先贴程序main.c:
#include "main.h"
#include "LCD12864.h"
#include "HX711.h"
unsigned long HX711_Buffer = 0;
unsigned int Weight_Maopi = 0,Weight_Shiwu = 0;
//主函数
LCD12864_Reset(); //初始化液晶
LCD12864_HAIZI_SET(); //设置为普通模式
LCD12864_NoWaitIdle_COM_Write(0x80); //指针设置
LCD12864_write_word("※※※※※※※※");
LCD12864_NoWaitIdle_COM_Write(0x90); //指针设置
LCD12864_write_word("※※欢迎使用※※");
Delay_ms(1000); //延时1s,等待传感器稳定
Get_Maopi(); //称毛皮重量
LCD12864_NoWaitIdle_COM_Write(0x01); //清空
Get_Weight(); //称重
if( Weight_Shiwu > 10000 )
LCD12864_write_word("※※※超重※※※");
else if( Weight_Shiwu < 10000)
//显示当前重量
LCD12864_write_word("重量:");
if( Weight_Shiwu/10000 != 0)
LCD12864_Data_Write(Weight_Shiwu/10000 + 0x30);
LCD12864_Data_Write(' ');
LCD12864_Data_Write(Weight_Shiwu%10000/1000 + 0x30);
LCD12864_Data_Write('.');
LCD12864_Data_Write(Weight_Shiwu%1000/100 + 0x30);
LCD12864_Data_Write(Weight_Shiwu%100/10 + 0x30);
LCD12864_Data_Write(Weight_Shiwu%10 + 0x30);
LCD12864_write_word(" Kg");
if( Weight_Shiwu*2/10000 != 0)
LCD12864_Data_Write(Weight_Shiwu*2/10000 + 0x30);
LCD12864_Data_Write(Weight_Shiwu*2%10000/1000 + 0x30);
LCD12864_Data_Write(Weight_Shiwu*2%1000/100 + 0x30);
LCD12864_Data_Write(Weight_Shiwu*2%100/10 + 0x30);
LCD12864_Data_Write(Weight_Shiwu*2%10 + 0x30);
LCD12864_write_word(" ");
//称重
void Get_Weight()
HX711_Buffer = HX711_Read();
HX711_Buffer = HX711_Buffer/100;
if(HX711_Buffer > Weight_Maopi)
Weight_Shiwu = HX711_Buffer;
Weight_Shiwu = Weight_Shiwu - Weight_Maopi; //获取实物的AD采样数值。
Weight_Shiwu = (unsigned int)((float)Weight_Shiwu/2.09+0.05); //计算实物的实际重量
//因为不同的传感器特性曲线不一样,因此,每一个传感器需要矫正这里的2.15这个除数。
//当发现测试出来的重量偏大时,增加该数值。
//如果测试出来的重量偏小时,减小改数值。
//该数值一般在2.15附近调整之间。因传感器不同而定。
//+0.05是为了四舍五入百分位
Weight_Shiwu=Weight_Shiwu/2;
//获取毛皮重量
void Get_Maopi()
unsigned char i = 0;
unsigned int Temp_Weight = 0;
Weight_Maopi = 0;
for( i = 0 ; i < 10 ; i++)
Temp_Weight = HX711_Buffer/100;
if( Temp_Weight > Weight_Maopi)
Weight_Maopi = Temp_Weight;
//MS延时函数(12M晶振下测试)
void Delay_ms(unsigned int n)
unsigned int i,j;
for(i=0;i<n;i++)
for(j=0;j<123;j++);
main.h:
#ifndef __MAIN_H__
#define __MAIN_H__
#include <reg52.h>
//函数或者变量声明
extern void Delay_ms(unsigned int n);
extern void Get_Maopi();
extern void Get_Weight();
#endif
LCD12864.h:
#ifndef __LCD12864_H__
#define __LCD12864_H__
#include <reg52.h>
#include <intrins.h>
//引脚定义
sbit LCD12864_RS_PORT = P1^0;
sbit LCD12864_RW_PORT = P1^1;
sbit LCD12864_E_PORT = P1^2;
#define LCD12864_DA_PORT P2
//函数或者变量声明
extern void LCD12864_WaitIdle();
extern void LCD12864_COM_Write( unsigned char com_da);
extern void LCD12864_NoWaitIdle_COM_Write(unsigned char com_da);
extern void LCD12864_Data_Write(unsigned char da);
extern void lcd_delay_ms(unsigned char x);
extern void LCD12864_Reset();
extern void LCD12864_write_word(unsigned char *s);
//extern void LCD12864_PHOTO_SET();
extern void LCD12864_HAIZI_SET();
//extern void LCD12864_HAIZI_WRITE(unsigned char xpos,unsigned char ypos,unsigned char daH,unsigned char daL);
//extern void LCD12864_PHOTO_WRITE(unsigned char *img);
#endif
HX711.h:
#ifndef __HX711_H__
#define __HX711_H__
#include <reg52.h>
//IO设置
sbit HX711_DOUT=P3^4;
sbit HX711_SCK=P3^5;
//函数或者变量声明
extern void Delay__hx711_us(void);
extern unsigned long HX711_Read(void);
#endif
LCD12864.c:
//LCD12864 忙 信号检测
unsigned char i;
LCD12864_DA_PORT = 0xff;
LCD12864_RS_PORT = 0;
LCD12864_RW_PORT = 1;
LCD12864_E_PORT = 1;
while((LCD12864_DA_PORT&0x80)==1); /*等待BF 不为1*/
LCD12864_E_PORT = 0;
for(i=0;i<5;i++);
//检测忙信号写入命令字 com_da 为待写入的命令字
LCD12864_RW_PORT = 0;
LCD12864_DA_PORT = com_da;
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
//不检测忙信号写入命令字 com_da 为待写入的命令字
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
//数据写入 da 为待写入的8位数据
LCD12864_WaitIdle(); /*检测忙信号*/
LCD12864_RS_PORT = 1;
LCD12864_DA_PORT = da;
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
//写连续字符函数
while(*s>0)
LCD12864_Data_Write(*s);
s++;
//1MS为单位的延时程序,不准确
unsigned char j;
while(x--){
for(j=0;j<125;j++)
//LCD12864初始化
lcd_delay_ms(100); /*适当延时待LCD自动复位完成*/
LCD12864_NoWaitIdle_COM_Write(0x30); /*使用8位并口通讯*/
lcd_delay_ms(10);
lcd_delay_ms(10);
LCD12864_NoWaitIdle_COM_Write(0x0c); /*显示开及光标设置*/
lcd_delay_ms(10);
LCD12864_NoWaitIdle_COM_Write(0x01); /*显示清屏*/
lcd_delay_ms(30);
LCD12864_NoWaitIdle_COM_Write(0x06); /*DDRAM的地址计数器(AC)加1*/
lcd_delay_ms(30);
//void LCD12864_PHOTO_SET()
// LCD12864_COM_Write(0x36);
// lcd_delay_ms(10);
LCD12864_COM_Write(0x30);
lcd_delay_ms(10);
lcd_delay_ms(10);
//void LCD12864_HAIZI_WRITE(unsigned char xpos,unsigned char ypos,unsigned char daH,unsigned char daL)
////ST7920 汉字字符写入
////参数说明: xpos 待写入的X位置
////ypos 待写入的Y位置
////daH 待写入的汉字的高八位 daL待写入的汉字的低八位
// unsigned char xy_pos;
// if((xpos>=8)||(ypos>=4) ) return; /*X位置超出显示范围退出*/
// if(ypos==0) xy_pos = 0x80 + xpos;
// else if(ypos==1) xy_pos = 0x90 + xpos; /*计算转换地址*/
// else if(ypos==2) xy_pos = 0x88 + xpos;
// else if(ypos==3) xy_pos = 0x98 + xpos;
// LCD12864_COM_Write(xy_pos); /*写地址*/
// lcd_delay_ms(1);
// LCD12864_Data_Write(daH); /*写高八位数据*/
// lcd_delay_ms(1);
// LCD12864_Data_Write(daL); /*写低八位数据*/
// lcd_delay_ms(1);
//void LCD12864_PHOTO_WRITE(unsigned char *img)
// unsigned char x,y,i,j;
// unsigned int k=0;
// y=0x80; /*设置起始 绘图区的 Y地址坐标*/
// x=0x80; /*设置起始 绘图区的 X地址坐标*/
// for(i=0;i<32;i++){ /*写上半部*/
// LCD12864_COM_Write(y);
// LCD12864_COM_Write(x);
// for(j=0;j<16;j++){
// LCD12864_Data_Write(img[k]);
// k++;
// y++;
// x=0x88; /*设置起始 绘图区的 X地址坐标*/
// for(i=0;i<32;i++){ /*写下半部*/
// k++;
// y++;
HX711.c:
#include "HX711.h"
//延时函数
_nop_();
_nop_();
//读取HX711
unsigned long HX711_Read(void) //增益128
unsigned long count;
unsigned char i;
HX711_DOUT=1;
Delay__hx711_us();
HX711_SCK=0;
count=0;
while(HX711_DOUT);
for(i=0;i<24;i++)
HX711_SCK=1;
count=count<<1;
HX711_SCK=0;
if(HX711_DOUT)
count++;
HX711_SCK=1;
Delay__hx711_us();
HX711_SCK=0;
return(count);
电路图
12864中文.doc
2.61 MB, 下载次数: 25, 下载积分: 黑币 -5
附上12864说明
