51单片机驱动4×4键盘按键显示对应键值程序
仿真原理图如下(proteus仿真工程文件可到本帖附件中下载):
- 伪定义
- KEYBUF EQU 30H ;键值暂存单元,查表时用
- ;* 主程序和中断程序入口 *
- ORG 0000H ;程序执行开始地址
- AJMP MAIN ;跳至MAIN执行
- ;* 主 程 序 *
- ORG 0040H
- MAIN: MOV P1,#0FFH
- CLR P2.0
- LCALL KEYSCAN ;主体程序。调用查键子程序
- LJMP MAIN ;转MAIN循环
- NOP ;软件陷阱
- NOP
- NOP
- LJMP MAIN
- ;* 键盘工作子程序(4 * 4 阵列) *
- ;* 出口为各键工作程序入口 P1口 *
- KEYSCAN:
- MOV P1,#0FFH;清P1口,初始化键低电平有效
- CLR P1.4;清P1.4口
- MOV A,P1;读P1口状态
- ANL A,#0FH;清高4位,保留低四位低电平有效
- XRL A,#0FH;异或相同则为0不同结果为1,为0则表示无键被按下(这一行)
- JZ NOKEY1;为0则转下一行键值处理
- LCALL DL10MS;有键按下则延时10ms再测一次抗干扰
- MOV A,P1
- ANL A,#0FH
- XRL A,#0FH
- JZ NOKEY1;是干扰则转下一行键值处理程序
- MOV A,P1
- ANL A,#0FH;保留低四?
- KB1:
- CJNE A,#0EH,KB2;如果值为#0E则为P1.4与P1.0组合的键
- MOV KEYBUF,#0;赋键值
- LJMP KEYWORK;转键处理
- KB2: CJNE A,#0DH,KB3;如果值为#0D则为P1.4与P1.1组合的键
- MOV KEYBUF,#1
- LJMP KEYWORK
- KB3: CJNE A,#0BH,KB4;如果值为#0B则为P1.4与P1.2组合的
- MOV KEYBUF,#2
- LJMP KEYWORK
- KB4: CJNE A,#07H,KB5;如果值为#07则为P1.4与P1.3组合的
- MOV KEYBUF,#3
- LJMP KEYWORK
- KB5: NOP
- NOKEY1:
- MOV P1,#0FFH
- CLR P1.5
- MOV A,P1
- ANL A,#0FH
- XRL A,#0FH
- JZ NOKEY2
- LCALL DL10MS
- MOV A,P1
- ANL A,#0FH
- XRL A,#0FH
- JZ NOKEY2
- MOV A,P1
- ANL A,#0FH
- CJNE A,#0EH,KB6
- MOV KEYBUF,#4
- LJMP KEYWORK
- KB6: CJNE A,#0DH,KB7
- MOV KEYBUF,#5
- LJMP KEYWORK
- KB7: CJNE A,#0BH,KB8
- MOV KEYBUF,#6
- LJMP KEYWORK
- KB8: CJNE A,#07H,KB9
- MOV KEYBUF,#7
- LJMP KEYWORK
- KB9: NOP
- NOKEY2:
- MOV P1,#0FFH
- CLR P1.6
- MOV A,P1
- ANL A,#0FH
- XRL A,#0FH
- JZ NOKEY3
- LCALL DL10MS
- MOV A,P1
- ANL A,#0FH
- XRL A,#0FH
- JZ NOKEY3
- MOV A,P1
- ANL A,#0FH
- CJNE A,#0EH,KB10
- MOV KEYBUF,#8
- LJMP KEYWORK
- KB10: CJNE A,#0DH,KB11
- MOV KEYBUF,#9
- LJMP KEYWORK
- KB11: CJNE A,#0BH,KB12
- MOV KEYBUF,#10
- LJMP KEYWORK
- KB12: CJNE A,#07H,KB13
- MOV KEYBUF,#11
- LJMP KEYWORK
- KB13: NOP
- NOKEY3:
- MOV P1,#0FFH
- CLR P1.7
- MOV A,P1
- ANL A,#0FH
- XRL A,#0FH
- JZ NOKEY4
- LCALL DL10MS
- MOV A,P1
- ANL A,#0FH
- XRL A,#0FH
- JZ NOKEY4
- MOV A,P1
- ANL A,#0FH
- CJNE A,#0EH,KB14
- MOV KEYBUF,#12
- LJMP KEYWORK
- KB14: CJNE A,#0DH,KB15
- MOV KEYBUF,#13
- LJMP KEYWORK
- KB15: CJNE A,#0BH,KB16
- MOV KEYBUF,#14
- LJMP KEYWORK
- KB16: CJNE A,#07H,KB17
- MOV KEYBUF,#15
- LJMP KEYWORK
- KB17: NOP
- NOKEY4:
- LJMP MAIN
- KEYWORK:
- MOV A,KEYBUF;得到键值
- MOV DPTR,#TABLE
- MOVC A,@A+DPTR;查行键值送ACC
- MOV P0,A;
- WAITFREE:
- MOV A,P1;以下程序等待键释放
- MOV KEYBUF,#00H
- ANL A,#0FH
- XRL A,#0FH
- JNZ WAITFREE
- RET
- ;* 延时513 us *
- ;513微秒延时程序
- DELAY: MOV R2,#0FEH
- DELAY1: DJNZ R2,DELAY1
- RET
4X4键盘显示.zip
(30.35 KB, 下载次数: 26)
