有没有大佬能不能帮我把这个接地才能用的矩阵按键改成上拉电阻可用的!
- #include "key4_4.h"
- #include "delay.h"
- #include "sys.h"
- //平台:STM32F103
- //实验名称:不连续I/O矩阵键盘实验
- //Author:GXNU_LPK_20512700***
- //使用说明:矩阵键盘所用引脚都已经用宏定义定义好了,移植只需根据实际需要在key4_4.c中修改对应的时钟、引脚和端口即可,其余都不用修改。
- //矩阵键盘所用的8个引脚可连续可不连续,看实际需要和个人爱好自己定义。
- int main(void)
- uart_init(9600);
- Key_Init();
- delay_init();
- printf("不连续I/O口矩阵键盘测试\r\n");
- while(1)
- Key_Test();
复制代码- #include "key4_4.h"
- #include "sys.h"
- //8个引脚 4个为行 4个为列
- //行输出端口定义
- #define X1_GPIO_PORT GPIOA
- #define X2_GPIO_PORT GPIOA
- #define X3_GPIO_PORT GPIOA
- #define X4_GPIO_PORT GPIOB
- //列输入端口定义
- #define Y1_GPIO_PORT GPIOB
- #define Y2_GPIO_PORT GPIOB
- #define Y3_GPIO_PORT GPIOB
- #define Y4_GPIO_PORT GPIOB
- //行输出引脚定义
- #define X1_GPIO_PIN GPIO_Pin_11
- #define X2_GPIO_PIN GPIO_Pin_12
- #define X3_GPIO_PIN GPIO_Pin_15
- #define X4_GPIO_PIN GPIO_Pin_3
- //列输入引脚定义
- #define Y1_GPIO_PIN GPIO_Pin_4
- #define Y2_GPIO_PIN GPIO_Pin_5
- #define Y3_GPIO_PIN GPIO_Pin_6
- #define Y4_GPIO_PIN GPIO_Pin_7
- //行输出时钟定义
- #define X1_RCC RCC_APB2Periph_GPIOA
- #define X2_RCC RCC_APB2Periph_GPIOA
- #define X3_RCC RCC_APB2Periph_GPIOA
- #define X4_RCC RCC_APB2Periph_GPIOB
- //列输入时钟定义
- #define Y1_RCC RCC_APB2Periph_GPIOB
- #define Y2_RCC RCC_APB2Periph_GPIOB
- #define Y3_RCC RCC_APB2Periph_GPIOB
- #define Y4_RCC RCC_APB2Periph_GPIOB
- //移植代码只需要修改上面的端口和引脚和时钟即可,下面的代码不用修改。
- unsigned char Y1,Y2,Y3,Y4;
- void Key_Init(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(X1_RCC|X2_RCC|X3_RCC|X4_RCC|Y1_RCC|Y2_RCC|Y3_RCC|Y4_RCC|RCC_APB2Periph_AFIO, ENABLE);
- GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
- /*****************************4行输出*********************************************/
- GPIO_InitStructure.GPIO_Pin = X1_GPIO_PIN ;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(X1_GPIO_PORT, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = X2_GPIO_PIN ;
- GPIO_Init(X2_GPIO_PORT, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = X3_GPIO_PIN ;
- GPIO_Init(X3_GPIO_PORT, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = X4_GPIO_PIN ;
- GPIO_Init(X4_GPIO_PORT, &GPIO_InitStructure);
- /**************************************4列输入*************************************/
- GPIO_InitStructure.GPIO_Pin = Y1_GPIO_PIN ;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
- GPIO_Init(Y1_GPIO_PORT, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = Y2_GPIO_PIN ;
- GPIO_Init(Y2_GPIO_PORT, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = Y3_GPIO_PIN ;
- GPIO_Init(Y3_GPIO_PORT, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = Y4_GPIO_PIN;
- GPIO_Init(Y4_GPIO_PORT, &GPIO_InitStructure);
- int Key_Scan(void)
- uchar KeyVal;
- GPIO_SetBits(X1_GPIO_PORT,X1_GPIO_PIN); //先让X1输出高
- GPIO_SetBits(X2_GPIO_PORT,X2_GPIO_PIN); //先让X2输出高
- GPIO_SetBits(X3_GPIO_PORT,X3_GPIO_PIN); //先让X3输出高
- GPIO_SetBits(X4_GPIO_PORT,X4_GPIO_PIN); //先让X4输出高
- if((GPIO_ReadInputDataBit(Y1_GPIO_PORT,Y1_GPIO_PIN)|GPIO_ReadInputDataBit(Y2_GPIO_PORT,Y2_GPIO_PIN)|GPIO_ReadInputDataBit(Y3_GPIO_PORT,Y3_GPIO_PIN)|GPIO_ReadInputDataBit(Y4_GPIO_PORT,Y4_GPIO_PIN))==0x0000)
- return -1; //如果X1到X4全为零则没有按键按下
- else
- delay_ms(5); //延时5ms去抖动
- return -1;
- GPIO_ResetBits(X1_GPIO_PORT,X1_GPIO_PIN);
- GPIO_ResetBits(X2_GPIO_PORT,X2_GPIO_PIN);
- GPIO_ResetBits(X3_GPIO_PORT,X3_GPIO_PIN);
- Y1=GPIO_ReadInputDataBit(Y1_GPIO_PORT,Y1_GPIO_PIN);Y2=GPIO_ReadInputDataBit(Y2_GPIO_PORT,Y2_GPIO_PIN);
- Y3=GPIO_ReadInputDataBit(Y3_GPIO_PORT,Y3_GPIO_PIN);Y4=GPIO_ReadInputDataBit(Y4_GPIO_PORT,Y4_GPIO_PIN);
- if(Y1==1&&Y2==0&&Y3==0&&Y4==0)
- KeyVal='*';
- if(Y1==0&&Y2==1&&Y3==0&&Y4==0)
- KeyVal=0;
- if(Y1==0&&Y2==0&&Y3==0&&Y4==1)
- KeyVal='D';
- if(Y1==0&&Y2==0&&Y3==1&&Y4==0)
- KeyVal='#';
- while(((GPIO_ReadInputDataBit(Y1_GPIO_PORT,Y1_GPIO_PIN))|(GPIO_ReadInputDataBit(Y2_GPIO_PORT,Y2_GPIO_PIN))|(GPIO_ReadInputDataBit(Y3_GPIO_PORT,Y3_GPIO_PIN))|(GPIO_ReadInputDataBit(Y4_GPIO_PORT,Y4_GPIO_PIN))) > 0);
- //等待按键释放
- GPIO_ResetBits(X4_GPIO_PORT,X4_GPIO_PIN);
- KeyVal=1;
- KeyVal=2;
- KeyVal=3;
- KeyVal='A';
- KeyVal=4;
- KeyVal=5;
- KeyVal=6;
- KeyVal='B';
- KeyVal=7;
- KeyVal=8;
- KeyVal=9;
- KeyVal='C';
- return KeyVal;
- 按键表盘为: 1 2 3 A
- 4 5 6 B
- 7 8 9 C
- * 0 # D
- void Key_Test(void)
- int num;
- num = Key_Scan();
- switch(num)
- case 0: printf("0\n"); break;
- case 1: printf("1\n"); break;
- case 2: printf("2\n"); break;
- case 3: printf("3\n"); break;
- case 4: printf("4\n"); break;
- case 5: printf("5\n"); break;
- case 6: printf("6\n"); break;
- case 7: printf("7\n"); break;
- case 8: printf("8\n"); break;
- case 9: printf("9\n"); break;
- case 'A': printf("A\n"); break;
- case 'B': printf("B\n"); break;
- case 'C': printf("C\n"); break;
- case 'D': printf("D\n"); break;
- case '#': printf("#\n"); break;
- case '*': printf("*\n"); break;
可移植的不连续IO口矩阵键盘(接地).7z
(214.93 KB, 下载次数: 8)
