舵机程序模块化,方便移植和使用
- #include<reg51.h>
- #include "servo.h"
- void main ( void ) //主函数
- InitialTimer();
- for(;;)
- ControlLeftOrRight();
- void Timer1 ( void ) interrupt 3 //定时器中断函数
- TH1 = ( 65535 - 500 ) / 256;
- TL1 = ( 65535 - 500 ) % 256;
- TimeOutCounter ++;
- switch ( LeftOrRight )
- case 0 : //为0时,舵机归位,脉宽1.5ms
- if( TimeOutCounter <= 3 )
- ControlPort = 1;
- else
- ControlPort = 0;
- break;
- case 1 : //为1时,舵机左转,脉宽1ms(理论值),实际可以调试得出
- if( TimeOutCounter <= 1 )
- ControlPort = 1;
- else
- ControlPort = 0;
- break;
- case 2 : //为2时,舵机右转,脉宽2ms(理论值),实际可以调试得出
- if( TimeOutCounter <= 6 )
- ControlPort = 1;
- else
- ControlPort = 0;
- break;
- default : break;
- if( TimeOutCounter == 80 ) //周期20ms(理论值),比较可靠,最好不要修改
- TimeOutCounter = 0;
Servo_Model.zip
(31.78 KB, 下载次数: 173)
