查看: 362|回复: 1
赛元微单片机ADC初始化问题
ID:1041297 发表于 2024-8-29 16:17 | 显示全部楼层 |阅读模式
在NTC那里我接了4.7K的电阻,也就是下图CN3的位置,理应ADC得返回2048左右的ADC值,但是返回出来只有200多,我的单片机芯片SC92F7411,用过他们赛元微里面的例程代码,返回出来的值也是一样,请问我应该怎么改,请大伙指点迷津,谢谢!!!!
void ADC_Init(uint Channel);
unsigned int ADC_GetAverageValue(void);
//unsigned int ADCValue = 0x0000;
uint8_t  tmpValue;
bit AdcFlag = 0;
float  ADC_Voltage;                                     //ADC电压
float NTC_Temperature;     //NTC温度值
uint32_t xdata ADC_Value;           //ADC值
/***********ADC采样频率选择*************/
enum ADCFreq {F32=0,F24,F16,F12,F8,F6,F4,F3};
*函数名称:void ADC_Init(uint Channel,uchar ADCFreq)
*函数功能:ADC初始化
*入口参数:void
*出口参数:void
        ADCCON = 0X80|Channel;                //开启ADC,ADC采样频率为3M ,选择Channel位ADC采样口
        if(Channel<8)
                ADCCFG0 = 1<<Channel;   //设置Channel作为采样口
                ADCCFG1 = 1<<(Channel-8);   //设置Channel作为采样口
        //ADCCFG2 = F8;
        IE |= 0X40;        //开启ADC中断
*函数名称:uint ADC_GetAverageValue(uint Channel,ADC_SamplesNum_TypeDef ADC_SamplesNum)
*函数功能:ADC采样取平均值
*入口参数:
ADC_SamplesNum_TypeDef ADC_SamplesNum:采样次数
*出口参数:
uint:多次采样平均值
uint32_t ADC_GetAverageValue(void)
        ADCCON |= 0X40;             //开始一次ADC转换
        while(!AdcFlag);          //等待ADC转换完成
        AdcFlag = 0;
        tmpValue=(ADCVH<<4)+(ADCVL>>4);     //获取单次转换值
        return tmpValue;                        //返回平均值
void ADC_Interrupt(void) interrupt 6
        ADCCON&=~(0X20);  //清中断标志位
        AdcFlag = 1;
//NTC电阻值
uint32_t code ntc_r[100]=
        //180°~ 189°
        1548,1514,1480,1447,1414,1383,1353,1323,1294,1266,
        //190°~199°
        1239,1212,1186,1160,1136,1112,1088,1065,1043,1021,
        //200°~209°
        1000,978,957,937,917,897,878,860,841,824,
        //210~219°
        807,790,773,758,742,727,712,698,683,670,
        //220°~229°
        656,643,630,618,606,594,582,571,560,549,
// 定义常量
#define R_FIXED 4700.0 // 固定电阻值4.7kΩ
#define B_CONST 4537.0 // NTC的B常数
#define T0 473.15 // 200℃转换为开尔文
#define R0 1000.0 // NTC在200℃时的电阻值1kΩ
函数功能:计算温度的值
参数:无
返回值:无
备注:无
float calculate_temperature(float voltage)
    float R_ntc;
    float V_supply = 5.0; // 电源电压5.0V
          float tmp1 = 0.0;
                float tmp2 = 0.0;
    // 计算NTC电阻值
    R_ntc = R_FIXED * (V_supply / voltage - 1);   //voltage是ADC值换算过来的电压
    // 计算温度(开尔文)
                tmp1 = R_ntc/R0;
                tmp2 = log(tmp1);
                tmp1 = tmp2/B_CONST;
                tmp2 = 1/T0;
                tmp1 = (tmp1+tmp2);
                tmp2 = 1.0/tmp1;
                if(tmp2 <= 274)tmp2 = 274;
                // 转换为摄氏度
                tmp2 -= 273.15;
                //tmp1 = tmp2+0.05;   //温度补偿
                //返回温度
    return tmp2;
ID:404160 发表于 2024-9-2 14:13 | 显示全部楼层
试试这段程序,如果还是一样,可能是硬件问题
#include "sc92f7411.h"
// 假设ADC模块的基地址为0x50000000
#define ADC_BASE 0x50000000
// ADC控制寄存器定义
#define ADC_CR1 *(volatile unsigned int *)(ADC_BASE)
#define ADC_CR2 *(volatile unsigned int *)(ADC_BASE + 4)
#define ADC_DR  *(volatile unsigned short *)(ADC_BASE + 8)
// ADC时钟使能(请根据实际情况修改)
void ADC_ClockInit() {
// ADC初始化
void ADC_Init() {
    ADC_ClockInit();
    // 配置ADC控制寄存器
    ADC_CR1 = 0x00; // 清除控制寄存器
    ADC_CR2 = 0x00; // 清除控制寄存器
    // 设置采样时间、通道等(根据数据手册配置)
    ADC_CR1 |= (1 << 12); // 设置采样时间
    ADC_CR2 |= (3 << 0);  // 选择通道3
    // 使能ADC
    ADC_CR2 |= (1 << 0);
// 启动ADC转换
void ADC_StartConvert() {
    // 启动ADC转换
    ADC_CR2 |= (1 << 3);
// 读取ADC转换结果
uint16_t ADC_ReadValue() {
    // 等待转换完成(可通过中断方式)
    return ADC_DR;
