分享一个51单片机做的SD卡读卡器仿真带源程序,一个简单的MMC卡存储器应用。下面是电路原理图:
可以看到虚拟窗口的结果出来了.
单片机SD卡读卡器设计的源程序如下:
- #include <AT89X52.H>
- #define F_OSC 11059200//晶振平率Hz
- #define F_BAUD 9600
- #define RELOAD 256-F_OSC/12/32/F_BAUD
- #define CR 0x0D //回车
- //定义SD卡需要的4根信号线
- sbit SD_CLK = P1^4;
- sbit SD_DI = P1^6;
- sbit SD_DO = P1^5;
- sbit SD_CS = P1^7;
- unsigned char xdata DATA[512];
- //定义512字节缓冲区,注意需要使用 xdata关键字
- //写一字节到SD卡,模拟SPI总线方式
- void SdWrite(unsigned char n)
- unsigned char i;
- for(i=8;i;i--)
- SD_CLK=0;
- SD_DI=(n&0x80);
- n<<=1;
- SD_CLK=1;
- SD_DI=1;
- //从SD卡读一字节,模拟SPI总线方式
- unsigned char SdRead()
- unsigned char n,i;
- for(i=8;i;i--)
- SD_CLK=0;
- SD_CLK=1;
- n<<=1;
- if(SD_DO) n|=1;
- return n;
- //检测SD卡的响应
- unsigned char SdResponse()
- unsigned char i=0,response;
- while(i<=8)
- response = SdRead();
- if(response==0x00)
- break;
- if(response==0x01)
- break;
- i++;
- return response;
- //发命令到SD卡
- void SdCommand(unsigned char command, unsigned long argument, unsigned char CRC)
- SdWrite(command|0x40);
- SdWrite(((unsigned char *)&argument)[0]);
- SdWrite(((unsigned char *)&argument)[1]);
- SdWrite(((unsigned char *)&argument)[2]);
- SdWrite(((unsigned char *)&argument)[3]);
- SdWrite(CRC);
- //初始化SD卡
- unsigned char SdInit(void)
- int delay=0, trials=0;
- unsigned char i;
- unsigned char response=0x01;
- SD_CS=1;
- for(i=0;i<=9;i++)
- SdWrite(0xff);
- SD_CS=0;
- //Send Command 0 to put MMC in SPI mode
- SdCommand(0x00,0,0x95);
- response=SdResponse();
- if(response!=0x01)
- return 0;
- while(response==0x01)
- SD_CS=1;
- SdWrite(0xff);
- SD_CS=0;
- SdCommand(0x01,0x00ffc000,0xff);
- SD_CS=1;
- SdWrite(0xff);
- return 1;
- //往SD卡指定地址写数据,一次最多512字节
- unsigned char SdWriteBlock(unsigned char *Block, unsigned long address,int len)
- unsigned int count;
- unsigned char dataResp;
- //Block size is 512 bytes exactly
- //First Lower SS
- SD_CS=0;
- //Then send write command
- SdCommand(0x18,address,0xff);
- if(SdResponse()==00)
- SdWrite(0xff);
- SdWrite(0xff);
- SdWrite(0xff);
- //command was a success - now send data
- //start with DATA TOKEN = 0xFE
- SdWrite(0xfe);
- //now send data
- for(count=0;count<len;count++) SdWrite(*Block++);
- for(;count<512;count++) SdWrite(0);
- //data block sent - now send checksum
- SdWrite(0xff); //两字节CRC校验, 为0XFFFF 表示不考虑CRC
- SdWrite(0xff);
- //Now read in the DATA RESPONSE token
- dataResp=SdRead();
- //Following the DATA RESPONSE token
- //are a number of BUSY bytes
- //a zero byte indicates the MMC is busy
- while(SdRead()==0);
- dataResp=dataResp&0x0f; //mask the high byte of the DATA RESPONSE token
- SD_CS=1;
- SdWrite(0xff);
- if(dataResp==0x0b)
- //printf("DATA WAS NOT ACCEPTED BY CARD -- CRC ERROR\n");
- return 0;
- if(dataResp==0x05)
- return 1;
- //printf("Invalid data Response token.\n");
- return 0;
- //printf("Command 0x18 (Write) was not received by the MMC.\n");
- return 0;
- //从SD卡指定地址读取数据,一次最多512字节
- unsigned char SdReadBlock(unsigned char *Block, unsigned long address,int len)
- //First Lower SS
- //printf("MMC_read_block\n");
- SD_CS=0;
- SdCommand(0x11,address,0xff);
- while(SdRead()!=0xfe);
- for(count=0;count<len;count++) *Block++=SdRead();
- for(;count<512;count++) SdRead();
- SdRead();
- SdRead();
- SD_CS=1;
- SdRead();
- return 1;
- //printf("Command 0x11 (Read) was not received by the MMC.\n");
- return 0;
- 串口初始化
- void UART()
- SCON=0x40;//工作与方式1不允许接受
- TMOD=0x20;//定时器1工作与方式2自动重装模式
- TH1=RELOAD;
- TR1=1;
- TI=0;
- //通过串口发送一个字符串
- void Sen_String(unsigned char *string)
- while(*string!='\0')
- if(*string=='\n')
- SBUF=CR;
- else
- SBUF=*string;
- while(TI==0);
- TI=0;
- string++;
- void main()
- UART();
- while(!SdInit()); //等待SD卡初始化完成
- SdWriteBlock("THIS IS A TEST!",0x000000,15);//写入字符串,然后读出进行检验
- SdReadBlock(DATA,0x000000,15);
- Sen_String(DATA); //发出数据
- while(1)
单片机SD卡读卡器仿真工程文件及其他完整资料下载:
http://www.51hei.com/bbs/dpj-54940-1.html
