代码:
#include "reg51.h"
uchar code table_numberP[] = {0xfe,0xfd,0xfa,0xf7,0xef,0xdf,0xaf,0x7f};
uchar code table[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay_ms(int);
void init_P();
int num;
for (num=2;num>=0;num--)
init_P();
P1 = table_numberP[num];
P0 = table[num];
delay_ms(5);
void init_P()
P1 = 0xff;
P0 = 0x00;
void delay_ms(int num)
int i,j;
for (i=num;i>0;i--)
for(j=110;j>0;j--);
问题:
当num=1时,显示0,1正常
当num=2时,显示为8,1,2
为什么会出现这个问题
备注:原理图及接线图
