- 名称:LCD1602
- 编写:shifang
- 日期:2009.5
- 修改:无
- 内容:通过标准程序静态显示字符
- 引脚定义如下:1-VSS 2-VDD 3-V0 4-RS 5-R/W 6-E 7-14 DB0-DB7 15-BLA 16-BLK
- #include<reg52.h> //包含头文件,一般情况不需要改动,头文件包含特殊功能寄存器的定义
- #include<intrins.h>
- sbit RS = P2^4; //定义端口
- sbit RW = P2^5;
- sbit EN = P2^6;
- #define RS_CLR RS=0
- #define RS_SET RS=1
- #define RW_CLR RW=0
- #define RW_SET RW=1
- #define EN_CLR EN=0
- #define EN_SET EN=1
- #define DataPort P0
- uS延时函数,含有输入参数 unsigned char t,无返回值
- unsigned char 是定义无符号字符变量,其值的范围是
- 0~255 这里使用晶振12M,精确延时请使用汇编,大致延时
- 长度如下 T=tx2+5 uS
- void DelayUs2x(unsigned char t)
- while(--t);
- mS延时函数,含有输入参数 unsigned char t,无返回值
- void DelayMs(unsigned char t)
- while(t--)
- //大致延时1mS
- DelayUs2x(245);
- DelayUs2x(245);
- 判忙函数
- bit LCD_Check_Busy(void)
- DataPort= 0xFF;
- RS_CLR;
- RW_SET;
- EN_CLR;
- _nop_();
- EN_SET;
- return (bit)(DataPort & 0x80);
- 写入命令函数
- void LCD_Write_Com(unsigned char com)
- while(LCD_Check_Busy()); //忙则等待
- RS_CLR;
- RW_CLR;
- EN_SET;
- DataPort= com;
- _nop_();
- EN_CLR;
- 写入数据函数
- void LCD_Write_Data(unsigned char Data)
- RS_SET;
- RW_CLR;
- EN_SET;
- DataPort= Data;
- _nop_();
- EN_CLR;
- 清屏函数
- void LCD_Clear(void)
- LCD_Write_Com(0x01);
- DelayMs(5);
- 写入字符串函数
- void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
- if (y == 0)
- LCD_Write_Com(0x80 + x); //表示第一行
- else
- LCD_Write_Com(0xC0 + x); //表示第二行
- while (*s)
- LCD_Write_Data( *s);
- s ++;
- 写入字符函数
- void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data)
- if (y == 0)
- else
- LCD_Write_Data( Data);
- 初始化函数
- void LCD_Init(void)
- LCD_Write_Com(0x38); /*显示模式设置*/
- DelayMs(5);
- DelayMs(5);
- DelayMs(5);
- LCD_Write_Com(0x08); /*显示关闭*/
- LCD_Write_Com(0x01); /*显示清屏*/
- LCD_Write_Com(0x06); /*显示光标移动设置*/
- DelayMs(5);
- LCD_Write_Com(0x0C); /*显示开及光标设置*/
- 主函数
- void main(void)
- LCD_Init();
- LCD_Clear();//清屏
- while (1)
- LCD_Write_Char(7,0,'o');
- LCD_Write_Char(8,0,'k');
- LCD_Write_String(1,1,"222222");
- while(1);
复制代码 |
