- #include<reg51.h> //51头文件
- #define uchar unsigned char
- #define uint unsigned int
- sbit s1=P3^2;
- sbit s2=P3^3;
- uchar k=0,p=0,delay=0;
- uchar bxxz=0;pinglv=0;
- uchar a=1,b=0,c=0,d=0;
- //正弦波数据
- uchar code sin[64]={
- 135,145,158,167,176,188,199,209,218,226,234,240,245,249,252,254,254,253,251,247,243,237,230,222,213,204,193,182,170,158,
- 146,133,121,108,96,84,72,61,50,41,32,24,17,11,7,3,1,0,0,2,5,9,14,20,28,36,45,55,66,78,90,102,114,128
- //方波数据报表
- uchar code juxing[64]={
- 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
- 255,255,255,255,255,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
- //锯齿波数据
- uchar code juchi[64]={
- 0,4,8,12,16,20,24,28,32,36,40,45,49,53,57,61,65,69,73,77,81,85,89,93,97,101,105,109,113,117,121,125,130,134,138,142,
- 146,150,154,158,162,166,170,174,178,182,186,190,194,198,202,206,210,215,219,223,227,231,235,239,243,247,251,255
- //三角波数据
- uchar code sanjiao[64]={
- 0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,144,152,160,168,176,184,192,200,208,216,224,232,240,248,
- 248,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0
- void delay1() //延时 ms级
- int a,b;
- for(a=1;a>0;a--)
- for(b=122;b>0;b--);
- void int0() interrupt 0 //外部中断0 P3.2 中断处理,用于波形切换
- EX0=0;
- delay1();
- if(s1==0)
- bxxz++;
- if(bxxz==4)
- bxxz=0;
- switch(bxxz)
- case 0 :
- {a=1,b=0,c=0,d=0;} //正弦波
- break;
- case 1 :
- {a=0,b=1,c=0,d=0;} //方波
- break;
- case 2 :
- {a=0,b=0,c=1,d=0;} //锯齿波
- break;
- case 3 :
- {a=0,b=0,c=0,d=1;} //三角波
- break;
- delay1();
- while(!s1);
- while(!s1);
- EX0=1;
- void int1() interrupt 2 //外部中断1 P3.3 中断处理,用于频率调节
- EX1=0;
- delay1();
- if(s2==0){
- p++;
- if(p==8)
- p=0;
- switch(p)
- case 1 :
- pinglv=4; //400Hz
- break;
- case 2 :
- pinglv=8; //250Hz
- break;
- case 3 :
- pinglv=16; //140Hz
- break;
- case 4 :
- pinglv=32; //75Hz
- break;
- case 5 :
- pinglv=64; //40Hz
- break;
- case 6 :
- pinglv=125; //20Hz
- break;
- case 7 :
- pinglv=255; //10Hz
- break;
- default :
- pinglv=0; //1000Hz
- break;
- delay1();
- while(!s2);
- while(!s2);
- EX1=1; //开中断
- void main()
- EA=1;
- IT0=1;
- EX0=1;
- IT1=1;
- EX1=1;
- pinglv=15;
- while(1)
- while(a) //产生正弦波
- delay=pinglv; //获取周期数据
- P2=sin[k]; //数据数P2口进行波形转换
- k++;
- if(k==64) //一个周期取64点波数据
- k=0;
- while(delay) //延时处理
- delay--;
- while(b) //产生方波
- delay=pinglv;
- P2=juxing[k];
- k++;
- if(k==64)
- k=0;
- while(delay)
- delay--;
- while(c) //产生锯齿波
- delay=pinglv;
- P2=juchi[k];
- k++;
- if(k==64)
- k=0;
- while(delay)
- delay--;
- while(d) //产生三角波
- delay=pinglv;
- P2=sanjiao[k];
- k++;
- if(k==64)
- k=0;
- while(delay)
- delay--;
所有资料51hei附件下载:
资料.7z
(94.29 KB, 下载次数: 50)
