查看: 1655|回复: 1
sht20温湿度程序
ID:730024 发表于 2020-4-15 20:03 | 显示全部楼层 |阅读模式
//头文件
#include "iic.h"
#include "delay.h"
#include "sht20.h"
//宏
#define SHT20ADDR       0x80       //sht写地址
#define ACK             0                   //应答信号
#define NACK            1                  //非应答
#define FAIL            1                    //失败返回
#define READ_TEMP_COMD  0xf3        //读温度
#define READ_HUMI_COMD  0xf5        //读湿度
TempHumiValue_t temp_humi_Value;
static void SHT20_setResolution(void);
void SHT20_softReset(void);
//写一个字节函数
static u8 sht20_writeOneByte(u8 dataToWrite)
        u8 ack;
        IIC_sendByte(dataToWrite);
        ack = IIC_waitAck();
        return ack;
//复位
static void SHT20_softReset(void)
        IIC_start();
        SHT20_writeOneByte(SHT20ADDR&0xfe);
        SHT20_writeOneByte(0xfe);
        IIC_stop();
//初始化
void sht20_Init(void)
        sht20_softReset();
//读字节
static u8 sht20_readOneByte(u8 ack)
        u8 temp;
        temp=IIC_readByte(ack);
        return temp;
//写寄存器
static void sht20_setResolution(void)
          IIC_start();
         if(sht20_writeOneByte(sht20ADDR&0xfe)==ACK) //80
                 if(sht20_writeOneByte(0xe6)==ACK)
                             if(SHT20_writeOneByte(0x83)==ACK);
           IIC_stop();
//读取测量值
float SHT20_readTemOrHum(u8 commod)
        float temp;
        u8 ack=1;
        u8  MSB,LSB;
        float Humidity,Temperature;
        SHT20_setResolution();
        IIC_start();
        ack = SHT20_writeOneByte(SHT20ADDR&0xfe);
        if( ack == ACK )
                if(SHT20_writeOneByte(commod)==ACK)
                 do
                                delay_ms(6);
                                IIC_start();
                        }while(SHT20_writeOneByte(SHT20ADDR|0x01)==NACK);
                        MSB = SHT20_readOneByte(ACK);
                        LSB = SHT20_readOneByte(ACK);
                        SHT20_readOneByte(NACK);
                        IIC_stop();
                        LSB &= 0xfc; //1111 1100
                        temp = MSB*256 + LSB;
                        if (commod==((u8)READ_HUMI_COMD))
                                Humidity =(temp*125)/65536-6;
                                return Humidity;
                        else if(commod==((u8)READ_TEMP_COMD))
                                 /*-- calculate temperature [¡ãC] --*/
                                Temperature = (temp*175.72f)/65536-46.85f;
                                return Temperature;
  return FAIL;
TempHumiValue_t * SHT20_readTemAndHum(void)
        temp_humi_Value.humidity = SHT20_readTemOrHum(READ_HUMI_COMD);
        temp_humi_Value.temperature = SHT20_readTemOrHum(READ_TEMP_COMD);
        return &temp_humi_Value;
ID:1 发表于 2020-4-16 00:56 | 显示全部楼层
