51单片机做的心形花样流水灯,DIY小作品必备
电路原理图如下:
- *说明:将32个LED分成4组LED_P0,LED_P1,LED_P3,LED_P2,每一组代表8个LED灯,也就是讲心形分成4个部分,
- * 如下图所示,这样,我们只需操作这些值,然后将这些值对应到相应的IO口上就可以了
- * LED_P0.2 LED_P2.5
- * LED_P0.3 LED_P0.1 LED_P2.6 LED_P2.4
- * LED_P0.4 LED_P0.0 LED_P2.7 LED_P2.3
- * LED_P0.5 LED_P2.2
- * LED_P0.6 LED_P2.1
- * LED_P0.7 LED_P2.0
- * LED_P1.0 LED_P3.7
- * LED_P1.1 LED_P3.6
- * LED_P1.2 LED_P3.5
- * LED_P1.3 LED_P3.4
- * LED_P1.4 LED_P3.3
- * LED_P1.5 LED_P3.2
- * LED_P1.6 LED_P3.1
- * LED_P1.7 LED_P3.0
- #include <reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- #define FOSC 12000000L //晶振设置,使用11.0592M Hz 6T双速倍模式
- volatile uchar LED_P0 = 0xff;
- volatile uchar LED_P1 = 0xff;
- volatile uchar LED_P2 = 0xff;
- volatile uchar LED_P3 = 0xff;
- #define SCENE_COUNT 20//定义循环播放发的数量
- //可自定义场景,按场景顺序播放多种状态
- uchar scene[SCENE_COUNT] = {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19};
- uchar code table0[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//LED从低位往高位移
- uchar code table1[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};//LED从高位往低位移
- uchar code table2[]={0xfe,0xfc,0xf8,0xf0,0xe0,0xc0,0x80,0x00};//LED从1个亮到8个都点亮(从低位往高位)
- uchar code table3[]={0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01,0x00};//LED从1个亮到8个都点亮(从高位往低位)
- uchar code table4[]={0x00,0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff};//LED从8个全亮到一个都不亮(从低位往高位)
- uchar code table5[]={0x00,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff};//LED从8个全亮到一个都不亮(从高位往低位)
- uchar code table6[]={0xfe,0xfc,0xfa,0xf6,0xee,0xde,0xbe,0x7e};//LED从低位往高位移(最低位始终为0)
- uchar code table7[]={0x7f,0x3f,0x5f,0x6f,0x77,0x7b,0x7d,0x7e};//LED从高位往低位移(最高位始终为0)
- uchar i,j; //定义循环变量
- uint tt=70; //定义时间指数
- //延时函数
- void Delayms(uint ms)
- uint x,y;
- for(x=ms;x>0;x--)
- for(y=125;y>0;y--);
- //将LED_P0,LED_P1,LED_P3,LED_P2的值的对应到具体IO口上,并延时
- void Display(uint time)
- P0 = ((LED_P0 & 0xfe)>>1) + ((LED_P1 & 0x01)<<7);
- P1 = ((LED_P1 & 0xfe)>>1) + ((LED_P3 & 0x01)<<7);
- P3 = ((LED_P3 & 0xfe)>>1) + ((LED_P2 & 0x01)<<7);
- P2 = ((LED_P2 & 0xfe)>>1) + ((LED_P0 & 0x01)<<7);
- Delayms(time);
- //状态0 所有LED闪烁3次
- void disp0()
- for(i=0;i<3;i++)
- LED_P0=0x00; LED_P2=0x00; LED_P3=0x00; LED_P1=0x00;
- Display(300);
- LED_P0=0xff; LED_P2=0xff; LED_P3=0xff; LED_P1=0xff;
- Display(300);
- //状态1 LED顺时针转一圈
- void disp1()
- for(i=0;i<8;i++)
- LED_P2=table1[i];
- Display(100);
- LED_P2=0xff;
- for(i=0;i<8;i++)
- LED_P3=table1[i];
- Display(100);
- LED_P3=0xff;
- for(i=0;i<8;i++)
- LED_P1=table1[i];
- Display(100);
- LED_P1=0xff;
- for(i=0;i<8;i++)
- LED_P0=table1[i];
- Display(100);
- LED_P0=0xff;
- //状态2 LED逆时针转一圈
- void disp2()
- for(i=0;i<8;i++)
- LED_P0=table0[i];
- Display(100);
- LED_P0=0xff;
- for(i=0;i<8;i++)
- LED_P1=table0[i];
- Display(100);
- LED_P1=0xff;
- for(i=0;i<8;i++)
- LED_P3=table0[i];
- Display(100);
- LED_P3=0xff;
- for(i=0;i<8;i++)
- LED_P2=table0[i];
- Display(100);
- LED_P2=0xff;
- //状态3 4个LED同时顺时、逆时针移动1/4圈
- void disp3()
- for(i=0;i<8;i++)
- LED_P0=table0[i];
- LED_P1=table1[i];
- LED_P2=table1[i];
- LED_P3=table0[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P0=table1[i];
- LED_P1=table0[i];
- LED_P2=table0[i];
- LED_P3=table1[i];
- Display(100);
- LED_P3=0xff; LED_P0=0xff;
- //状态4 2个LED同时顺时针移动半圈
- void disp4()
- for(i=0;i<8;i++)
- LED_P2=table1[i];
- LED_P1=table1[i];
- Display(100);
- LED_P2=0xff; LED_P1=0xff;
- for(i=0;i<8;i++)
- LED_P3=table1[i];
- LED_P0=table1[i];
- Display(100);
- //状态5 2个LED同时逆时针移动半圈
- void disp5()
- for(i=0;i<8;i++)
- LED_P0=table0[i];
- LED_P3=table0[i];
- Display(100);
- LED_P0=0xff; LED_P3=0xff;
- for(i=0;i<8;i++)
- LED_P1=table0[i];
- LED_P2=table0[i];
- Display(100);
- LED_P1=0xff; LED_P2=0xff;
- //状态6 LED自上而下逐渐点亮(一半点亮一半不亮)
- void disp6()
- for(i=0;i<8;i++)
- LED_P0=table2[i];
- LED_P2=table3[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P1=table2[i];
- LED_P3=table3[i];
- Display(100);
- LED_P1=0xff; LED_P3=0xff;
- //状态7 LED自下而上逐渐点亮(直到全部点亮)
- void disp7()
- for(i=0;i<8;i++)
- LED_P1=table3[i];
- LED_P3=table2[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P0=table2[i];
- LED_P2=table2[i];
- Display(100);
- //状态8 间断8格的4个LED亮并逆时针旋转
- void disp8()
- for(j=0;j<2;j++)
- for(i=0;i<8;i++)
- LED_P0=table0[i];
- LED_P2=table0[i];
- LED_P1=table0[i];
- LED_P3=table0[i];
- Display(100);
- LED_P0=0xff; LED_P2=0xff; LED_P1=0xff; LED_P3=0xff;
- for(i=0;i<8;i++)
- LED_P0=table0[i];
- LED_P2=table0[i];
- LED_P1=table0[i];
- LED_P3=table0[i];
- Display(100);
- //状态9 间断8格的4个LED亮,然后逆时针逐渐点亮(直到全部点亮)
- void disp9()
- for(i=0;i<8;i++)
- LED_P0=table2[i];
- LED_P2=table2[i];
- LED_P1=table2[i];
- LED_P3=table2[i];
- Display(100);
- Display(500);
- //状态10 从LED全部亮到全不亮(间断8格的4个LED开始逆时针熄灭)
- void disp10()
- for(i=0;i<9;i++)
- LED_P0=table4[i];
- LED_P2=table4[i];
- LED_P1=table4[i];
- LED_P3=table4[i];
- Display(100);
- Display(300);
- //状态11 间断8格的4个LED亮并顺时针旋转
- void disp11()
- for(j=0;j<2;j++)
- for(i=0;i<8;i++)
- LED_P0=table1[i];
- LED_P2=table1[i];
- LED_P1=table1[i];
- LED_P3=table1[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P0=table1[i];
- LED_P2=table1[i];
- LED_P1=table1[i];
- LED_P3=table1[i];
- Display(100);
- //间断8格的4个LED亮,然后顺时针逐渐点亮(直到全部点亮)
- void disp12()
- for(i=0;i<8;i++)
- LED_P0=table3[i];
- LED_P2=table3[i];
- LED_P1=table3[i];
- LED_P3=table3[i];
- Display(100);
- Display(1000);
- //状态13 从LED全部亮到全不亮(间断8格的4个LED开始顺时针熄灭)
- void disp13()
- for(i=0;i<9;i++)
- LED_P0=table5[i];
- LED_P2=table5[i];
- LED_P1=table5[i];
- LED_P3=table5[i];
- Display(100);
- Display(300);
- //状态14 从LED不亮到全亮(从P0.0、P1.0、P2.0、P3.7开始逐步点亮)
- void disp14()
- for(i=0;i<8;i++)
- LED_P0=table3[i];
- LED_P1=table2[i];
- LED_P2=table2[i];
- LED_P3=table3[i];
- Display(100);
- //状态15 从LED全亮到全不亮(从P0.7、P1.7、P2.7、P3.0开始逐步熄灭
- void disp15()
- for(i=0;i<9;i++)
- LED_P0=table4[i];
- LED_P1=table5[i];
- LED_P2=table5[i];
- LED_P3=table4[i];
- Display(100);
- Display(300);
- //状态16 LED灯交替闪烁(频率有慢变快)
- void disp16()
- for(i=0;i<5;i++)
- LED_P0=0xaa; LED_P1=0xaa; LED_P2=0xaa; LED_P3=0xaa;
- Display(100);
- LED_P0=~LED_P0; LED_P1=~LED_P1; LED_P2=~LED_P2; LED_P3=~LED_P3;
- Display(100);
- for(i=0;i<5;i++)
- Display(200);
- Display(200);
- for(i=0;i<5;i++)
- Display(300);
- Display(300);
- Display(300);
- //状态17 LED从P0.7开始逆时针逐步点亮,(循环2次)并且速度会逐步提高
- void disp17()
- for(i=0;i<8;i++)
- LED_P0=table2[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P1=table2[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P3=table2[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P2=table2[i];
- Display(100);
- LED_P0=0xff; LED_P1=0xff; LED_P3=0xff; LED_P2=0xff;
- for(i=0;i<8;i++)
- LED_P0=table2[i];
- Display(50);
- for(i=0;i<8;i++)
- LED_P1=table2[i];
- Display(50);
- for(i=0;i<8;i++)
- LED_P3=table2[i];
- Display(50);
- for(i=0;i<8;i++)
- LED_P2=table2[i];
- Display(50);
- //状态18 LED从P0.7开始逆时针逐步点亮(每亮8位后就熄灭)
- void disp18()
- for(i=0;i<8;i++)
- LED_P0=table2[i];
- Display(100);
- LED_P0=0xff;
- for(i=0;i<8;i++)
- LED_P1=table2[i];
- Display(100);
- LED_P1=0xff;
- for(i=0;i<8;i++)
- LED_P3=table2[i];
- Display(100);
- LED_P3=0xff;
- for(i=0;i<8;i++)
- LED_P2=table2[i];
- Display(100);
- LED_P2=0xff;
- //状态19 LED从P2.7开始顺时针逐步点亮,(循环2次)并且速度会逐步提高
- void disp19()
- for(i=0;i<8;i++)
- LED_P2=table3[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P3=table3[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P1=table3[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P0=table3[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P2=table3[i];
- Display(50);
- for(i=0;i<8;i++)
- LED_P3=table3[i];
- Display(50);
- for(i=0;i<8;i++)
- LED_P1=table3[i];
- Display(50);
- for(i=0;i<8;i++)
- LED_P0=table3[i];
- Display(50);
- //状态20 LED从P2.7开始顺时针逐步点亮(每亮8位后就熄灭)
- void disp20()
- for(i=0;i<8;i++)
- LED_P2=table3[i];
- Display(100);
- LED_P2=0xff;
- for(i=0;i<8;i++)
- LED_P3=table3[i];
- Display(100);
- LED_P3=0xff;
- for(i=0;i<8;i++)
- LED_P1=table3[i];
- Display(100);
- LED_P1=0xff;
- for(i=0;i<8;i++)
- LED_P0=table3[i];
- Display(100);
- LED_P0=0xff;
- //状态21 2个LED开始上下移动半圈
- void disp21()
- for(i=0;i<8;i++)
- LED_P0=table0[i];
- LED_P2=table1[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P1=table0[i];
- LED_P3=table1[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P1=table1[i];
- LED_P3=table0[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P0=table1[i];
- LED_P2=table0[i];
- Display(100);
- //装态22 2个LED自上而下移动(循环5次,且频率渐快,到最快时持续循环16次,然后循环5次频率再逐渐降低)
- void disp22()
- for(j=0;j<5;j++)
- for(i=0;i<8;i++)
- LED_P0=table0[i];
- LED_P2=table1[i];
- Display(tt);
- for(i=0;i<8;i++)
- LED_P1=table0[i];
- LED_P3=table1[i];
- Display(tt);
- tt=tt-10;
- for(j=0;j<16;j++)
- for(i=0;i<8;i++)
- LED_P0=table0[i];
- LED_P2=table1[i];
- Display(20);
- for(i=0;i<8;i++)
- LED_P1=table0[i];
- LED_P3=table1[i];
- Display(20);
- tt=20;
- for(j=0;j<5;j++)
- for(i=0;i<8;i++)
- LED_P0=table0[i];
- LED_P2=table1[i];
- Display(tt);
- for(i=0;i<8;i++)
- LED_P1=table0[i];
- LED_P3=table1[i];
- Display(tt);
- tt=tt+10;
- tt=70;
- //状态23 LED上下交替闪烁
- void disp23()
- for(i=0;i<2;i++)
- Display(1000);
- LED_P1=0x00; LED_P3=0x00;
- Display(1000);
- //状态24 LED左右交替闪烁
- void disp24()
- LED_P1=0xff; LED_P3=0xff; LED_P0=0xff; LED_P2=0xff;
- for(i=0;i<2;i++)
- LED_P0=0x00; LED_P1=0x00;
- Display(1000);
- LED_P2=0x00; LED_P3=0x00;
- Display(1000);
- LED_P2=0xff; LED_P3=0xff;
- //状态25 LED交替闪烁
- void disp25()
- for(i=0;i<5;i++)
- Display(1000);
- Display(1000);
- //状态26 2个LED开始上下移动半圈(LED不亮流水)
- void disp26()
- LED_P0=0x00;LED_P1=0x00;LED_P2=0x00;LED_P3=0x00;
- for(i=0;i<8;i++)
- LED_P0=~table0[i];
- LED_P2=~table1[i];
- Display(200);
- for(i=0;i<8;i++)
- LED_P1=~table0[i];
- LED_P3=~table1[i];
- Display(200);
- for(i=0;i<8;i++)
- LED_P1=~table1[i];
- LED_P3=~table0[i];
- Display(200);
- for(i=0;i<8;i++)
- LED_P0=~table1[i];
- LED_P2=~table0[i];
- Display(200);
- //状态27 逐步顺时针点亮P2、P1的LED,熄灭后,再顺时针点亮P0、P3的LED
- void disp27()
- LED_P0=0xff; LED_P1=0xff; LED_P2=0xff; LED_P3=0xff;
- for(j=0;j<2;j++)
- for(i=0;i<8;i++)
- LED_P2=table3[i];
- LED_P1=table3[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P0=table3[i];
- LED_P3=table3[i];
- Display(100);
- //状态28 P1、P2和P0、P3交替闪烁
- void disp28()
- for(i=0;i<2;i++)
- LED_P1=0x00; LED_P2=0x00; LED_P0=0xff; LED_P3=0xff;
- Display(1000);
- LED_P1=0xff; LED_P2=0xff; LED_P0=0x00; LED_P3=0x00;
- Display(1000);
- LED_P1=0xff; LED_P2=0xff; LED_P0=0xff; LED_P3=0xff;
- //状态29 逐步顺时针点亮P2、P1的LED,再顺时熄灭后,再顺时针点亮P0、P3的LED,再顺时熄灭
- void disp29()
- for(j=0;j<2;j++)
- for(i=0;i<8;i++)
- LED_P2=table3[i];
- LED_P1=table3[i];
- Display(100);
- for(i=0;i<9;i++)
- LED_P2=table5[i];
- LED_P1=table5[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P0=table3[i];
- LED_P3=table3[i];
- Display(100);
- for(i=0;i<9;i++)
- LED_P0=table5[i];
- LED_P3=table5[i];
- Display(100);
- Display(200);
- //状态30 逐步逆时针点亮P2、P1的LED,熄灭后,再逆时针点亮P0、P3的LED
- void disp30()
- for(j=0;j<2;j++)
- for(i=0;i<8;i++)
- LED_P2=table2[i];
- LED_P1=table2[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P0=table2[i];
- LED_P3=table2[i];
- Display(100);
- //状态31 逐步逆时针点亮P2、P1的LED,再逆时熄灭后,再逆时针点亮P0、P3的LED,再逆时熄灭
- void disp31()
- for(j=0;j<2;j++)
- for(i=0;i<8;i++)
- LED_P2=table2[i];
- LED_P1=table2[i];
- Display(100);
- for(i=0;i<9;i++)
- LED_P2=table4[i];
- LED_P1=table4[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P0=table2[i];
- LED_P3=table2[i];
- Display(100);
- for(i=0;i<9;i++)
- LED_P0=table4[i];
- LED_P3=table4[i];
- Display(100);
- Display(200);
- //状态32 LED自上而下逐步点亮,然后从下往上逐步熄灭
- void disp32()
- for(i=0;i<8;i++)
- LED_P0=table2[i];
- LED_P2=table3[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P1=table2[i];
- LED_P3=table3[i];
- Display(100);
- for(i=0;i<9;i++)
- LED_P1=table5[i];
- LED_P3=table4[i];
- Display(100);
- for(i=0;i<9;i++)
- LED_P0=table5[i];
- LED_P2=table4[i];
- Display(100);
- //状态33 LED从左往右开始点亮(直到全亮),然后从左右两边开始熄灭(直到全部熄灭)
- void disp33()
- for(i=0;i<8;i++)
- LED_P0=table3[i];
- LED_P1=table2[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P2=table3[i];
- LED_P3=table2[i];
- Display(100);
- Display(500);
- for(i=0;i<9;i++)
- LED_P2=table4[i];
- LED_P3=table5[i];
- LED_P1=table4[i];
- LED_P0=table5[i];
- Display(100);
- Display(300);
- //状态34 LED从左往右开始点亮(直到全亮),然后从中间往左右边熄灭
- void disp34()
- for(i=0;i<8;i++)
- LED_P2=table2[i];
- LED_P3=table3[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P0=table2[i];
- LED_P1=table3[i];
- Display(100);
- Display(500);
- for(i=0;i<9;i++)
- LED_P2=table5[i];
- LED_P3=table4[i];
- LED_P1=table5[i];
- LED_P0=table4[i];
- Display(100);
- Display(300);
- //状态35 从P2.7、P1.7开始同时顺时针旋转,直到LED全亮
- void disp35()
- for(i=0;i<8;i++)
- LED_P2=table3[i];
- LED_P1=table3[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P3=table3[i];
- LED_P0=table3[i];
- Display(100);
- //状态36 从P0.7、P3.1开始同时逆时针旋转,直到LED全亮
- void disp36()
- for(i=0;i<8;i++)
- LED_P0=table2[i];
- LED_P3=table2[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P1=table2[i];
- LED_P2=table2[i];
- Display(100);
- //状态37 2个LED自上而下移动,并点亮最下2个LED,然后2个LED再自下而上回去,同时4个LED(上下各2个LED)再来回移动一次
- void disp37()
- for(i=0;i<8;i++)
- LED_P0=table0[i];
- LED_P2=table1[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P1=table0[i];
- LED_P3=table1[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P1=table7[i];
- LED_P3=table6[i];
- Display(100);
- LED_P1=0x7f; LED_P3=0xfe;
- for(i=0;i<8;i++)
- LED_P0=table1[i];
- LED_P2=table0[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P0=table0[i];
- LED_P2=table1[i];
- LED_P1=table1[i];
- LED_P3=table0[i];
- Display(200);
- for(i=0;i<8;i++)
- LED_P0=table1[i];
- LED_P1=table0[i];
- LED_P2=table0[i];
- LED_P3=table1[i];
- Display(200);
- LED_P0=0xff;LED_P1=0xff; LED_P2=0xff;LED_P3=0xff;
- //状态38 逐步顺时针点亮P2、P1的LED,熄灭后,再顺时针点亮P0、P3的LED
- void disp38()
- for(j=0;j<2;j++)
- for(i=0;i<8;i++)
- LED_P2=table3[i];
- LED_P1=table3[i];
- Display(100);
- for(i=0;i<8;i++)
- LED_P0=table3[i];
- LED_P3=table3[i];
- Display(100);
- //状态39 P1、P3LED(下半部分)一直亮,上半部分LED向外扩张亮,然后闪烁3次
- void disp39()
心形花样流水灯.zip
(408.8 KB, 下载次数: 32)
