();
switch(s1num)
{//根据功能键次数调节相应数值
case 1: miao++;
if(miao==60)
miao=0;
write_sfm(10,miao);
break;
case 2: fen++;
if(fen==60)
fen=0;
write_sfm(7,fen);
break;
case 3: shi++;
if(shi==24)
shi=0;
write_sfm(4,shi);
break;
case 4: week++;
if(week==8)
week=1;
write_week(week);
write_com(0x80+12);
break;
case 5: day++;
if(day==32)
day=1;
write_nyr(9,day);
write_com(0x80+9);
break;
case 6: month++;
if(month==13)
month=1;
write_nyr(6,month);
write_com(0x80+6);
break;
case 7: year++;
if(year==100)
year=0;
write_nyr(3,year);
write_com(0x80+3);
break;
if(s3==0)
delay(1);
if(s3==0)
while(!s3);
di();
switch(s1num)
{//根据功能键次数调节相应数值
case 1: miao--;
if(miao==-1)
miao=59;
write_sfm(10,miao);
break;
case 2: fen--;
if(fen==-1)
fen=59;
write_sfm(7,fen);
break;
case 3: shi--;
if(shi==-1)
shi=23;
write_sfm(4,shi);
break;
case 4: week--;
if(week==0)
week=7;
write_week(week);
write_com(0x80+12);
break;
case 5: day--;
if(day==0)
day=31;
write_nyr(9,day);
write_com(0x80+9);
break;
case 6: month--;
if(month==0)
month=12;
write_nyr(6,month);
write_com(0x80+6);
break;
case 7: year--;
if(year==-1)
year=99;
write_nyr(3,year);
write_com(0x80+3);
break;
if(s4==0)//检测S4
delay(5);
if(s4==0)
flag1=~flag1;
while(!s4);di();
if(flag1==0)
{//退出闹钟设置时保存数值
flag=0;
write_date(' ');
write_date(' ');
write_com(0x0c);
write_ds(1,miao);
write_ds(3,fen);
write_ds(5,shi);
{//进入闹钟设置
read_alarm();//读取原始数据
miao=amiao;//重新赋值用以按键调节
fen=afen;
shi=ashi;
write_date('R');//显示标志
write_date('i');
write_com(0x80+0x40+3);
write_sfm(4,ashi);//送液晶显示闹钟时间
write_sfm(7,afen);
write_sfm(10,amiao);
void write_ds(uchar add,uchar date)
{//写12C887函数
dscs=0;
dsas=1;
dsds=1;
dsrw=1;
P0=add;//先写地址
dsas=0;
dsrw=0;
P0=date;//再写数据
dsrw=1;
dsas=1;
dscs=1;
uchar read_ds(uchar add)
{//读12C887函数
uchar ds_date;
dsas=1;
dsds=1;
dsrw=1;
dscs=0;
P0=add;//先写地址
dsas=0;
dsds=0;
P0=0xff;
ds_date=P0;//再读数据
dsds=1;
dsas=1;
dscs=1;
return ds_date;
/*---首次操作12C887时给予寄存器初始化---*/
void set_time()
{//首次上电初始化时间函数
// write_ds(4, 0);
// write_ds(2, 0);
write_ds(0,0);
write_ds(1,0);
write_ds(2,0);
write_ds(3,0);
write_ds(4,0);
write_ds(5,0);
write_ds(6,0);
write_ds(7,0);
write_ds(8,0);
write_ds(9,0);
void read_alarm()
{//读取12C887闹钟值
amiao=read_ds(1);
afen=read_ds(3);
ashi=read_ds(5);
void main()//主函数
init();//调用初始化函数
keyscan();//按键扫描
if(flag_ri==1)//当闹钟中断时进入这里
di();
delay(100);
di();
delay(500);
if(flag==0&&flag1==0)//正常工作时进入这里
keyscan();//按键扫描
year=read_ds(9);//读取12C887数据
month=read_ds(8);
day=read_ds(7);
week=read_ds(6);
shi=read_ds(4);
fen=read_ds(2);
miao=read_ds(0);
write_sfm(10,miao);//送液晶显示
write_sfm(7,fen);
write_sfm(4,shi);
write_week(week);
write_nyr(3,year);
write_nyr(6,month);
write_nyr(9,day);
void exter() interrupt 2//外部中断1服务程序
{ uchar c; //进入中断表示闹钟时间到,
flag_ri=1; //设置标志位,用以大程序中报警提示
c=read_ds(0x0c);//读取12C887的C寄存器表示响应了中断
以上代码下载:
定时器时钟闹钟1602显示.7z
(29.77 KB, 下载次数: 12)
