#include<reg51.h>
#include<intrins.h>
#include <ctype.h>
#include <stdlib.h>
#define LCD_DATA P0
sbit LCD_RS = P2^0;
sbit LCD_RW = P2^1;
sbit LCD_EN = P2^2;
unsigned char dispBuff0[16]={'S','E','T',':',' ','.',' ','V',' ',' ',' ','s',' ',' ',' ',};
unsigned char dispBuff1[16]={'T','E','M','P',':',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',};
unsigned char dispBuff2[4]={' ',' ',' ',' ',};
unsigned char dispBuff3[16]={' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',};
unsigned char dispBuff4[16]={'I','N','P','U','T',' ','4','W','E','I',' ','M','I','M','A',};
unsigned char dispBuff5[16]={' ',' ',' ','M','I','M','A',' ','E','R','R','O','R',' ',' ',};
sbit DQ=P2^3;
unsigned int temperature=0;
unsigned int fuhao=0;
sbit LED1=P1^1;
#define off 1
#define on 0
sbit speaker=P1^0;
void Delay20ms() ;
void LCD_WriteDat(unsigned char lcd_dat);
void LCD_WriteCmd(unsigned char lcd_cmd);
unsigned char LCD_ReadStatus(void);
void LCD_Goto(unsigned char x,unsigned char y);
void LCD_Display(unsigned char row,unsigned char *str);
void delay(unsigned int x)
unsigned char j;
while(x--)
for(j=0;j<125;j++);
void delay1(unsigned int x)
while(--x);
char keyscan()
char skey;
P3 = 0xfe;
while((P3 & 0xf0) != 0xf0)
delay(10);
switch(P3)
case 0xee: skey = '7'; break;
case 0xde: skey = '8'; break;
case 0xbe: skey = '9'; break;
case 0x7e: skey = '+'; break;
while((P3 & 0xf0) != 0xf0);
P3 = 0xfd;
delay(10);
switch(P3)
case 0xed: skey = '4'; break;
case 0xdd: skey = '5'; break;
case 0xbd: skey = '6'; break;
case 0x7d: skey = '-'; break;
P3 = 0xfb;
delay(10);
switch(P3)
case 0xeb: skey = '1'; break;
case 0xdb: skey = '2'; break;
case 0xbb: skey = '3'; break;
case 0x7b: skey = '.'; break;
P3 = 0xf7;
delay(10);
switch(P3)
case 0xe7: skey = '&'; break;
case 0xd7: skey = '0'; break;
case 0xb7: skey = '*'; break;
case 0x77: skey = '#'; break;
return skey;
void Delay20ms()
unsigned int tmp = 50000;
while(tmp--);
void LCD_Init(void)
Delay20ms();
LCD_WriteCmd(0x38);
LCD_WriteCmd(0x0c);
LCD_WriteCmd(0x01);
LCD_WriteCmd(0x06);
LCD_Goto(0,0);
unsigned char tmp;
tmp = LCD_ReadStatus();
while((tmp & 0x80))
LCD_RS = 1;
LCD_RW = 0;
LCD_DATA = lcd_dat;
_nop_();
LCD_EN = 0;
_nop_();
_nop_();
LCD_EN = 1;
unsigned char tmp;
while((tmp & 0x80))
LCD_RS = 0;
LCD_RW = 0;
LCD_DATA = lcd_cmd;
_nop_();
LCD_EN = 0;
_nop_();
_nop_();
LCD_EN = 1;
unsigned char tmp;
#if 0
LCD_RS = 0;
LCD_RW = 1;
LCD_EN = 1;
tmp = LCD_DATA;
LCD_EN = 0;
#endif
LCD_DATA = 0xff;
LCD_RS = 0;
LCD_RW = 1;
LCD_EN = 0;
_nop_();
_nop_();
LCD_EN = 1;
tmp = LCD_DATA;
return tmp;
unsigned char tmp;
if(y)
tmp = 0xc0 + x;
LCD_WriteCmd(tmp);
tmp = 0x80 + x;
LCD_WriteCmd(tmp);
if(row)
LCD_Goto(0,1);
LCD_Goto(0,0);
while(*str != '\0')
LCD_WriteDat(*str++);
int Init_DS18B20()
unsigned char x=0;
DQ = 1;
delay1(1);
DQ = 0;
delay1(30);
DQ = 1;
delay1(5);
if(DQ==1)
x=0;
x=1;
delay1(30);
return x;
unsigned char ReadOneChar(void)
unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
DQ=1;
_nop_();
_nop_();
_nop_();
DQ = 0;
dat>>=1;
delay(1);
DQ = 1;
delay(2);
if(DQ)
dat|=0x80;
delay(5);
return(dat);
void WriteOneChar(unsigned char dat)
unsigned char i=0;
for (i=8; i>0; i--)
DQ = 1;
_nop_();
_nop_();
_nop_();
DQ = 0;
DQ = dat&0x01;
delay(2);
dat>>=1;
void ReadTemperature(void)
{ unsigned char readdata[2]={0,0};
fuhao=0;
temperature=0;
delay(40);
if(Init_DS18B20()==1)
WriteOneChar(0xCC);
WriteOneChar(0x44);
delay1(30);
WriteOneChar(0xCC);
WriteOneChar(0xBE);
delay1(30);
readdata[0]=ReadOneChar();
readdata[1]=ReadOneChar();
readdata[1]<<=8;
if (readdata[1]>127)
readdata[0]^=0xff;
readdata[1]^=0xff;
fuhao=1;
temperature =readdata[1]*256+readdata[0] ;
temperature =temperature*0.625+0.5;
void set()
int i;
char ckey;
ckey=keyscan();
if(ckey=='#')
delay(10);
i=1;
{ ckey=keyscan();
if(isdigit(ckey)&&i==1)
dispBuff2[0]=ckey;
i=0;
dispBuff0[4]=dispBuff2[0];
LCD_Display(0,dispBuff0);
else if(isdigit(ckey)&&i==0)
dispBuff2[1]=ckey;
dispBuff0[6]=dispBuff2[1];
break;
delay(800);
if(ckey=='*')
delay(10);
i=1;
{ ckey=keyscan();
dispBuff2[2]=ckey;
i=0;
dispBuff0[9]=dispBuff2[2];
dispBuff2[3]=ckey;
dispBuff0[10]=dispBuff2[3];
break;
delay(800);
int mima()
int i,a;
char ckey;
LCD_Display(0,dispBuff4);
ckey=keyscan();
if(ckey=='&')
delay(10);
i=0;
ckey=keyscan();
dispBuff2[0]=ckey;
i=1;
dispBuff3[6]=dispBuff2[0];
LCD_Display(1,dispBuff3);
else if(isdigit(ckey)&&i==1)
dispBuff2[1]=ckey;
i=2;
dispBuff3[7]=dispBuff2[1];
else if(isdigit(ckey)&&i==2)
dispBuff2[2]=ckey;
i=3;
dispBuff3[8]=dispBuff2[2];
else if(isdigit(ckey)&&i==3)
dispBuff2[3]=ckey;
i=4;
dispBuff3[9]=dispBuff2[3];
break;
delay(800);
a=(dispBuff2[0]-'0')*1000+(dispBuff2[1]-'0')*100+(dispBuff2[2]-'0')*10+(dispBuff2[3]-'0');
return a;
void timer0() interrupt 1
{ TH0=254;
TL0=200;
speaker=!speaker;
int a,b,d;
float c;
LCD_Init();
TMOD=0x11;
TH0=254;
TL0=200;
ET0=1;
EA=1;
speaker=1;
m:d=mima();
if(d==1234)
{ while(1)
delay(10);
set();
ReadTemperature();
if (fuhao)
dispBuff1[5]='-';
dispBuff1[5]='+';
dispBuff1[6]=(temperature/1000)%10+'0';
dispBuff1[7]=(temperature/100)%10+'0';
dispBuff1[8]=(temperature/10)%10+'0';
dispBuff1[9]='.';
dispBuff1[10]=(temperature)%10+'0';
LCD_Display(1,dispBuff1);
a=dispBuff0[4]-'0';
b=dispBuff0[6]-'0';
c=a+b*0.1;
delay(20);
if (temperature>=c*510 && !fuhao)
LED1=on;
LED1=off;
TR0=1;
TR0=0;
LCD_Display(1,dispBuff5);
goto m;
