N76E003 uart 参考代码:
- #include "N76E003.h"
- #include "Common.h"
- #include "Delay.h"
- #include "SFR_Macro.h"
- #include "Function_define.h"
- * FUNCTION_PURPOSE: Serial interrupt, echo received data.
- * FUNCTION_INPUTS : P0.7(RXD) serial input
- * FUNCTION_OUTPUTS: P0.6(TXD) serial output
- * Following setting in Common.c
- #if 0
- //void InitialUART0_Timer1(UINT32 u32Baudrate) //T1M = 1, SMOD = 1
- // P06_Quasi_Mode;
- // P07_Quasi_Mode;
- // SCON = 0x52; //UART0 Mode1,REN=1,TI=1
- // TMOD |= 0x20; //Timer1 Mode1
- // set_SMOD; //UART0 Double Rate Enable
- // set_T1M;
- // clr_BRCK; //Serial port 0 baud rate clock source = Timer1
- //#ifdef FOSC_160000
- // TH1 = 256 - (1000000/u32Baudrate+1); /*16 MHz */
- //#endif
- // set_TR1;
- //void InitialUART0_Timer3(UINT32 u32Baudrate) //use timer3 as Baudrate generator
- // T3CON &= 0xF8; //T3PS2=0,T3PS1=0,T3PS0=0(Prescale=1)
- // set_BRCK; //UART0 baud rate clock source = Timer3
- // RH3 = HIBYTE(65536 - (1000000/u32Baudrate)-1); /*16 MHz */
- // RL3 = LOBYTE(65536 - (1000000/u32Baudrate)-1); /*16 MHz */
- //#endif
- // set_TR3; //Trigger Timer3
- #endif
- * FUNCTION_PURPOSE: Main function
- void main (void)
- #if 0
- InitialUART0_Timer1(9600); //UART0 Baudrate initial,T1M=0,SMOD=0
- while(1)
- Send_Data_To_UART0(0x55);
- #else
- InitialUART0_Timer3(115200);
- while(1)
- #endif
全部资料51hei下载地址:
UART0.zip
(130.08 KB, 下载次数: 19)
