#include<reg51.h>
sbit s1 = P1^0;
sbit s2 = P1^1;
sbit s3 = P3^0;
sbit s4 = P3^1;
sbit s5 = P3^2;//????,s1??,s2??,s3?1,s4?1
sbit a = P2^7;sbit b = P2^6;sbit c = P2^5;sbit d = P2^4;//?????????
uchar code time_counter[10][2]={{0xda,0x1c},{0xde,0xe4},{0xe1,0xec},{0xe5,0xd4},{0xe9,0xbc}, //9.7 ----1ms
{0xed,0xa4},{0xf1,0x8c},{0xf5,0x74},{0xf9,0x5c},{0xfc,0x18}};
uchar num1 = 0;//?????????
uchar num2 = 8;
char k=0;//??????,1????
char pause=1;//??????????,????1
bit flag1 = 0;//????,?????
//================================???0/1?????================================
void T0_T1_init()
TMOD = 0x11;//???0/1??????1,16?????
TH1 = time_counter[k-1][0];
TL1 = time_counter[k-1][1];//???1,??10ms??????????
TR1 = 0;
ET1= 1;//??????
EA = 1;//????
//================================ms?????=======================================
void delay1m(uint x)
uint i,j;
for(i=0;i<x;i++) //??x?,? x ms
for(j=0;j<120;j++); //?120 ?,?1 ms
T0_T1_init();
a=b=c=d=0;
if(s1 == 0)
delay1m(3);
if(s1 == 0)
flag1 = 0;//??
while(!s1);
if(s2 == 0 )
delay1m(3);
if(s2 == 0)
flag1 = 1;//??
while(!s2);
if(s3 == 0) //???1?
delay1m(3);
if(s3 == 0)
k++;
TR1=1;
if(k > 10 )
k = 1;
while(!s3);
if(s4 == 0) //???1?
delay1m(3);
if(s4 == 0)
k--;
TR1=1;
if(k <= 0)
k = 10;
while(!s4);
if(s5==0)
delay1m(3);
if(s5==0)
if(TR1==1)
pause=k;
k=0;
TR1=0;
a=b=c=d=0;
else if(TR1==0)
k=pause;
TR1=1;
while(!s5);
//==================================???1????,????????=====================================
void time1_interrupt()interrupt 3
static num1 = 0;
static num2 = 0;
TL1 = time_counter[k-1][1];//???1,??1 ??????????
if(flag1 == 0)//??
switch(num1)
case 0:a = 1;b = 0;c = 0;d = 0;break;
case 1:a = 1;b = 1;c = 0;d = 0;break;
case 2:a = 0;b = 1;c = 0;d = 0;break;
case 3:a = 0;b = 1;c = 1;d = 0;break;
case 4:a = 0;b = 0;c = 1;d = 0;break;
case 5:a = 0;b = 0;c = 1;d = 1;break;
case 6:a = 0;b = 0;c = 0;d = 1;break;
case 7:a = 1;b = 0;c = 0;d = 1;break;
num1++;
if(num1 == 8)num1 = 0;
else //??
switch(num2)
case 0:a = 1;b = 0;c = 0;d = 1;break;
case 1:a = 0;b = 0;c = 0;d = 1;break;
case 2:a = 0;b = 0;c = 1;d = 1;break;
case 3:a = 0;b = 0;c = 1;d = 0;break;
case 4:a = 0;b = 1;c = 1;d = 0;break;
case 5:a = 0;b = 1;c = 0;d = 0;break;
case 6:a = 1;b = 1;c = 0;d = 0;break;
case 7:a = 1;b = 0;c = 0;d = 0;break;
num2++;
if(num2 == 8)num2 = 0;
