查看: 10674|回复: 2
STM8 TIME1做正交编码器输入测试
ID:80436 发表于 2015-5-21 22:22 | 显示全部楼层 |阅读模式
  • //                           _ooOoo_
  • //                          o8888888o
  • //                          88" . "88
  • //                          (| -_- |)
  • //                          O\  =  /O
  • //                       ____/`---'\____
  • //                   /  _||||| -:- |||||-  \
  • //                   | \_|  ''\---/''  |   |
  • //                   \  .-\__  `-`  ___/-. /
  • //                 ___`. .'  /--.--\  `. . __
  • //              ."" '<  `.___\_<|>_/___.'  >'"".
  • //             | | :  `- \`.;`\ _ /`;.`/ - ` : | |
  • //             \  \ `-.   \_ __\ /__ _/   .-` /  /
  • //        ======`-.____`-.___\_____/___.-`____.-'======
  • //                   佛祖保佑       永不死机
  • //                   心外无法       法外无心
  * @file    Project/main.c
  * @author  MCD Application Team
  * @version V2.1.0
  * @date    18-November-2011
  * @brief   Main program body
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm8s.h"
#include <stdio.h>
#include <math.h>
/* Private defines -----------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
#define LED_GPIO_PORT  GPIOA
#define LED_GPIO_PIN  GPIO_PIN_3
void Delay(uint16_t nCount)
  /* Decrement nCount value */
  while (nCount != 0)
    nCount--;
uint8_t i=0;
void Init_GPIO(void)
GPIO_Init(LED_GPIO_PORT, LED_GPIO_PIN, GPIO_MODE_OUT_PP_LOW_FAST);
void Init_Timer1(void)
TIM1_TimeBaseInit(0,TIM1_COUNTERMODE_UP ,65535,0);
TIM1_EncoderInterfaceConfig(TIM1_ENCODERMODE_TI1, TIM1_ICPOLARITY_RISING, TIM1_ICPOLARITY_RISING);
TIM1_ARRPreloadConfig(ENABLE);
TIM1_Cmd(ENABLE);
void Init_Timer4(void)
/*TIM4_UpdateDisableConfig(ENABLE);//允许更新事件
TIM4_ARRPreloadConfig(ENABLE);//自动重装
TIM4_ITConfig(TIM4_IT_UPDATE, ENABLE);//中断配置,更新中断
TIM4_SetCounter(0xff);//计数器初值
TIM4_SetAutoreload(0xFF);//计数器自动重装的初值
TIM4_PrescalerCoL(TIM4_PRESCALER_128, TIM4_PSCRELOADMODE_UPDATE);//预分频值
TIM4_TimeBaseInit(TIM4_PRESCALER_128, 0xff);
  /* Clear TIM4 update flag */
  TIM4_ClearFlag(TIM4_FLAG_UPDATE);
/* Enable update interrupt */
TIM4_Cmd(ENABLE);
void Init_UART1(void)
UART1_DeInit();
UART1_Init((u32)9600, UART1_WORDLENGTH_8D, UART1_STOPBITS_1, UART1_PARITY_NO, UART1_SYNCMODE_CLOCK_DISABLE, UART1_MODE_TX_ENABLE);
//UART1_Cmd(ENABLE);
void Send(uint8_t dat)
  while(( UART1_GetFlagStatus(UART1_FLAG_TXE)==RESET));
UART1_SendData8(dat);
void UART_SendString( char *p)
while(*p!=0x00)       //判断字符串是否发送完毕
Send(*p++);
void sendswj_int (int datasend)//上位机发送格式
sprintf(send_int,"%d",abs(datasend));
if(datasend>0)
UART_SendString("+");
UART_SendString("-");
UART_SendString(send_int);
//UART_SendString(0,"b");
UART_SendString("\r\n");
void main(void)
  int ecode=0;
  int temp=0;
  CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);
  Init_UART1();
  Init_GPIO();
// Init_Timer4();
  Init_Timer1();
  enableInterrupts();
  while (1)
    ecode=(TIM1->CNTRH<<8)|TIM1->CNTRL;
    if(ecode!=temp)
    sendswj_int(ecode);
    temp=ecode;
#ifdef USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
ID:639665 发表于 2020-11-12 11:17 | 显示全部楼层
那个像,太牛了!
ID:81138 发表于 2021-1-27 18:19 | 显示全部楼层
刚刚学习STM8希望能讲的详细点
