查看: 935|回复: 0
led灯闪烁实例
ID:357062 发表于 2018-6-23 10:25 | 显示全部楼层 |阅读模式
#include<reg52.h>
sbit LED = P0^0;
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
void main()  //void即函数类型
    //以下为声明语句部分
    unsigned int i = 0;  //定义一个无符号整型变量i,并赋初值0
    //以下为执行语句部分
    ENLED = 0;   //U3、U4两片74HC138总使能
    ADDR3 = 1;   //使能U3使之正常输出
    ADDR2 = 1;   //经U3的Y6输出开启三极管Q16
    ADDR1 = 1;
    ADDR0 = 0;
    while (1)
        LED = 0;                  //点亮小灯
        for (i=0; i<30000; i++);  //延时一段时间
        LED = 1;                  //熄灭小灯
