两片NRF24L01无法实现通信
- #include <STC12C5A60S2.H>
- #include"LCD1602display.h"
- // Define interface to nRF24L01
- // Define SPI pinssbit qq=P3^4;
- sbit CE = P2^1; // Chip Enable pin signal (output)
- sbit CSN = P2^2; // Slave Select pin, (output to CSN, nRF24L01)
- sbit SCK = P2^3; // Master Out, Slave In pin (output)
- sbit MOSI = P2^4; // Serial Clock pin, (output)
- sbit MISO = P2^5; // Master In, Slave Out pin (input)
- sbit IRQ = P2^6; // Interrupt signal, from nRF24L01 (input)
- sbit P3_7=P3^2;
- // SPI(nRF24L01) commands
- #define READ_REG 0x00 // Define read command to register
- #define WRITE_REG 0x20 // Define write command to register
- #define RD_RX_PLOAD 0x61 // Define RX payload register address
- #define WR_TX_PLOAD 0xA0 // Define TX payload register address
- #define FLUSH_TX 0xE1 // Define flush TX register command
- #define FLUSH_RX 0xE2 // Define flush RX register command
- #define REUSE_TX_PL 0xE3 // Define reuse TX payload register command
- #define NOP 0xFF // Define No Operation, might be used to read status register
- // SPI(nRF24L01) registers(addresses)
- #define CONFIG 0x00 // 'Config' register address
- #define EN_AA 0x01 // 'Enable Auto Acknowledgment' register address
- #define EN_RXADDR 0x02 // 'Enabled RX addresses' register address
- #define SETUP_AW 0x03 // 'Setup address width' register address
- #define SETUP_RETR 0x04 // 'Setup Auto. Retrans' register address
- #define RF_CH 0x05 // 'RF channel' register address
- #define RF_SETUP 0x06 // 'RF setup' register address
- #define STATUS 0x07 // 'Status' register address
- #define OBSERVE_TX 0x08 // 'Observe TX' register address
- #define CD 0x09 // 'Carrier Detect' register address
- #define RX_ADDR_P0 0x0A // 'RX address pipe0' register address
- #define RX_ADDR_P1 0x0B // 'RX address pipe1' register address
- #define RX_ADDR_P2 0x0C // 'RX address pipe2' register address
- #define RX_ADDR_P3 0x0D // 'RX address pipe3' register address
- #define RX_ADDR_P4 0x0E // 'RX address pipe4' register address
- #define RX_ADDR_P5 0x0F // 'RX address pipe5' register address
- #define TX_ADDR 0x10 // 'TX address' register address
- #define RX_PW_P0 0x11 // 'RX payload width, pipe0' register address
- #define RX_PW_P1 0x12 // 'RX payload width, pipe1' register address
- #define RX_PW_P2 0x13 // 'RX payload width, pipe2' register address
- #define RX_PW_P3 0x14 // 'RX payload width, pipe3' register address
- #define RX_PW_P4 0x15 // 'RX payload width, pipe4' register address
- #define RX_PW_P5 0x16 // 'RX payload width, pipe5' register address
- #define FIFO_STATUS 0x17 // 'FIFO Status Register' register address
- #define uchar unsigned char
- #define TX_ADR_WIDTH 5 // 5字节宽度的发送/接收地址
- #define TX_PLOAD_WIDTH 4 // 数据通道有效数据宽度
- uchar code table[]={'0','1','2','3','4','5','6','7','8','9','a','b','c','d','e','f'};
- uchar code
- TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01};
- // 定义一个静态发送地址,该地址是指通道0的地址吗??
- uchar RX_BUF[TX_PLOAD_WIDTH]; //是否以确定发送与接收的数据宽度一样??
- uchar TX_BUF[TX_PLOAD_WIDTH]; //是否以确定发送与接收的数据宽度一样??
- uchar flag; //该字符的作用???
- uchar x=0,y=0,z=0,m=0; //为什么设置为这个数字
- uchar bdata sta;
- sbit RX_DR = sta^6;
- sbit TX_DS = sta^5;
- sbit MAX_RT = sta^4;
- 函数:delay_ms()
- 描述:
- 延迟x毫秒
- void delay_ms(uchar x)
- uchar i, j;
- i = 0;
- for(i=0; i<x; i++)
- j = 250;
- while(--j);
- j = 250;
- while(--j);
- 函数:SPI_RW()
- 描述:
- 根据SPI协议,写一字节数据到nRF24L01,同时从nRF24L01
- 读出一字节
- //是不是接收端与发射端都要用到这个函数,读出的字节是否为状态字
- uchar SPI_RW(uchar byte)
- uchar i;
- for(i=0; i<8; i++) // 循环8次
- MOSI = (byte & 0x80); // byte最高位输出到MOSI
- byte <<= 1; // 低一位移位到最高位
- SCK = 1; // 拉高SCK,nRF24L01从MOSI读入1位数据,同时从MISO输出1位数据
- byte |= MISO; // 读MISO到byte最低位
- SCK = 0; // SCK置低
- return(byte); // 返回读出的一字节
- 函数:SPI_RW_Reg()
- 描述:写数据value到reg寄存器
- 是不是通过写地址确定寄存器,然后向其写数据??
- uchar SPI_RW_Reg(uchar reg, uchar value)
- uchar status;
- CSN = 0; // CSN置低,开始传输数据
- status = SPI_RW(reg); // 选择寄存器,同时返回状态字
- SPI_RW(value); // 然后写数据到该寄存器
- CSN = 1; // CSN拉高,结束数据传输
- return(status); // 返回状态寄存器
- 函数:SPI_Read()
- 描述:
- 从reg寄存器读一字节
- uchar SPI_Read(uchar reg)
- uchar reg_val;
- SPI_RW(reg); // 选择寄存器
- reg_val = SPI_RW(0); // 然后从该寄存器读数据 为什么送一个0就可以读回一个数据
- CSN = 1;
- // CSN拉高,结束数据传输
- return(reg_val); // 返回寄存器数据
- 函数:SPI_Read_Buf()
- 描述:
- 从reg寄存器读出bytes个字节,通常用来读取接收通道
- 数据或接收/发送地址
- uchar SPI_Read_Buf(uchar reg, uchar * pBuf, uchar bytes)
- uchar status, i;
- for(i=0; i<bytes; i++)
- pBuf[ i] = SPI_RW(0); // 逐个字节从nRF24L01读出
- 函数:SPI_Write_Buf()
- 描述:
- 把pBuf缓存中的数据写入到nRF24L01,通常用来写入发
- 射通道数据或接收/发送地址
- uchar SPI_Write_Buf(uchar reg, uchar * pBuf, uchar bytes)
- uchar status, i;
- SPI_RW(pBuf[ i]); // 逐个字节写入nRF24L01
- 函数:RX_Mode()
- 描述:
- 这个函数设置nRF24L01为接收模式,等待接收发送设备的数据包
- void RX_Mode(void)
- CE = 0;
- SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f);
- // CRC使能,16位CRC校验,上电,接收模式
- CE = 1; // 拉高CE启动接收设备
- 函数:TX_Mode()
- 描述:
- 这个函数设置nRF24L01为发送模式,(CE=1持续至少10us),
- 130us后启动发射,数据发送结束后,发送模块自动转入接收
- 模式等待应答信号。
- void TX_Mode(uchar * BUF)
- CE = 0;
- SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);
- // 写入发送地址 (与接收地址一样)
- SPI_Write_Buf(WR_TX_PLOAD, BUF, TX_PLOAD_WIDTH);
- // 写数据包到TX FIFO(前以定义BUF数组发送数据4字节,写数据用于发送模式)
- SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);
- CE = 1;
- 函数: init_io()
- 描述:
- 初始化IO
- void init_io(void)
- CE = 0; // 待机
- CSN = 1; // SPI禁止
- SCK = 0; // SPI时钟置低
- IRQ = 1; // 中断复位
- SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH);
- // 为了应答接收设备,接收通道0地址和发送地址相同 (发射端设置0通道接收应答信号)
- SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 使能接收通道0自动应答
- SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 使能接收通道0
- SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x0a);
- // 自动重发延时等待250us+86us,自动重发10次
- SPI_RW_Reg(WRITE_REG + RF_CH, 10);
- // 选择射频通道0x40
- SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH);
- // 接收通道0选择和发送通道相同有效数据宽度
- SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);
- // 数据传输率1Mbps,发射功率0dBm,低噪声放大器增益
- 函数:CheckButtons()
- 描述:
- 检查按键是否按下,按下则发送一字节数据
- void CheckButtons()
- if(!P3_7) // 读取P3^0状态
- delay_ms(10);
- TX_BUF[0]=x ; // 数据送到缓存 (uchar DATA = 0x01;)
- TX_BUF[1]=y;
- TX_BUF[2]=z ; // 数据送到缓存 (uchar DATA = 0x01;)
- TX_BUF[3]=m;
- DisplayOneChar(4,0,table[x%16]);
- DisplayOneChar(4,1,table[y%16]);
- x++;y++;z+=2;m+=3;
- RX_Mode(); // 设置为接收模式
- while(!P3_7);
- void Init_T0 (void)
- TMOD = 0x01;
- TH0 = (65536-50000) /256;
- TL0 = (65536-50000) %256;
- EA = 1;
- ET0 = 1;
- TR0 = 1;
- 函数:main()
- 描述:
- 主函数
- void main(void)
- { qq=0;init_io(); // 初始化IO
- LCDInit();
- Init_T0();
- DisplayListChar(1,0,"Xt=");
- DisplayListChar(1,1,"Yt=");
- DisplayListChar(7,0,"Xr=");
- DisplayListChar(7,1,"Yr=");
- while(1)
- CheckButtons();
- void Time0_ISR(void) interrupt 1
- TH0 = (65536-30000) /256;
- TL0 = (65536-30000) %256;
- SPI_RW(FLUSH_TX);
- TX_Mode(TX_BUF); // 把nRF24L01设置为发送模式并发送数据
- // Check_ACK(1); // 等待发送完毕,清除TX FIFO
- // SPI_RW(FLUSH_TX);
- sta = SPI_Read(STATUS); // 读状态寄存器
- if(RX_DR) // 判断是否接受到数据
- SPI_Read_Buf(RD_RX_PLOAD, RX_BUF, TX_PLOAD_WIDTH);
- // 从RX FIFO读出数据
- flag = 1;
- SPI_RW_Reg(WRITE_REG + STATUS, sta); // 清除RX_DS中断标志
- if(flag) // 接受完成
- flag = 0; // 清标志
- DisplayOneChar(10,0,table[RX_BUF[1]%16]);
- DisplayOneChar(10,1,table[RX_BUF[2]%16]);
