查看: 1285|回复: 0
12864万年历程序
ID:233078 发表于 2017-9-14 11:56 | 显示全部楼层 |阅读模式
  参数  AT89S52MCS-51 12MHZ
//程序部分开始//
//头文件
//#include <AT89X52.h>
#include <string.h>
#include<reg52.h>
//灯与扬声器定义
sbit led_back =  P1^0;//
sbit led_b =  P2^3;//秒闪烁灯
sbit led_r =  P2^4;
sbit led_g1 = P2^5;//
sbit led_g2 = P2^5;
sbit led_g3 = P2^5;
sbit led_g4 = P2^5;
sbit beep   = P1^1;//
//温度传感器定义
sbit DQ = P1 ^ 6;//ds18B20
//键盘引脚定义
sbit KEY_1 = P3^0;  //左上
sbit KEY_2 = P3^1;  //左下
sbit KEY_3 = P3^2;  //右上
sbit KEY_4 = P3^3;  //右下
sbit KEY_I = P3^4;  //
//LCD接口定义
sbit RS = P2^0;//模式位为0输入指令为1输入数据
sbit RW = P2^1;//读写位为0读为1写
sbit E = P2^2;//使能位
#define Lcd_Bus P0 //数据总线
//定义DS1302时钟接口
sbit clock_clk = P3 ^ 7;//ds1302_clk时钟线
sbit clock_dat = P3 ^ 6;//ds1302_dat数据线
sbit clock_Rst = P3 ^ 5;//ds1302_Rst复位线
//定义累加器A中的各位
sbit a0   = ACC ^ 0;
sbit a1   = ACC ^ 1;
sbit a2   = ACC ^ 2;
sbit a3   = ACC ^ 3;
sbit a4   = ACC ^ 4;
sbit a5   = ACC ^ 5;
sbit a6   = ACC ^ 6;
sbit a7   = ACC ^ 7;
//定义全局变量
unsigned char yy,mo,dd,xq,hh,mm,ss;//定义时间映射全局变量专用寄存器
bit w = 0; //调时标志位
static unsigned char menu = 0;//定义静态小时更新用数据变量
static unsigned char keys = 0;//定义静态小时更新用数据变量
static unsigned char timecount = 0;//定义静态软件计数器变量
void DelayM(unsigned int a){//延时函数 1MS/次
  unsigned char i;
  while( --a != 0){
   for(i = 0; i < 125; i++);  //一个 ; 表示空语句,CPU空转。
  }          //i 从0加到125CPU大概就耗时1毫秒
//LCD驱动
void chk_busy(){//检查忙位底层
   RS=0;
   RW=1;
   E=1;
   Lcd_Bus=0xff;
   while((Lcd_Bus&0x80)==0x80);
   E=0;
void write_com(unsigned char cmdcode){//写命令到LCD底层
chk_busy();
RS=0;
RW=0;
E=1;
Lcd_Bus=cmdcode;
E=0;
void write_data(unsigned char Dispdata){  //写数据到LCD底层
chk_busy();
RS=1;
RW=0;
E=1;
Lcd_Bus=Dispdata;
E=0;
void lcm_init(){//初始化LCD屏被调用层
   write_com(0x30);       //选择8bit数据流
   write_com(0x0c);       //开显示(无游标、不反白)
   write_com(0x01);       //清除显示并且设定地址指针为00H
void lcm_w_word(unsigned char *s){//向LCM发送一个字符串,长度64字符之内。被调用层
while(*s>0){     //应用lcm_w_word("您好");
     write_data(*s);
     s++;
void lcm_w_test(bit i,unsigned char word){//写指令或数据被调用层
if(i == 0){
  write_com(word);//写指令或数据0指令
}else{
  write_data(word);//写指令或数据1数据
void lcm_clr(void){//清屏函数
lcm_w_test(0,0x01);
//公历节日数据库表
void days (void) {   //公历节日数据库
  lcm_w_test(0,0x80);//在屏幕第一行
  lcm_w_word("[Dis]      [Set]");//显示菜单操作注释
  lcm_w_test(0,0x98);//在屏幕第四行
  if ( mo == 0x01 && dd == 0x01 ){ lcm_w_word("Happy New Year!!"); }//1月
  if ( mo == 0x02 && dd == 0x02 ){ lcm_w_word("  世界湿地日    "); }//2月
  if ( mo == 0x02 && dd == 0x13 ){ lcm_w_word("  明天情人节了  "); }
  if ( mo == 0x02 && dd == 0x14 ){ lcm_w_word("  今天是情人节  "); }
  if ( mo == 0x03 && dd == 0x01 ){ lcm_w_word("  国际海豹日    "); }//3月
  if ( mo == 0x03 && dd == 0x03 ){ lcm_w_word("  全国爱耳日    "); }
  if ( mo == 0x03 && dd == 0x08 ){ lcm_w_word("   3.8妇女节    "); }
  if ( mo == 0x03 && dd == 0x12 ){ lcm_w_word("    植树节      "); }
  if ( mo == 0x03 && dd == 0x14 ){ lcm_w_word("  国际警察日    "); }
  if ( mo == 0x03 && dd == 0x15 ){ lcm_w_word("  消费者权益日  "); }
  if ( mo == 0x03 && dd == 0x17 ){ lcm_w_word("  国际航海日    "); }
  if ( mo == 0x03 && dd == 0x21 ){ lcm_w_word("  世界森林日    "); }
  if ( mo == 0x03 && dd == 0x22 ){ lcm_w_word("    世界水日    "); }
  if ( mo == 0x03 && dd == 0x23 ){ lcm_w_word("  世界气象日    "); }
  if ( mo == 0x03 && dd == 0x24 ){ lcm_w_word("世界防治结核病日"); }
  if ( mo == 0x04 && dd == 0x01 ){ lcm_w_word("愚人节  小心上当"); }//4
  if ( mo == 0x04 && dd == 0x07 ){ lcm_w_word("  世界卫生日    "); }
  if ( mo == 0x04 && dd == 0x08 ){ lcm_w_word("    复活节      "); }
  if ( mo == 0x04 && dd == 0x13 ){ lcm_w_word("  黑色星期五    "); }
  if ( mo == 0x05 && dd == 0x01 ){ lcm_w_word("  劳动节  放假  "); }//5
  if ( mo == 0x05 && dd == 0x04 ){ lcm_w_word("    青年节      "); }
  if ( mo == 0x05 && dd == 0x08 ){ lcm_w_word("  世界红十字日  "); }
  if ( mo == 0x05 && dd == 0x12 ){ lcm_w_word("  国际护士节    "); }
  if ( mo == 0x05 && dd == 0x05 ){ lcm_w_word("近日注意母亲节  "); }
  if ( mo == 0x05 && dd == 0x15 ){ lcm_w_word("  国际家庭日    "); }
  if ( mo == 0x05 && dd == 0x31 ){ lcm_w_word("  世界无烟日    "); }
  if ( mo == 0x06 && dd == 0x01 ){ lcm_w_word("  国际儿童节    "); }//6
  if ( mo == 0x06 && dd == 0x05 ){ lcm_w_word("  世界环境日    "); }
  if ( mo == 0x06 && dd == 0x26 ){ lcm_w_word("  国际禁毒日    "); }
  if ( mo == 0x06 && dd == 0x06 ){ lcm_w_word("  全国爱眼日    "); }
  if ( mo == 0x06 && dd == 0x13 ){ lcm_w_word("近日注意父亲节  "); }
  if ( mo == 0x06 && dd == 0x15 ){ lcm_w_word("近日注意父亲节  "); }
  if ( mo == 0x07 && dd == 0x01 ){ lcm_w_word("香港回归记念日  "); }//7
  if ( mo == 0x07 && dd == 0x07 ){ lcm_w_word("抗日战争记念日  "); }
  if ( mo == 0x07 && dd == 0x11 ){ lcm_w_word("  世界人口日    "); }
  if ( mo == 0x08 && dd == 0x01 ){ lcm_w_word("  八一建军节    "); }//8
  if ( mo == 0x08 && dd == 0x08 ){ lcm_w_word("  中国男子节    "); }
  if ( mo == 0x08 && dd == 0x15 ){ lcm_w_word("抗战胜利记念日  "); }
  if ( mo == 0x09 && dd == 0x10 ){ lcm_w_word("  中国教师节    "); }//9
  if ( mo == 0x09 && dd == 0x18 ){ lcm_w_word("九·一八事变记念"); }
  if ( mo == 0x09 && dd == 0x20 ){ lcm_w_word("  国际爱牙日    "); }
  if ( mo == 0x09 && dd == 0x27 ){ lcm_w_word("  世界旅游日    "); }
  if ( mo == 0x10 && dd == 0x01 ){ lcm_w_word("  中国国庆节    "); }//10
  if ( mo == 0x10 && dd == 0x04 ){ lcm_w_word("  世界动物日    "); }
  if ( mo == 0x10 && dd == 0x24 ){ lcm_w_word("    联合国日    "); }
  if ( mo == 0x10 && dd == 0x12 ){ lcm_w_word("明天国际教师节  "); }
  if ( mo == 0x10 && dd == 0x13 ){ lcm_w_word("  国际教师节    "); }
  if ( mo == 0x11 && dd == 0x10 ){ lcm_w_word("  世界青年节    "); }//11
  if ( mo == 0x11 && dd == 0x17 ){ lcm_w_word("  世界学生节    "); }
  if ( mo == 0x12 && dd == 0x01 ){ lcm_w_word("  世界艾滋病日  "); }//12
  if ( mo == 0x12 && dd == 0x23 ){ lcm_w_word("  明晚平安夜    "); }
  if ( mo == 0x12 && dd == 0x24 ){ lcm_w_word("  今晚平安夜    "); }
  if ( mo == 0x12 && dd == 0x25 ){ lcm_w_word("    圣诞快乐    "); }
  if ( mo == 0x12 && dd == 0x31 ){ lcm_w_word("    明日新年    "); }
  else{//非节日时显示时晨信息
   if ( hh >= 0x04 && hh <  0x06 ){ lcm_w_word("★★__▲▲__凌晨"); }
   if ( hh >= 0x06 && hh <  0x08 ){ lcm_w_word("☆○__▲△__早晨"); }
   if ( hh >= 0x08 && hh <  0x12 ){ lcm_w_word("__●__▲▲__上午"); }
   if ( hh == 0x12)               { lcm_w_word("____▲●▲__中午"); }
   if ( hh >= 0x13 && hh <  0x18 ){ lcm_w_word("__▲▲__●__下午"); }
   if ( hh >= 0x18 && hh <  0x22 ){ lcm_w_word("△▲__●☆__晚上"); }
   if ( hh >= 0x22 && hh <= 0x23 ){ lcm_w_word("△▲__★☆__夜里"); }
   if ( hh >= 0x00 && hh <  0x04 ){ lcm_w_word("__★▲▲★__深夜"); }
//DS18B20温度传感器驱动显示0至60度
void Delay(int num){//延时函数
while(num--) ;
void Init_DS18B20(void){//初始化ds1820
unsigned char x=0;
DQ = 1;    //DQ复位
Delay(8);  //稍做延时
DQ = 0;    //单片机将DQ拉低
Delay(80); //精确延时 大于 480us
DQ = 1;    //拉高总线
Delay(14);
x=DQ;      //稍做延时后 如果x=0则初始化成功 x=1则初始化失败
Delay(20);
unsigned char ReadOneChar(void){//读一个字节
unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--){
  DQ = 0; // 给脉冲信号
  dat>>=1;
  DQ = 1; // 给脉冲信号
  if(DQ)
  dat|=0x80;
  Delay(4);
return(dat);
void WriteOneChar(unsigned char dat){//写一个字节
unsigned char i=0;
for (i=8; i>0; i--){
  DQ = 0;
  DQ = dat&0x01;
  Delay(5);
  DQ = 1;
  dat>>=1;
unsigned int ReadTemperature(void){//读取温度
unsigned char a=0;
unsigned char b=0;
unsigned int t=0;
float tt=0;
Init_DS18B20();
WriteOneChar(0xCC); // 跳过读序号列号的操作
WriteOneChar(0x44); // 启动温度转换
Init_DS18B20();
WriteOneChar(0xCC); //跳过读序号列号的操作
WriteOneChar(0xBE); //读取温度寄存器
a=ReadOneChar();  //读低8位
b=ReadOneChar(); //读高8位
t=b;
t<<=8;
t=t|a;
tt=t*0.0625;
t= tt*10+0.5; //放大10倍输出并四舍五入
return(t);
//声明当各函数的排列适当时可不用声明
void lcm_w_ss(void);
void lcm_w_mm(void);
void lcm_w_hh(void);
void lcm_w_dd(void);
void lcm_w_mo(void);
void lcm_w_yy(void);
void lcm_w_xq(void);
unsigned char clock_in(void);
void clock_out(unsigned char dd);
void Init_1302(void);
unsigned char read_clock(unsigned char ord);
void read_clockS(void);
void Set_time(unsigned char sel);
void write_clock(unsigned char ord, unsigned char dd);
void updata (void);
//DS1302时钟芯片驱动程序
//常用时钟数据读取
void read_clockS(void){
ss = read_clock(0x81);//读取秒数据
mm = read_clock(0x83);//读取分钟数据
hh = read_clock(0x85);//小时
dd = read_clock(0x87);//日
mo = read_clock(0x89);//月
xq = read_clock(0x8b);//星期
yy = read_clock(0x8d);//年
//调时用加1程序
void Set_time(unsigned char sel){ //根据选择调整的相应项目加1并写入DS1302
  signed char address,item;
  signed char max,mini;
  lcm_w_test(0,0x9a);
  lcm_w_word("调整");
//if(sel==6)  {lcm_w_word("秒钟");address=0x80; max=0;mini=0;}     //秒7
  if(sel==5)  {lcm_w_word("分钟");address=0x82; max=59;mini=0;}    //分钟6
  if(sel==4)  {lcm_w_word("小时");address=0x84; max=23;mini=0;}    //小时5
  if(sel==3)  {lcm_w_word("星期");address=0x8a; max=7;mini=1;}    //星期4
  if(sel==2)  {lcm_w_word("日期");address=0x86; max=31;mini=1;}    //日3
  if(sel==1)  {lcm_w_word("月份");address=0x88; max=12;mini=1;}    //月2
  if(sel==0)  {lcm_w_word("年份");address=0x8c; max=99; mini=0;}    //年1
  //读取1302某地址上的数值转换成10进制赋给item
  item=((read_clock(address+1))/16)*10 + (read_clock(address+1))%16;
  if(KEY_2 == 0){
   item++;//数加 1
  if(KEY_4 == 0){
   item--;//数减 1
  if(item>max) item=mini;//查看数值有效范围
  if(item<mini) item=max;
write_clock(0x8e,0x00);//允许写操作
  write_clock(address,(item/10)*16+item%10);//转换成16进制写入1302
  write_clock(0x8e,0x80);//写保护禁止写操作
  updata (); //刷新数据
  lcm_w_mm();//刷新 分
//设置1302的初始时间自动初始化
void Init_1302(void){//-设置1302的初始时间2007年1月1日00时00分00秒星期一
unsigned char f;
if(read_clock(0xc1) != 0xaa){
  write_clock(0x8c,0x07);//年
  write_clock(0x8a,0x01);//星期
  write_clock(0x88,0x01);//月
  write_clock(0x86,0x01);//日
  write_clock(0x84,0x00);//小时
  write_clock(0x82,0x00);//分钟
  write_clock(0x80,0x00);//秒
  write_clock(0x90,0xa5);//充电
  write_clock(0xc0,0xaa);//写入初始化标志RAM第00个RAM位置
  for(f=0;f<60;f=f+2)
  {//清除闹钟RAM位为0
  write_clock(0xc2+f,0x00);
  write_clock(0x8e,0x80);//禁止写操作
//DS1302写数据底层协议
void write_clock(unsigned char ord, unsigned char dd){
clock_clk=0;
clock_Rst=0;
clock_Rst=1;
clock_out(ord);
clock_out(dd);
clock_Rst=0;
clock_clk=1;
//1302驱动程序底层协议
void clock_out(unsigned char dd){
ACC=dd;
clock_dat=a0; clock_clk=1; clock_clk=0;
clock_dat=a1; clock_clk=1; clock_clk=0;
clock_dat=a2; clock_clk=1; clock_clk=0;
clock_dat=a3; clock_clk=1; clock_clk=0;
clock_dat=a4; clock_clk=1; clock_clk=0;
clock_dat=a5; clock_clk=1; clock_clk=0;
clock_dat=a6; clock_clk=1; clock_clk=0;
clock_dat=a7; clock_clk=1; clock_clk=0;
//DS1302写入字节底层协议
unsigned char clock_in(void){
clock_dat=1;
a0=clock_dat;
clock_clk=1; clock_clk=0; a1=clock_dat;
clock_clk=1; clock_clk=0; a2=clock_dat;
clock_clk=1; clock_clk=0; a3=clock_dat;
clock_clk=1; clock_clk=0; a4=clock_dat;
clock_clk=1; clock_clk=0; a5=clock_dat;
clock_clk=1; clock_clk=0; a6=clock_dat;
clock_clk=1; clock_clk=0; a7=clock_dat;
return(ACC);
//DS1302读数据底层协议
unsigned char read_clock(unsigned char ord){
unsigned char dd=0;
clock_clk=0;
clock_Rst=0;
clock_Rst=1;
clock_out(ord);
dd=clock_in();
clock_Rst=0;
clock_clk=1;
return(dd);
void Beep(void){//BELL-扬声器--整点报时
unsigned char a;//定义变量用于发声的长度设置
for(a=60;a>0;a--){//第一个声音的长度
  beep = ~beep;//取反扬声器驱动口以产生音频
Delay(100);//音调设置延时
for(a=100;a>0;a--){//同上
  beep = ~beep;
  Delay(80);//
  beep = ~beep;
  Delay(30);//
beep = 1;//音乐结束后扬声器拉高关闭
void Beep_set(void){//BELL -扬声器--确定设置
for(a=50;a>0;a--){//第一个声音的长度
  Delay(100);//音调设置延时
  beep = ~beep;
  Delay(50);//
for(a=50;a>0;a--){//同上
  beep = ~beep;
  Delay(100);//
void Beep_key(void){//-扬声器--按键音
for(a=100;a>0;a--){//声音的长度
  beep = ~beep;
  Delay(50);//音调设置延时
//向LCM中填写 年 数据
void lcm_w_yy(void){
//if(read_clock(0x8d) != yy){
  lcm_w_test(0,0x83);
  lcm_w_word("20");
  lcm_w_test(0,0x84);
  lcm_w_test(1,(yy/16)+0x30);
  lcm_w_test(1,yy%16+0x30);
//向LCM中填写 月 数据
void lcm_w_mo(void){
//if(read_clock(0x89) != mo){
  lcm_w_test(0,0x90);
   if(mo/16 != 0){lcm_w_test(1,(mo/16)+0x30);} //十位消隐
   else{lcm_w_test(1,0x20);}//同上
  lcm_w_test(1,mo%16+0x30);
  lcm_w_test(0,0x91);
  lcm_w_word("月");
//星期处理并送入LCM的指定区域
void lcm_w_xq(void){
unsigned char sel;
//if(read_clock(0x8b) != xq){
sel = (read_clock(0x8b))%16; //字节低4位的BCD码放入sel
lcm_w_test(0,0x97);//写入指定区域97H 第二行第8个字
if(sel==7)  {lcm_w_word("日");}    //
   if(sel==6)  {lcm_w_word("六");}    //
   if(sel==5)  {lcm_w_word("五");}    //
   if(sel==4)  {lcm_w_word("四");}    //
   if(sel==3)  {lcm_w_test(1,0xc8);lcm_w_test(1,0xfd);} //此指令等于lcm_w_word("三"); 因为“三”的内码失效。
   if(sel==2)  {lcm_w_word("二");}    //
   if(sel==1)  {lcm_w_word("一");}    //星期一
lcm_w_test(0,0x95);
lcm_w_word("星期");
//向LCM中填写 日 数据
void lcm_w_dd(void){
// if(read_clock(0x87) != dd){
  lcm_w_test(0,0x92);
   if(dd/16 != 0){lcm_w_test(1,(dd/16)+0x30);} //十位消隐
  lcm_w_test(1,dd%16+0x30);
  lcm_w_test(0,0x93);
  lcm_w_word("日  ");
//向LCM中填写 小时 数据
void lcm_w_hh(void){
if(read_clock(0x85) != hh){
   if (hh > 0x07 && hh < 0x22 && w == 0){
    Beep();//整点报时音
  lcm_w_test(0,0x88);
  lcm_w_test(1,(hh/16)+0x30);
  lcm_w_test(1,hh%16+0x30);
//向LCM中填写 分钟 数据
void lcm_w_mm(void)
if(read_clock(0x83) != mm){
  if(w == 0)
   days();//节日显示
lcm_w_test(0,0x89);
lcm_w_test(1,0x3a);   //":"
lcm_w_test(1,(mm/16)+0x30);
lcm_w_test(1,mm%16+0x30);
lcm_w_test(1,0x2e);  //"."
//刷新数据
void updata (void){
  lcm_w_mm();//刷新 分
  lcm_w_hh();//刷新 小时
  lcm_w_dd();//刷新 日
lcm_w_xq();//更新星期值
  lcm_w_mo();//刷新 月
  lcm_w_yy();//刷新 年
//向LCM中填写 秒 数据
void lcm_w_ss(void){
unsigned int i=0;
unsigned char a=0,b=0,c=0;
if(read_clock(0x81) != ss){ //判断是否需要更新
  ss = read_clock(0x81); //更新数据
  lcm_w_test(0,0x8b);  //秒值在LCM上的写入位置
  lcm_w_test(1,(ss/16)+0x30); //写十位
  lcm_w_test(1,ss%16+0x30); //写个位
  lcm_w_word("  ");
  led_b = ~led_b;    //LED闪烁
  updata (); //刷新数据
  lcm_w_test(0,0x8d);  //温度在LCM上的写入位置
  i=ReadTemperature();//读温度并送显
  a=i/100;
  lcm_w_test(1,a+0x30); //显示温度十位
  b=i/10-a*10;
  lcm_w_test(1,b+0x30); //个位
  c=i-a*100-b*10;
  lcm_w_test(1,c+0x30); //小位1位
  lcm_w_word("℃"); //度C
void welcome(void){
lcm_w_word("   0123456789  ABCDEFG                  ");//
//----------|-------1-------|-------3-------|-------2-------|-------4-------|-----//标尺
//---主程序---//
main() {
unsigned char e=0;
KEY_I = 0;KEY_1 = 1;KEY_2 = 1;KEY_3 = 1;KEY_4 = 1;//初始键盘
yy=0xff;mo=0xff;dd=0xff;xq=0xff;hh=0xff;mm=0xff;ss=0xff; //各数据刷新
Beep();
led_back = 0;
Init_1302();
lcm_init();//初始化液晶显示器
lcm_clr();//清屏
welcome();//显示欢迎信息
DelayM(3000); //显示等留3秒
while(1){//主循环
  if (w == 0){   //正常走时
  lcm_w_ss();//刷新 秒
  else {  //启动调时
  if (KEY_3 == 0) // 设置时间
         DelayM(20);    //去抖
   led_g3 = 0;led_r = 1;
   if(KEY_3 == 0 && w == 1)  //当是调时状态 本键用于调整下一项
    Beep_key();//按键音
    e++;
    if (e >= 6 ){e = 0;}
    Set_time(e);//调整
   if(KEY_3 == 0 && w == 0)  //当是正常状态时就进入调时状态
    Beep_set();//确定按键音
    led_b = 1;//
    lcm_clr();//清屏
    w=1;   //进入调时
    lcm_w_test(0,0x9e);
    lcm_w_word(" [-]");
lcm_w_test(0,0x80);
    lcm_w_word("[Esc]");
    lcm_w_test(0,0x85);
    lcm_w_word("[Next]");
    lcm_w_test(0,0x98);
    lcm_w_word("[+]");
    Set_time(e);//调整
         while(KEY_3 == 0);//等待键松开
   led_g3 = 1; led_r = 0;//红灯亮表示调时
if (KEY_1 == 0) // 当在调时状态时就退出调时
         DelayM(20);
   led_g1 = 0;led_r = 1;
         if(KEY_1 == 0 && w == 1){
    Beep_set();//确定按键音
    w = 0;   //退出调时
    e = 0;  //“下一项”计数器清0
   if(KEY_1 == 0 && w == 0){
    lcm_clr();//清屏
    lcm_w_test(0,0x80);
    welcome();//显示欢迎信息
    while(KEY_1 == 0);//等待键松开
    lcm_clr();//清屏
    updata (); //刷新数据
    lcm_w_mm();//刷新 分
   led_g1 = 1;
  if (KEY_2 == 0 && w == 1) // 加减调整{
         DelayM(20);
   led_g2 = 0;led_r = 1;
         if(KEY_2 == 0 && w == 1){
    Beep_key();//按键音
    Set_time(e);//调整
         while(KEY_2 == 0);//等待键松开
   led_g2 = 1; led_r = 0;
  if (KEY_4 == 0 && w == 1){ // 加减调整
         DelayM(20);
   led_g4 = 0;led_r = 1;
         if(KEY_4 == 0 && w == 1){
    Beep_key();//按键音
    Set_time(e);//调整
         while(KEY_4 == 0);
   led_g4 = 1; led_r = 0;
