自己做的一个proteus仿真的51单片机开发板,有完整的试验步骤和仿真工程文件提供
板子上带扩展ROM空间(i^2c 24c02)、adc(数字电压表)、dac(信号发生器)、矩形按键(计算器),四个任务通过独立按键进行切换
下面是基于DAC0832芯片信号发生器(1602液晶显示)部分的的单片机源程序
完整代码和仿真工程文件请下载http://www.51hei.com/bbs/dpj-91558-1.html
- #include <reg51.h>
- #include<string.h>
- #define uchar unsigned char
- #define uint unsigned int
- //--LCD????
- sbit RS=P2^6;
- sbit RW=P2^5;
- sbit EN=P2^7;
- sbit K1=P2^2;
- sbit K2=P2^3;
- sbit K3=P2^4;
- sbit K4=P3^6;
- sbit K5=P3^7;
- //sbit key=P3^4;
- uchar WaveChoice=1;
- uchar ys=30;
- uchar i1,b1=0;
- uchar sqar_num=128;
- uint freq;
- uchar code Sin[]={"Sine "};
- //uchar code exp[]={"Exp "};
- uchar code Squ[]={"Square "} ;
- uchar code Tri[]={"Triangle "};
- uchar code Saw[]={"Sawtooth "} ;
- uchar code No[]={"No Signal out "};
- uchar code Wave[]={"Wave :"};
- uchar code Fre[]={"Freq :"};
- uchar code tosin[256]=
- {0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,
- 0xae,0xb1,0xb4,0xb7,0xba,0xbc,0xbf,0xc2,0xc5,0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd6,0xd8,
- 0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,0xee,0xef,0xf1,0xf2,0xf4,
- 0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,
- 0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,
- 0xf4,0xf2,0xf1,0xef,0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,0xd8,
- 0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,0xbf,0xbc,0xba,0xb7,0xb4,0xb1,0xae,0xab,
- 0xa8,0xa5,0xa2,0x9f,0x9c,0x99,0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,
- 0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,
- 0x51,0x4e,0x4c,0x48,0x45,0x43,0x40,0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b,
- 0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16,0x15,0x13,0x11,0x10,0x0e,
- 0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02 ,0x02,0x03,0x04,
- 0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,0x11,0x13,0x15,0x16,0x18,
- 0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,
- 0x3d,0x40,0x43,0x45,0x48,0x4c,0x4e ,0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66 ,
- 0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80 }; //????
- //--??MS
- void DelayMS(uchar ms)
- uchar i;
- while(ms--) for(i=0;i<120;i++);
- //--??y*9us
- void Delay1(uint y)
- uint i;
- for(i=y;i>0;i--);
- uchar Busy_Check()
- uchar LCD_Status;
- RS=0; // ?????
- RW=1; //??????
- EN=1; // ???
- DelayMS(1);
- // LCD_Status=P1;
- LCD_Status=P0;
- EN=0;
- return LCD_Status;
- //?LCD??
- void Write_LCD_Command(uchar cmd)
- while((Busy_Check()&0x80)==0x80); //???
- RS=0; //???????
- RW=0; //?
- EN=0;
- // P1=cmd;
- P0=cmd;
- EN=1;DelayMS(1);EN=0;
- void Write_LCD_Data(uchar dat)
- RS=1; RW=0; EN=0;
- // P1=dat;
- P0=dat;
- //LCD???
- void Init_LCD()
- Write_LCD_Command(0x38);
- DelayMS(1);
- Write_LCD_Command(0x01); //??
- DelayMS(1);
- Write_LCD_Command(0x06); //??????:????,????
- DelayMS(1);
- Write_LCD_Command(0x0C); //???????
- DelayMS(1);
- //--?LCD????
- void Write_freq(uint k)
- uchar qian,bai,shi,ge;
- qian=k/1000;
- bai=k/100%10;
- shi=k/10%10;
- ge=k%10;
- Write_LCD_Command(0x86+0x40);
- Write_LCD_Data(0x30+qian);
- Write_LCD_Data(0x30+bai);
- Write_LCD_Data(0x30+shi);
- Write_LCD_Data(0x30+ge);
- Write_LCD_Data(0x48);
- Write_LCD_Data(0x5a);
- //--LCD?????????
- void Xianshi_f()
- if(WaveChoice==1)
- freq=(10000000/(50000+2860*ys));
- Write_freq(freq);
- if(WaveChoice==2)
- freq=(10000000/(50000+2300*ys));
- Write_freq(freq);
- if(WaveChoice==3)
- freq=(10000000/(14000+2300*ys));
- Write_freq(freq);
- if(WaveChoice==4)
- freq=(10000000/(15000+2300*ys));
- Write_freq(freq);
- //--LCD??????
- void Write_wave(uchar t )
- switch(t)
- case 0:
- Write_LCD_Command(0x86);
- DelayMS(5);
- for (i1=0;i1<sizeof(No)-1;i1++)
- Write_LCD_Data(No[i1]);
- DelayMS(5);
- break;
- case 1:
- ys=25;
- DelayMS(5);
- for (i1=0;i1<sizeof(Sin)-1;i1++)
- Write_LCD_Data(Sin[i1]);
- DelayMS(5);
- break;
- case 2:
- ys=30;
- DelayMS(5);
- for (i1=0;i1<sizeof(Squ)-1;i1++)
- Write_LCD_Data(Squ[i1]);
- DelayMS(5);
- break;
- case 3:
- ys=30;
- DelayMS(5);
- for (i1=0;i1<sizeof(Tri)-1;i1++)
- Write_LCD_Data(Tri[i1]);
- DelayMS(5);
- break;
- case 4:
- ys=30;
- Write_LCD_Command(0x86);//??????
- DelayMS(5);
- for (i1=0;i1<sizeof(Saw)-1;i1++)
- Write_LCD_Data(Saw[i1]);
- DelayMS(5);
- break;
- void Out_Wave(uchar i)
- { uchar j;
- switch(i)
- // case 0: P0=0x00;break;
- case 0: P1=0x00;break;
- case 1:
- for (j=0;j<255;j++)
- // P0=tosin[j];
- P1=tosin[j];
- Delay1(ys);
- break;
- case 2:
- if(b1<sqar_num)
- // P0=0xff;
- P1=0xff;
- Delay1(ys);
- else
- // P0=0x00;
- P1=0x00;
- Delay1(ys);
- b1++;
- } break;
- case 3:
- if(b1<128)
- // P0=a;
- P1=b1;
- Delay1(ys);
- else
- // P0=255-a;
- P1=255-b1;
- Delay1(ys);
- b1++;
- } break;
- case 4:
- if(b1<255)
- // P0=a;
- P1=b1;
- Delay1(ys);
- b1++;
- if(b1==255)
- b1=0;
- } break;
- void keyscanf()
- if(K2==0)
- DelayMS(5);
- if(K2==0)
- while(!K2);
- ys--;
- if(ys==0)
- ys=20;
- if(K3==0)
- DelayMS(5);
- if(K3==0)
- while(!K3);
- ys++;
- if(ys>22)
- ys=20;
- if(K4==0)
- DelayMS(5);
- if(K4==0)
- while(!K4);
- if(WaveChoice==2)
- sqar_num=sqar_num+2;
- if(sqar_num==238)
- sqar_num=128;
- if(K5==0)
- DelayMS(5);
- if(K5==0)
- while(!K5);
- if(WaveChoice==2)
- sqar_num=sqar_num-2;
- if(sqar_num==18)
- sqar_num=128;
- void xinhao()
- Init_LCD();
- IE=0X81;
- IT0=1;
- Write_LCD_Command(0x80);//--??wave:
- DelayMS(5);
- for (i1=0;i1<sizeof(Wave)-1;i1++)
- Write_LCD_Data(Wave[i1]);
- DelayMS(5);
- Write_LCD_Command(0x80+0X40);//----??freq:
- DelayMS(5);
- for (i1=0;i1<sizeof(Fre)-1;i1++)
- Write_LCD_Data(Fre[i1]);
- DelayMS(5);
- Write_wave(WaveChoice);
- while (1)
- keyscanf();
- Out_Wave(WaveChoice);
- if(!(K1&K2&K3))
- Xianshi_f();
- //---INT0??
- void EX_INT0() interrupt 0
- WaveChoice++;
- if(WaveChoice==5) WaveChoice=1;
