查看: 3842|回复: 1
关于stc89c52单片机贪吃蛇小游戏源码 12864显示
ID:149311 发表于 2018-8-10 15:55 | 显示全部楼层 |阅读模式
  制作一个贪吃蛇小游戏用12864显示,即时显示,可控制速度,附上源代码,just娱乐,可供研究
  1. //12864并行接口参考程序,控制器st7920
  2. #include "reg51.h"
  3. #include "Lcd12864.h"
  4. #include "Key.h"
  5. #define uchar unsigned char
  6. #define uint unsigned int
  7. static unsigned long Seed = 1;
  8. #define A 48271L
  9. #define M 2147483647L
  10. #define Q (M / A)
  11. #define R (M % A)
  12. /************************************
  13. 伪随机数发生器
  14. *************************************/
  15. double Random(void)
  16. {
  17.         long TmpSeed;
  18.         TmpSeed=A*(Seed%Q)-R*(Seed/Q);
  19.         if(TmpSeed>=0)
  20.                 Seed=TmpSeed;
  21.         else
  22.                 Seed=TmpSeed+M;
  23.         return (double)Seed/M;
  24. }
  25. /**************************************
  26. 为伪随机数发生器播种
  27. ***************************************/
  28. void InitRandom(unsigned long InitVal)
  29. {
  30.         Seed=InitVal;
  31. }
  32. //延时子程序
  33. void delay(unsigned int t)
  34. {
  35.         unsigned int i,j;
  36.         for(i=0;i<t;i++)
  37.                 for(j=0;j<10;j++);
  38. }
  39. /*********************************
  40. 初始化MPU
  41. **********************************/
  42. void InitCpu(void)
  43. {
  44.         TMOD=0x0;
  45.         TH0=0;
  46.         TL0=0;
  47.         TR0=1;
  48.         ET0=1;
  49.         EA=1;
  50. }
  51. #define N 25
  52. struct Food
  53. {
  54.         unsigned char x;
  55.         unsigned char y;
  56.         unsigned char yes;
  57. }food;//食物结构体
  58. struct Snake
  59. {
  60.         unsigned char x[N];
  61.         unsigned char y[N];
  62.         unsigned char node;
  63.         unsigned char direction;
  64.         unsigned char life;
  65. }snake;//蛇结构体
  66. unsigned char Flag=0;
  67. unsigned char Score=0;
  68. unsigned char Speed=5;
  69. unsigned char KeyBuffer=0;
  70. #define FUNC 1
  71. #define UP 2
  72. #define DOWN 3
  73. #define LEFT 4
  74. #define RIGHT 5
  75. #define PASSSCORE 50//预定义过关成绩
  76. void Timer0Int(void) interrupt 1
  77. {
  78.    switch(OSReadKey())
  79.         {
  80. case 9:
  81.                                 KeyBuffer=FUNC;
  82.                                 /*if(++Speed>=10)
  83.                                         Speed=1;
  84.                                    Flag|=1<<1;//速度变化标志置1*/
  85.                                 break;
  86.                 case 13:
  87.                                 KeyBuffer=DOWN;
  88.                                 /*if(snake.direction!=2)
  89.                                         snake.direction=1;*/
  90.                                 break;
  91.                 case 17:
  92.                                 KeyBuffer=UP;
  93.                                 /*if(snake.direction!=1)
  94.                                         snake.direction=2;*/
  95.                                 break;
  96.                 case 21:
  97.                                 KeyBuffer=RIGHT;
  98.                                 /*if(snake.direction!=4)
  99.                                         snake.direction=3;*/
  100.                                 break;
  101.                    case 25:
  102.                                 KeyBuffer=LEFT;
  103.                                 /*if(snake.direction!=3)
  104.                                         snake.direction=4;*/
  105.                                 break;
  106.                 default:
  107.                                 break;
  108.         }
  109.
  110.      /* if(K1==1)
  111.                                  KeyBuffer=DOWN;
  112.                                 //if(++Speed>=10)         Speed=1;        Flag|=1<<1;//速度变化标志置1
  113.
  114.
  115.        if(K2==1)
  116.                         KeyBuffer=RIGHT;
  117.                                 //if(snake.direction!=2)                snake.direction=1;
  118.        */
  119. }
  120. /******************************
  121. 画墙壁,初始化界面
  122. *******************************/
  123. void DrawBoard(void)
  124. {
  125.         unsigned char n;
  126.         for(n=0;n<31;n++)
  127.         {
  128.                 Lcd_Rectangle(3*n,0,3*n+2,2,1);
  129.                 Lcd_Rectangle(3*n,60,3*n+2,62,1);
  130.         }
  131.         for(n=0;n<21;n++)
  132.         {
  133.                 Lcd_Rectangle(0,3*n,2,3*n+2,1);
  134.                 Lcd_Rectangle(90,3*n,92,3*n+2,1);
  135.         }
  136.         Lcd_HoriLine(93,31,35,1);
  137.         Lcd_HoriLine(93,63,35,1);
  138. }
  139. /***************************
  140. 打印成绩
  141. ****************************/
  142. void PrintScore(void)
  143. {
  144.         unsigned char Str[3];
  145.         Lcd_WriteStr(6,0,"成绩");
  146.         Str[0]=(Score/10)|0x30;//十位
  147.         Str[1]=(Score%10)|0x30;//个位
  148.         Str[2]=0;
  149.         Lcd_WriteStr(7,1,Str);
  150. }
  151. /********************************
  152. 打印速度级别
  153. *********************************/
  154. void PrintSpeed(void)
  155. {
  156.         unsigned char Str[2];
  157.         Lcd_WriteStr(6,2,"级别");
  158.         Str[0]=Speed|0x30;
  159.         Str[1]=0;
  160.         Lcd_WriteStr(7,3,Str);
  161. }
  162. /***********************************
  163. 游戏结束处理
  164. ************************************/
  165. void GameOver(void)
  166. {
  167.         unsigned char n;
  168.         Lcd_Rectangle(food.x,food.y,food.x+2,food.y+2,0);//消隐出食物
  169.         for(n=1;n<snake.node;n++)
  170.         {
  171.                 Lcd_Rectangle(snake.x[n],snake.y[n],snake.x[n]+2,snake.y[n]+2,0);//消隐食物,蛇头已到墙壁内,故不用消去
  172.         }
  173.         if(snake.life==0)//如果蛇还活着
  174.                 Lcd_WriteStr(2,1,"通关");
  175.         else             //如果蛇死了
  176.                 Lcd_WriteStr(2,1,"输了");
  177.         Lcd_WriteStr(1,2,"游戏结束");
  178. }
  179. /********************************
  180. 游戏的具体过程,也是贪吃蛇算法的关键部分
  181. *********************************/
  182. void GamePlay(void)
  183. {
  184.         unsigned char n;
  185.         InitRandom(TL0);                 //数据流入
  186.         food.yes=1;//1表示需要出现新事物,0表示已经存在食物尚未吃掉
  187.         snake.life=0;//表示蛇还活着
  188.         snake.direction=DOWN;
  189.         snake.x[0]=6;snake.y[0]=6;
  190.         snake.x[1]=3;snake.y[1]=6;
  191.         snake.node=2;
  192.         PrintScore();
  193.         PrintSpeed();
  194.         while(1)
  195.         {
  196.                 if(food.yes==1)
  197.                 {
  198.                         while(1)
  199.                         {
  200.                                 food.x=Random()*85+3;
  201.                                 food.y=Random()*55+3;//获得随机数
  202.
  203.                                 while(food.x%3!=0)
  204.                                         food.x++;
  205.                                 while(food.y%3!=0)
  206.                                         food.y++;
  207.                             for(n=0;n<snake.node;n++)//判断产生的食物坐标是否和蛇身重合
  208.                                 {
  209.                                         if((food.x==snake.x[n])&&(food.y==snake.y[n]))
  210.                                                 break;
  211.                                 }
  212.                                 if(n==snake.node)
  213.                                 {
  214.                                         food.yes=0;
  215.                                         break;//产生有效的食物坐标
  216.                                 }
  217.                         }
  218.                 }
  219.                 if(food.yes==0)
  220.                 {
  221.                         Lcd_Rectangle(food.x,food.y,food.x+2,food.y+2,1);
  222.                 }
  223.                 for(n=snake.node-1;n>0;n--)
  224.                 {
  225.                         snake.x[n]=snake.x[n-1];
  226.                         snake.y[n]=snake.y[n-1];
  227.                 }
  228.                 switch(snake.direction)
  229.                 {
  230.                         case DOWN:snake.x[0]+=3;break;
  231.                         case UP:snake.x[0]-=3;break;
  232.                         case RIGHT:snake.y[0]-=3;break;
  233.                         case LEFT:snake.y[0]+=3;break;
  234.                         default:break;
  235.                 }
  236.                 for(n=3;n<snake.node;n++)//从第三节开始判断蛇头是否咬到自己
  237.                 {
  238.                         if(snake.x[n]==snake.x[0]&&snake.y[n]==snake.y[0])
  239.                         {
  240.                                 GameOver();
  241.                                 snake.life=1;
  242.                                 break;
  243.                         }
  244.                 }
  245.                 if(snake.x[0]<3||snake.x[0]>=90||snake.y[0]<3||snake.y[0]>=60)//判蛇头是否撞到墙壁
  246.                 {
  247.                         GameOver();
  248.                         snake.life=1;
  249.                 }
  250.                 if(snake.life==1)
  251.                         break;//蛇死,则跳出while(1)循环
  252.                 if(snake.x[0]==food.x&&snake.y[0]==food.y)//判蛇是否吃到食物
  253.                 {
  254.                         Lcd_Rectangle(food.x,food.y,food.x+2,food.y+2,0);//消隐食物
  255.                         snake.x[snake.node]=200;
  256.                         snake.y[snake.node]=200;//产生蛇新的节坐标先放在看不见的位置
  257.                         snake.node++;//蛇节数加1
  258.                         food.yes=1;//食物标志置1
  259.                         if(++Score>=PASSSCORE)
  260.                         {
  261.                                 PrintScore();
  262.                                 GameOver();
  263.                                 break;
  264.                         }
  265.                         PrintScore();
  266.                 }
  267.                 for(n=0;n<snake.node;n++)
  268.                 {
  269.                         Lcd_Rectangle(snake.x[n],snake.y[n],snake.x[n]+2,snake.y[n]+2,1);
  270.                 }//根据蛇的节数画出蛇
  271.                 delay(Speed*1000);
  272.                 Lcd_Rectangle(snake.x[snake.node-1],snake.y[snake.node-1],snake.x[snake.node-1]+2,snake.y[snake.node-1]+2,0);
  273.                 switch(KeyBuffer)
  274.                 {
  275.                         case FUNC:
  276.                                         KeyBuffer=0;
  277.                                         if(++Speed>=10)
  278.                                                 Speed=1;
  279.                                            PrintSpeed();
  280.                                         break;
  281.                         case DOWN:
  282.                                         KeyBuffer=0;
  283.                                         if(snake.direction!=UP)
  284.                                                 snake.direction=DOWN;
  285.                                         break;
  286.                         case UP:
  287.                                         KeyBuffer=0;
  288.                                         if(snake.direction!=DOWN)
  289.                                                 snake.direction=UP;
  290.                                         break;
  291.                         case RIGHT:
  292.                                         KeyBuffer=0;
  293.                                         if(snake.direction!=LEFT)
  294.                                                 snake.direction=RIGHT;
  295.                                         break;
  296.                            case LEFT:
  297.                                         KeyBuffer=0;
  298.                                         if(snake.direction!=RIGHT)
  299.                                                 snake.direction=LEFT;
  300.                                         break;
  301.                         default:
  302.                                         break;
  303.                 }
  304.         }//结束while(1)
  305. }
  306. void Main()
  307. {
  308.         InitCpu();//初始化CPU
  309.         Lcd_Reset(); //初始化LCD屏
  310.         Lcd_Clear(0);//清屏
  311.         DrawBoard();//画界面
  312.         GamePlay();//玩游戏
  313.         GameOver();//游戏结束
  314.         while(1);//要想重玩,只能重启,可继续完善该游戏
  315. }
SnakeGame.rar (72.74 KB, 下载次数: 37)
ID:110606 发表于 2018-8-13 15:13 | 显示全部楼层
谢楼主分享,有空试试
