做了一个测方波用的频率计最高频率实测可以超过20MHZ,
因为是实在没有频率够高的信号啦
内置4个档位,做2、8、16、256分频
自动找档功能,LCD1602显示,有开机loading显示。
在高频段误差小于千分之一,
低频段误差较大,例如49HZ,测得48或者50HZ
是因为做了2分频,可略作修改,或多做一档不进行分频。
两块数字芯片都是非常基础的,分别是74LS161(16进制计数器)和CD4051(单刀八掷数字开关)
- #include "reg51.h"
- #include "stdio.h"
- #include "string.h"
- //sprintf(strHex, "%0x", num); 十进制
- //sprintf(strHex, "%d", num); 十六进制
- #include "1602.h"
- #include "type.h"
- #define uint unsigned int
- #define uchar unsigned char
- sbit LSA=P1^3;
- sbit LSB=P1^4;
- sbit LSC=P1^5;
- void Timer_Init();
- void delayms(uint yanshi);
- uint number_date=0;
- float fre_date=0;
- uchar str[16];
- uchar str2[16];
- uchar str3[16];
- uint flag_4051=3;
- uchar count=0;
- uchar t=1;
- void main()
- lcd1602init();
- Timer_Init();
- display_string(1,"START FRE Meter!");
- delayms(200);
- display_string(2,"Loading......");
- delayms(1000);
- display_string(1," ");
- display_string(2," ");
- // LSA=0;LSB=1;LSC=0;
- while(1)
- switch(flag_4051)
- case 1:
- LSA=LSB=LSC=0;
- delayms(1000);
- fre_date=number_date;
- fre_date=fre_date*2;
- if(fre_date>60000)
- flag_4051=2;
- P2=0x00;
- if(number_date<5000)
- sprintf(str2,"%0.1f",fre_date);
- strcat(str2,"HZ ");
- else
- sprintf(str2,"%0.3f",fre_date/1000);
- strcat(str2,"KHZ");
- strcpy(str,"START MODE ONE!!");
- break;
- case 2: LSA=0;LSB=1;LSC=0;
- delayms(1000);
- fre_date=fre_date*8;
- if(fre_date<60000) flag_4051=1;
- if(fre_date>200000) flag_4051=3;
- strcat(str2,"KHZ ");
- strcpy(str,"START MODE TWO!!");
- break;
- case 3: LSA=1;LSB=1;LSC=0;
- delayms(1000);
- fre_date=fre_date*16;
- if(fre_date<200000) flag_4051=2;
- if(fre_date>750000) flag_4051=4;
- strcpy(str,"START MODE THREE");
- break;
- case 4: LSA=1;LSB=1;LSC=1;
- delayms(1000);
- fre_date=fre_date*256;
- if(fre_date<750000) flag_4051=3;
- sprintf(str2,"%0.3f",fre_date/1000000);
- strcat(str2,"MHZ ");
- strcpy(str,"START MODE FOUR!");
- break;
- display_string(1, str);
- strcpy(str3,"Fre=");
- strcat(str3,str2);
- display_string(2, str3);
- void Timer_Init()
- TMOD=0X15;
- TR0=1;
- TR1=1;
- EA = 1;
- ET1 = 1; //允许T1定时中断
- ET0 = 1; //允许T0计数中断
- void Timer1() interrupt 3 //测量时间
- uchar i;
- TL1=0XF0;
- TH1=0XD8; //给定时器赋初值,定时10ms
- i++;
- if(i>99)
- number_date=(TH0*256+TL0);//+t*65535;
- TL0=0;
- TH0=0;
- t=0;
- i=0;
- void Timer0() interrupt 1
- t++;
- TL0=0;
- TH0=0;
- uint i,j;
- for(i=yanshi;i>0;i--)
- for(j=125;j>0;j--);
提供一种频率计的设计思路,电路和程序的优化空间很大,大家可以自行发挥,仅供参考,切勿照搬
全部资料51hei下载地址:
20M Frequency meter.zip
(106.4 KB, 下载次数: 67)
