查看: 8377|回复: 4
51单片机音乐程序源代码,歌名保密
ID:75263 发表于 2015-3-24 23:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
鉴于今天这个特殊的日子,我又编译了一首歌,歌名暂时保密,这段代码,送给不远处的你,搬起砖头我无法拥抱你,放下转头我无法养活你,我现在就在搬砖中,还得继续学习深造啊。
#include <reg52.h>
sbit beep=P1^0;
unsigned int C;
#define L1 262
#define L2 284
#define L3 311
#define L4 349
#define L5 392
#define L6 440
#define L7 494
#define Z1 523
#define Z2 587
#define Z3 659
#define Z4 698
#define Z5 784
#define Z6 880
#define Z7 987
#define H1 1046
#define H2 1174
#define H3 1318
#define H4 1396
#define H5 1567
#define H6 1760
#define H7 1975
void delay();
unsigned code GP[]={H3,H1,H1,Z6,Z6,Z5,Z5,/**/Z5,Z4,Z3,Z4,Z4,H1,H1,H1,
                   /**/H3,Z7,Z7,H2,H2,Z7,/**/Z7,Z5,Z5,/**/Z5,Z5,Z6,H3,H2,H1,H1,Z6,
                                   /**/H2,
                                   /**/H2,H2,H2,H2,H1,H1,H5,
                                   /**/H5,H3,H3,/**/H5,H5,H5,H3,H3,H1,/**/H3,H2,H2,
                                  /**/H2,H2,H2,H2,H2,H2,/**/H1,H2,H3,H5,H5,/**/
                                   H5,L5,L6,Z3,Z2,Z1,L6,/**/Z2,/**/Z2,Z2,Z2,Z2,Z1,
                                   Z1,Z2,/**/Z5,Z3,Z3,/**/Z5,Z5,Z5,Z3,Z3,Z1,/**/Z3,
                                   Z2,Z2,/**/Z2,Z2,Z2,Z2,Z2,Z2,/**/Z3,Z2,L6,Z1,Z1,
                                   /**/Z1,/**/Z5,Z6,H3,H2,H1,H1,Z6,/**/H2,
                                   /**/H2,H2,H2,H2,H2,H1,H2,/**/H3,H5,H3,H2,H3,/**/
                                   H3,H3,H3,H2,H1,/**/H2,H1,Z6,Z6,/**/H2,H1,Z6,Z6,/**/
                                   H1,H1,H1,H2,H2,/**/H2,Z5,Z6,H3,H2,H1,H1,Z6,/**/H2,
                                   H1,H1,H1,H2,H2,/**/Z5,Z6,H3,H2,H1,H1,Z6,/**/H2,/**/H2,H2,
                                   H2,H2,H1,H1,H2,/**/H5,H3,H3,/**/H5,H5,H5,Z3,H3,H1,/**/
                                   H3,H2,H2,/**/H2,H2,H2,H2,H2,H2,/**/H3,H2,Z6,H1,H1,/**/
                                   H1,Z1,Z1,Z3,Z3,Z6,Z7,Z6,
                                   /**/0xff};
unsigned code JP[]={4,4,4,4,4,4,8,/**/4,4,4,4,4,4,4,4,/**/12,4,4,4,4,4,/**/
                     12,4,12,/**/4,4,4,4,6,2,4,4,/**/20,/**/4,4,4,6,
                                         2,4,4,/**/4,4,20,/**/8,4,6,2,4,4,/**/4,4,8,
                                         /**/4,4,4,4,4,4,/**/8,8,4,4,8,/**/4,4,4,4,6,2,4,4,
                                         /**/12,/**/4,4,4,6,2,4,4,/**/4,4,12,/**/8,4,
                                         6,2,4,4,/**/4,4,8,/**/4,4,4,4,4,4,/**/8,8,4,4,8,
                                         /**/8,/**/4,4,4,6,2,4,4,/**/12,/**/
                                         4,4,4,4,4,4,4,/**/8,8,8,8,8,/**/4,4,4,8,4,/**/
                                         4,8,4,12,/**/4,8,4,12,/**/8,8,4,8,4,/**/4,4,4,4,
                                         4,4,4,4,/**/12,/**/4,4,4,4,4,4,4,/**/8,8,4,8,
                                         4,/**/4,4,4,8,4,/**/4,8,4,12,/**/4,8,4,12,/**/
                                         8,8,4,8,4,/**/4,4,4,6,2,4,4,/**/12,/**/4,4,4,6,2,
                                         4,4,/**/4,4,12,/**/8,4,6,2,4,4,/**/4,4,8,
                                         /**/4,4,4,4,4,4,/**/8,8,4,4,8,/**/4,4,4,4,4,4,4,4,
{ uchar i,j;
TMOD=0x00;
EA=1;         //开总中断
ET0=1;        //开t0中断
{ i=0;
while(GP[i]!=0xff)
{C=460830/GP[i];
TH0=(8192-C)/32;
TL0=(8192-C)%32;
TR0=1;//开定时器0
for(j=0;j<JP[i];j++)
{delay();}
TR0=0;
i++;
beep=0;
void delay()          //延时15.6ms
uint i,j;
for(i=70;i>0;i--)
   {for(j=110;j>0;j--);}
void T0_time()interrupt 1
{ TR0=0;
beep=!beep;
TH0=(8192-C)/32;
TL0=(8192-C)%32;
TR0=1;
收藏收藏2 分享淘帖 顶 踩
ID:673731 发表于 2019-12-25 16:50 | 只看该作者
  1. while(GP[i]!=0xff) {C=460830/GP[i]; TH0=(8192-C)/32; TL0=(8192-C)%32;
大佬这一段什么意思呀
ID:665331 发表于 2019-12-26 08:40 来自手机 | 只看该作者
厉害厉害
ID:678235 发表于 2020-1-1 14:13 | 只看该作者
用汇编的会吗
ID:288930 发表于 2020-2-14 10:30 | 只看该作者
喇叭声音太小,怎样放大电流?
