#include <reg51.h>
uchar num=0; //技术标记
uchar W=0; //脉宽值0~20
sbit PLA=P3^3;
sbit PLB=P3^4;
sbit PLED=P3^5;
void delayms(unsigned int k)
unsigned int i,j;
for(i=0;i<k;i++)
for(j=0;j<121;j++)
void T0_init()
TMOD=0x01;
TL0=0xEA; //设置定时初值
TH0=0xFF; //设置定时初值
EA=1; //开总中断
ET0=1; //定时器0的中断允许开关
TR0=1; //开定时器。
T0_init();
if(num==20)
num=0;
PLED=~PLED;
else if(num<15)
PLA=0; //低电平有效
PLB=0;
PLA=1;
PLB=1;
void T0_time() interrupt 1
TL0 = 0xEA; //设置定时初值
TH0 = 0xFF; //设置定时初值
num++;
