- #include<reg51.h>
- #define uint unsigned int
- #define uchar unsigned char
- #define wei=P2;
- #define duan=P0;
- sbit led=P1^0;
- sbit S2=P3^0;
- sbit S3=P3^1;
- sbit S4=P3^2;
- uchar sec,num;
- uint cnt=0; //全局变量,控制数码管显示的数字的变化
- uint ge,shi,qian,bai;
- uchar code arry[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
- void delay(uint i);//软件延时函数
- void display(); //数码管显示函数
- void delay(uint i)//软件延时函数
- uint a,c;
- for(a =i;a>0;a--)
- for(c=114;c>0;c--);
- void display()
- qian=cnt/1000;
- bai=(cnt%1000)/100;
- shi=((cnt%1000)%100)/10;
- ge= ((cnt%1000)%100)%10;
- P2=0xf7;
- P0=arry[ge];
- delay(5); //防止重影
- P2=0xfb;
- P0=arry[shi];
- delay(5);
- P2=0xfd;
- P0=arry[bai];
- delay(5);
- P2=0xfe;
- P0=arry[qian];
- delay(5);
- void Timer0Init()
- TMOD|=0X11;//选择为定时器0模式,工作方式1,仅用TR0打开启动。
- TH0=0X3c; //给定时器赋初值,定时1ms
- TL0=0Xb0;
- TH1=0X3C;
- TL1=0XB0;
- ET1=1;
- ET0=1;//打开定时器0中断允许
- EA=1;//打开总中断
- void Timer0() interrupt 1
- TH0=0X3c; //
- TL0=0Xb0;
- sec++;
- if(sec==20)
- TF0=0;
- sec=0;
- cnt++;
- if(cnt==9999)
- cnt=9999;
- TR0=0;
- TF0=0;
- void Timer1() interrupt 3
- TH1=0X3c; //
- TL1=0Xb0;
- num++;
- if(num==10)
- num=0;
- TF1=0;
- led=~led;
- void main()//主函数
- Timer0Init();
- while(1)
- display();
- if(S2==0)//开始/复位
- delay(10);
- if(S2==0)
- sec = 0;
- num=0;
- cnt=0;
- TR0=1;
- TR1=1;
- if(S3==0)//暂停
- delay(10);
- if(S3==0)
- TR0 = 0; //关闭定时器
- TF0 = 0;
- TR1=0;
- TF1=0;
- if(S4==0)//继续开始
- delay(10);
- if(S4==0)
- sec = 0;
- num=0;
- TR0=1;
- TR1=1;
51单片机0到9999数码管显示的Proteus仿真 代码.dsn.zip
(77.43 KB, 下载次数: 82)
