查看: 975|回复: 0
程序运行,单片机数码管一直不亮,能不能帮忙改一下程序 求帮助
ID:566055 发表于 2019-6-18 19:18 | 显示全部楼层 |阅读模式
#include<reg52.h>
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={0x3f, 0x06, 0x5b, 0x4f,
                   0x66, 0x6d, 0x7d, 0x07,
                   0x7f, 0x6f, 0x77, 0x7c,
                   0x39, 0x5e, 0x79, 0x71};
uchar num1,num2,shi,ge;
void delayms(uint xms)
uint i,j;
for(i=xms;i>0;i--)
   for(j=110;j>0;j--);
void display1(uchar m)
wela=1;
P0=0xfe;
wela=0;
dula=1;
P0=table[m];
dula=0;
delayms(5);
void display(uchar shi,uchar ge)
wela=1;
P0=0xfd;
wela=0;
dula=1;
P0=table[shi];
dula=0;
P0=0xff;
delayms(5);
wela=1;
P0=0xfe;
wela=0;
dula=1;
P0=table[ge];
dula=0;
P0=0xff;
delayms(5);
uchar temp, key;
TMOD=0x01;
EA=1;
ET0=1;
TH0=(65536-9174)/256;
TL0=(65536-9174)%256;
  P3=0xfe;
   temp=P3;
   temp=temp&0xf0;
if(temp!=0xf0)
  delayms(10);
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
   delayms(10);
   temp=P3;
   switch(temp)
    case 0xee: key=1;
               break;
    case 0xde: key=2;
               break;
    case 0xbe: key=3;
               break;
    case 0x7e: key=4;
               break;
   while(temp!=0xfe)
    delayms(5);
    TR0=1;
   while(num1<1000&&TR0==1)
      display1(key);
     delayms(10);
     display1(0);
     display(shi,ge);
   if(num1==1000)
    num1=0;
    TR0=0;
    display1(0);
void  T0_time() interrupt 1
uchar num1, num2;
num1++;
ge=num2%10;
shi=num2/10;
if(num1==100)
  num1=0;
  num2++;
  if(num2==10)
   num2=0;
   num1=0;
