第一次弄 也不怎么会 哈哈哈哈
用ad弄得仿真图 也不怎么会弄....
电路原理图如下:
- #include<reg52.h> //包含头文件,一般情况不需要改动,头文件包含特殊功能寄存器的定义
- #include<stdio.h>
- #include "18b20.h"
- #include "1602.h"
- #include "delay.h"
- #define SETDOWN 0x01
- #define SETUP 0x02
- sbit key1=P2^0; //引脚定义
- sbit key2=P2^1;
- sbit key3=P2^2;
- sbit relay_jiare=P1^0;
- sbit relay_zhileng=P1^1;
- sbit buzzer=P1^4;
- unsigned int setL= 20; //上限
- unsigned int setH= 50; //下限
- unsigned char DisFlag=0; //更新显示标志
- unsigned char SetFlag=0; //设置参数标志
- unsigned long time2ms=0; //定时计数
- unsigned int buzLater=0; //蜂鸣器计时报
- int temp1; //读取温度初始值
- float temperature; //实际温度值
- unsigned char ReadTempFlag=0;//定义读时间标志
- char dis0[16];//定义显示区域临时存储数组
- char dis1[16];//定义显示区域临时存储数组
- unsigned char Num=0; //计数
- void CheckKey(void);
- void Init_Timer0(void);//定时器初始化
- void main (void)
- relay_jiare=0;
- relay_zhileng=0;
- buzzer=0;
- Init_Timer0();
- LCD_Init(); //初始化液晶
- DelayMs(200); //延时有助于稳定
- LCD_Clear(); //清屏
- relay_jiare=1;
- relay_zhileng=1;
- buzzer=1;
- while (1) //主循环
- CheckKey(); //检测按键
- if(ReadTempFlag==1) //读取温度标志
- ReadTempFlag=0;
- temp1=ReadTemperature(); //读取温度
- temperature=(float)temp1*0.0625; //温度值转换
- if(DisFlag==1)
- DisFlag=0;
- if((temperature>0)&&(temperature<150))
- sprintf(dis0,"Temp:%4.1f C",temperature);//打印温度值
- LCD_Write_String(0,0,dis0);//显示第二行
- LCD_Write_Char(9,0,0xdf);//写入温度右上角点
- if(temperature<setL) //温度过低
- relay_jiare=0; //开启升温 关闭降温
- relay_zhileng=1;
- else if((temperature)>setH) //温度超高
- relay_jiare=1; //关闭升温 开启降温
- relay_zhileng=0;
- else //正常温度
- relay_jiare=1; //关闭升温 关闭降温
- relay_zhileng=1;
- buzLater=0;
- if(buzLater>=60)//正常清零 否则过高过低都会累加 超过1min
- {buzzer=0;} //打开蜂鸣器
- else
- {buzzer=1;} //关闭蜂鸣器
- sprintf(dis1," %02d-- %02d ",setL,setH);
- LCD_Write_String(0,1,dis1); //初始化显示
- if(SetFlag == 0)//按键设置标志
- LCD_Write_Char(0,1,' ');LCD_Write_Char(5,1,' ');//更新显示标志
- else if(SetFlag == 1)//按键设置标志
- LCD_Write_Char(0,1,'S');LCD_Write_Char(5,1,' ');//更新显示标志
- else if(SetFlag == 2)//按键设置标志
- LCD_Write_Char(0,1,' ');LCD_Write_Char(5,1,'S');//更新显示标志
- static unsigned char rekey =0;
- if((key1==0)||(key2==0)||(key3==0)) //检测到按键按下
- DelayMs(10); //小抖动
- if(rekey==0)
- if(key1==0) //检测是否按下
- rekey=1;
- SetFlag++;//设置标志
- if(SetFlag >= 3) SetFlag = 0;
- else if(key2==0)//设置值键
- rekey=1;
- if(SetFlag==1) //处于设置1
- if(setL > 0 )
- {setL=setL-1;}
- else if(SetFlag==2)//处于设置2
- if(setH > 0)
- {setH=setH-1;}
- else if(key3==0)//设置值键
- rekey=1;
- if(setL < 99 )
- {setL=setL+1;}
- if(setH < 99 )
- {setH=setH+1;}
- else
- rekey=0; //防止重复检测到按键
- 定时器初始化子程序
- TMOD |= 0x01; //使用模式1,16位定时器,使用"|"符号可以在使用多个定时器时不受影响
- //TH0=0x00; //给定初值
- //TL0=0x00;
- EA=1; //总中断打开
- ET0=1; //定时器中断打开
- TR0=1; //定时器开关打开
- 定时器中断子程序
- void Timer0_isr(void) interrupt 1
- TH0=(65536-20000)/256; //重新赋值 20ms
- TL0=(65536-20000)%256;
- time2ms++;
- if(time2ms%10==0) //更新显示
- DisFlag=1;
- if(time2ms%50==0) //读取温度
- ReadTempFlag=1; //读标志位置1
- if(buzLater<200)buzLater++;
Desktop.rar
(73.5 KB, 下载次数: 53)
