- #include "i2c_tts.h"
- #include "delay.h"
- #include <string.h>
- #define I2C_Speed 10000 //快速模式10k
- #define I2C1_TTS_SLAVE_ADDRESS7 0x80 //从机地址
- //XFS5152CE作为I2C接口的从设备,设备地址为: 0x80。
- //为保证通讯的稳定性,XFS5152CE的I2C接口通信速度要求不高于15KHZ。
- *函数名称:void I2C_TTS_GPIO_Configuration(void)
- *入口参数:无
- *出口参数:无
- *功能说明:配置使用的I/ O端口引脚
- void I2C_TTS_GPIO_Configuration(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7; //配置I2C1 PB6-SCL和PB7-SDA
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //管脚频率为50MHZ
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD; //模式为复用开漏输出,因此两个引脚要接上拉电阻
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- *函数名称:void I2C_TTS_Configuration(void)
- *入口参数:无
- *出口参数:无
- *功能说明:I2C Configuration
- void I2C_TTS_Configuration(void)
- I2C_InitTypeDef I2C_InitStructure;
- //定义I2C初始化结构体I2C_InitStructure
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE);
- I2C_InitStructure.I2C_Mode = I2C_Mode_I2C; //I2C模式
- I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_16_9;
- //占空比一定要选I2C_DutyCycle_16_9,不能选I2C_DutyCycle_2,因为TTS的速率不能超过15KHZ
- I2C_InitStructure.I2C_OwnAddress1 = I2C1_TTS_SLAVE_ADDRESS7; //TTS地址(0x80)使能应答
- I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
- I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit; //应答7位地址
- I2C_InitStructure.I2C_ClockSpeed = I2C_Speed;
- I2C_Init(I2C1, &I2C_InitStructure); //初始化I2C
- I2C_Cmd(I2C1, ENABLE); //使能I2C1
- *函数名称:void I2C_TTS_Init()
- *入口参数:无
- *出口参数:无
- *功能说明:初始化用于I2C TTS驱动的外设
- void I2C_TTS_Init()
- I2C_TTS_GPIO_Configuration();
- I2C_TTS_Configuration();
- *函数名称:void I2C_TTS_Write(u8 *pBuffer, u8 NumByteToWrite)
- *入口参数:pBuffer指向写入的数据缓冲区,NumByteToWrite写入TTS的字节数
- *出口参数:无
- *功能说明:写入多个字节的TTS。
- void I2C_TTS_Write(u8 *pBuffer, u8 NumByteToWrite)
- I2C_GenerateSTART(I2C1, ENABLE); //起始信号
- while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT)); // 测试和清除EV5
- I2C_Send7bitAddress(I2C1, I2C1_TTS_SLAVE_ADDRESS7, I2C_Direction_Transmitter); //发送写TTS地址
- while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)); // 测试和清除EV6
- while(NumByteToWrite--)
- I2C_SendData(I2C1, *pBuffer); //发送当前字节
- pBuffer++; //下一个被写入的字节
- while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED)); // 测试和清除EV8
- I2C_GenerateSTOP(I2C1, ENABLE); //停止信号
- * 名 称: XFS5051 文本合成语音函数
- * 功 能: 发送合成文本到XFS5051芯片进行合成播放
- * 入口参数: *pData:文本指针变量
- * 出口参数: 无
- * 说 明: 本函数用于文本合成语音。
- void TTS_SendFrameInfo(u8 *pData)
- /****************需要发送的文本**********************************/
- u8 Frame_Info[45];
- u8 dataLength = strlen((const char *)pData); //需要发送文本的长度
- /*****************帧固定配置信息**************************************/
- Frame_Info[0] = 0xFD ; //构造帧头FD
- Frame_Info[1] = 0x00 ; //构造数据区长度的高字节
- Frame_Info[2] = dataLength+2; //构造数据区长度的低字节
- Frame_Info[3] = 0x01 ; //构造命令字:合成播放命令
- Frame_Info[4] = 0x01; //文本编码格式:GBK
- /*******************发送帧信息***************************************/
- memcpy(&Frame_Info[5], pData, dataLength);
- I2C_TTS_Write(Frame_Info,5+dataLength); //发送帧配置
复制代码 |
