前段时间调试DM648,有一些笔记,跟大家分享一下。虽然用到DM648的朋友会很少,但正因为64+的资料不容易找,所以才把相关笔记整理发出来,希望能对做64+的朋友提供一些方便。 下面的函数描述了EDMA配置到启动的过程(完全寄存器级的操作,更有利于理解EDMA3.0的操作过程)。 EDMA_init() { /* Step 1: EDMA寄存器初始化 */ QUEPRI=0x10; //queue优先级设置,0、2、3为0级,1为1级 QWMTHRA =(16<<8u)|(16 & 0xFF); //queue超长报错设置,0、1均为16,2、3为0 EMCR = 0xFFFFFFFF; //清除所有EDMA事件丢失标志 CCERRCLR = 0xFFFFFFFF; //清除所有EDMA3CC错误 //以VP2亮度事件触发为例 /* Step 2: Programming DMA Channel (and Param set) */ DCHMAP32=0x80<<5; //对应EVENT32与第128项PARAM DMAQNUM4=0x0; //将EVENT32项对应到QUEUE0通道 //设置第128项PARAM值,重载表设为129项 OPT128 = 0x00105301; // TCINTEN is set,A sync,TCC=5,64bit FIFO SRC128 = YSRCA2; A_B_CNT128 = ((frameCount << 16u) | (elementCount & 0xFFFFu)); // ACNT = 1536, BCNT = 2 DST128 = (unsigned int )line_buffer2; SRC_DST_BIDX128 = (elementCount << 16u) | (0u); // SRC_BIDX = 0, DST_BIDX = 1536 //一次完整的EDMA搬移完成后,用第129项PARAM表装载到第128项表 LINK_BCNTRLD128 = (frameCount << 16u) | 0x1020u; // LINK = 129, BCNTRLD = 1 SRC_DST_CIDX128 = (elementCount << 16u) | (0u); CCNT128 = 1; //第129项PARAM表为备份表,用于重载到第128项PARAM表 OPT129 = 0x00105301; // TCINTEN is set,A sync,TCC=5,64bit FIFO SRC129 = YSRCA2; A_B_CNT129 = ((frameCount << 16u) | (elementCount & 0xFFFFu)); // ACNT = 1536, BCNT = 2 DST129 = (unsigned int )line_buffer2; SRC_DST_BIDX129 = (elementCount << 16u) | (0u); // SRC_BIDX = 0, DST_BIDX = 1536 //将129项PARAM表装载到第128项表,仍然指向第129项PARAM表 LINK_BCNTRLD129 = (frameCount << 16u) | 0x1020u; // LINK = 129, BCNTRLD = 1 SRC_DST_CIDX129 = (elementCount << 16u) | (0u); CCNT129 = 1; /* Step 3: Triggering the Transfer and Waiting for Transfer Completion */ EESRH = 0x1; //enable event VP2EVTYA channel , number 32 // ESRH = 0x1;//调试时可用于手动触发EDMA事件,观察EDMA模块工作情况 }
