1黑币
#include <reg51.h>
#include <intrins.h>
sbit plus_10=P1^3; //对各个按钮进行位定义
sbit minus_10=P1^4;
sbit plus=P1^5;
sbit minus=P1^6;
sbit enter=P1^7;
sbit PWM_OUT1=P1^1;
sbit PWM_OUT2=P1^0;
sbit dir=P1^2;
struct PID //定义PID结构体
int SetValue; //设定值
// long SumError; //误差
double Proportion; //比例系数
double Integral; //积分系数
double Derivative; //微分系数
int LastError;
int PrevError;
}sPID,*sptr= &sPID;
int PWM,PWM_temp=1,count0=0,Speed_Set,Seep_Measure,counter_100ms,counter_10ms;
bit flag_100ms,flag_10ms,start,plus_10_lock=1,minus_10_lock=1,plus_lock=1,
minus_lock=1,enter_lock=1;
char num[] = {0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07, 0x7f, 0x6f};//0~9 对应数码
*函数名:void delayms(unsigned char x)
*函数功能:简单延时 支持0~255ms
*函数参数:x 延时时间
unsigned char i ;
while(x--)
for(i = 0 ; i < 120 ; i++) ;
*函数名:void display(void)
*函数功能:显示函数
*函数参数:无
void display(void)
P2 =0x7f; P0 = num[Speed_Set/100];delayms(2);
P2 =0xbf; P0 = num[Speed_Set % 100 / 10];delayms(2);
P2 =0xdf; P0 = num[Speed_Set % 10];delayms(2);
P2 =0xfb; P0 = num[Seep_Measure / 100];delayms(2);
P2 =0xfd; P0 = num[Seep_Measure % 100/10];delayms(2);
P2 =0xfe; P0 = num[Seep_Measure % 10]; delayms(2);
if(start&&dir)
P2=0xf7;P0=0x40;delayms(2);
*函数名:void keyscan(void)
*函数功能:按键扫描
*函数参数:无
void keyscan(void)
static unsigned char plus_10_delay,minus_10_delay,plus_delay,minus_delay,enter_delay;
if(plus_10==0)
if(plus_10_lock&&++plus_10_delay>=2)
plus_10_lock=0;
if(Speed_Set<170)
Speed_Set+=10;
else Speed_Set=10;
plus_10_lock=1;
plus_10_delay=0;
if(minus_10==0)
if(minus_10_lock&&++minus_10_delay>=2)
minus_10_lock=0;
if(Speed_Set>10)
Speed_Set-=10;
else Speed_Set=170;
minus_10_lock=1;
minus_10_delay=0;
if(plus==0)
if(plus_lock&&++plus_delay>2)
plus_lock=0;
if(Speed_Set<170)
Speed_Set+=1;
else Speed_Set=0;
plus_lock=1;
plus_delay=0;
if(minus==0)
if(minus_lock&&++minus_delay>2)
minus_lock=0;
if(Speed_Set>0)
Speed_Set-=1;
else Speed_Set=170;
minus_lock=1;
minus_delay=0;
if(enter==0)
if(enter_lock&&++enter_delay>2)
enter_lock=0;
sptr->SetValue =Speed_Set;
start=1;
enter_lock=1;
enter_delay=0;
*函数名:void timer0(void)
*函数功能:定时器0 中断函数
*函数参数:无
void timer0(void) interrupt 1
TH0=0xfc; //定时1ms
TL0=0x18;
if(++counter_100ms>=100)
counter_100ms=0;
flag_100ms=1;
if(++counter_10ms>=10)
flag_10ms=1;
counter_10ms=0;
if(PWM&&--PWM_temp==0)
PWM_OUT1=!PWM_OUT1;
if(PWM_OUT1) PWM_temp=PWM;
else PWM_temp=100-PWM; //PWM周期小于等于采样周期
*函数名:void EIRQ0(void)
*函数功能:外部中断0处理函数 记录脉冲个数
*函数参数:无
void EIRQ0(void) interrupt 0
count0++;
*函数名:viod PIDInit(void)
*函数功能:PID参数初始化
*函数参数:无
void PIDInit(void)
// sptr->SumError = 0;
sptr->LastError = 0; //Error[-1]
sptr->PrevError = 0; //Error[-2]
sptr->Proportion = 2.3; //比例系数
sptr->Integral = 1.2; //积分系数
sptr->Derivative = 0.1; //微分系数
sptr->SetValue = 0;
*函数名:int PID_Calc(int MeasureValue)
*函数功能:PID算法 调节PWM增量
*函数参数:MeasureValue 测得的速度值 PID_Adjust 返回值 PWM误差修正值
register int iError, PID_Adjust;
iError = sptr->SetValue - MeasureValue; //计算增加量
PID_Adjust = (int)(sptr->Proportion * iError //E[k]项
- sptr->Integral * sptr->LastError //E[k-1]项
+ sptr->Derivative * sptr->PrevError); //E[k-2]项
//存储当前误差以便后面计算
sptr->PrevError = sptr->LastError;
sptr->LastError = iError;
//返回增量值
return (PID_Adjust);
*函数名:void main(void)
*函数功能:主函数
*函数参数:无
void main(void)
TMOD=0x01;
TH0=0xfc;
TL0=0x18;
IT0=1;
EX0=1;
ET0=1;
TR0=1;
EA=1;
PWM_OUT1=0 ;
PWM_OUT2=0;
PIDInit();
if(flag_100ms) //100ms采集一次脉冲数
Seep_Measure=count0; //(600/600)*count0
count0=0;
flag_100ms=0;
if(start==1) //调整PWM
int PWM_PID;
PWM_PID=PID_Calc(Seep_Measure);
if((PWM+0.5*PWM_PID)<99&&(PWM+0.5*PWM_PID)>1) //防止调节比例过大 造成PWM值超出范围
PWM=PWM+0.5*PWM_PID; //0.5用于保证速度调整跨度过大时PWM不会过界
if(flag_10ms)
keyscan();
display();
flag_10ms=0;
