自己写的一个利用GSM模块上传数据到服务器,发送短信的程序
上传数据到服务器部分不会写主函数了,就是如何在main中调用void GPRSInit();void send_GPRSdata();这两部分- #include "reg52.h"
- #include "type.h"
- #include <string.h>
- #include <stdio.h>
- #define DEVID "" //设备id
- #define APIKEY "" //设备apikey
- bit flag;
- uchar model=0; //模式
- uchar temp1H=35; //上限值
- uchar temp2H=35; //上限值
- uchar temp3H=35; //上限值
- uchar hum1H=70; //上限值
- uchar hum2H=70; //上限值
- uchar hum3H=70; //上限值
- uchar temp_L=10;
- uchar date[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
- unsigned char temp1=0,temp2=0,temp3=0,hum1=0,hum2=0,hum3=0;
- #define SEND_MESSA_TO_YOUR "at+cmgs=\"1840**2397\"\r\n" //填入你手上的手机号码 不是板子的
- #include "LCD1602.H"
- sbit set=P1^6;
- sbit add=P3^5;
- sbit min=P3^4;
- sbit beep=P3^6;
- sbit led1=P1^2;
- sbit led2=P1^1;
- /***********模拟开关*********************/
- sbit CS_4052=P1^0;
- sbit B_4052=P1^1;
- sbit A_4052=P1^2;
- uchar fen=0; //定时发送短信计时
- bit sendFlag=0; //发送短信标志
- void delay1ms(unsigned int ms)//延时1毫秒(不够精确的)
- {unsigned int i,j;
- for(i=0;i<ms;i++)
- for(j=0;j<100;j++);
- void Uart_Send(uchar dat) //发送一字节
- SBUF=dat;
- while(!TI);
- TI=0;
- //发送一串字符到串口
- void Uart_Sends(char* data_at)
- unsigned char cnt=0;
- while(*(data_at+cnt)) //判断一串数据是否结束
- Uart_Send(*(data_at+cnt));
- cnt++;
- void select(uchar num)
- if(num==1) //上位机串口使能
- CS_4052=0;
- B_4052=0;
- A_4052=0;
- else if(num==2) //CC2530串口使能
- CS_4052=0;
- B_4052=0;
- A_4052=1;
- //发送短信函数
- void Send_SMS(void)
- uchar yy=1;
- select(1); //GSM模块串口使能
- delay1ms(100);
- Uart_Sends("AT+CMGF=1\r");//设置中文方式发送
- delay1ms(800);
- delay1ms(1000);
- Uart_Sends(SEND_MESSA_TO_YOUR);
- delay1ms(1000);
- switch (yy)
- case 1 : Uart_Sends("wendu1=");
- Uart_Send(temp1/10+0x30);
- Uart_Send(temp1%10+0x30);
- Uart_Sends(",wendu2=");
- Uart_Send(temp2/10+0x30);
- Uart_Send(temp2%10+0x30);
- Uart_Sends(",wendu3=");
- Uart_Send(temp3/10+0x30);
- Uart_Send(temp3%10+0x30);
- Uart_Sends("\r\nshidu1=");
- Uart_Send(hum1/10+0x30);
- Uart_Send(hum1%10+0x30);
- Uart_Sends(",shidu2=");
- Uart_Send(hum2/10+0x30);
- Uart_Send(hum2%10+0x30);
- Uart_Sends(",shidu3=");
- Uart_Send(hum3/10+0x30);
- Uart_Send(hum3%10+0x30);
- Uart_Sends("\r\n");
- if(temp1>temp1H)
- Uart_Sends("wendu1 Warning!!!\r\n");
- if(temp2>temp2H)
- Uart_Sends("wendu2 Warning!!!\r\n");
- if(temp3>temp3H)
- Uart_Sends("wendu3 Warning!!!\r\n");
- if(hum1>hum1H)
- Uart_Sends("hum1 Warning!!!\r\n");
- if(hum2>hum2H)
- Uart_Sends("hum2 Warning!!!\r\n");
- if(hum3>hum3H)
- Uart_Sends("hum3 Warning!!!\r\n");
- break; //烟雾报警
- Uart_Send(0x1a);//以0x1a来结束,表示内容结束,发送短信
- void GPRSInit()
- select(1); //打开GSM串口
- Uart_Sends("AT+CIPCLOSE=1\r\n");
- delay1ms(1000);
- Uart_Sends("AT+CGCLASS=\"B\"\r\n");
- delay1ms(1000);
- Uart_Sends("AT+CGDCONT=1,\"IP\",\"CMNET\"\r\n");
- delay1ms(1000);
- Uart_Sends("AT+CGATT=1\r\n");
- delay1ms(1000);
- Uart_Sends("AT+CIPCSGP=1,\"CMNET\"\r\n");
- delay1ms(1000);
- Uart_Sends("AT+CLPORT=\"TCP\",\"2000\"\r\n"); //发送指令指定本地端口
- delay1ms(1000);
- Uart_Sends("AT+CIPSTART=\"TCP\",\"183.230.40.33\",\"80\"\r\n");
- delay1ms(3000);
- void send_GPRSdata()
- char xdata text[28];
- char xdata buf1[60];
- select(1); //打开GPRS串口
- //ES=0; //关闭串口接收中断
- Uart_Sends("AT+CIPSEND\r\n");
- delay1ms(1000);
- memset(buf1, 0, sizeof(buf1));
- sprintf(buf1,"POST /devices/%s/datapoints?type=3 HTTP/1.1\r\n",DEVID);
- Uart_Sends(buf1);//向服务器发送数据
- delay1ms(1000);
- memset(buf1, 0, sizeof(buf1));//初始化
- sprintf(buf1,"api-key:%s\r\n",APIKEY);
- delay1ms(1000);
- Uart_Sends("Host:api.heclouds点com\r\n");
- delay1ms(1000);
- memset(text, 0, sizeof(text));
- strcpy(buf1, "{");
- sprintf(text, "\"Temperature1\":%d,",temp1);
- strcat(buf1, text);
- sprintf(text, "\"Humidity1\":%d,",hum1);
- sprintf(text, "\"Temperature2\":%d,",temp2);
- sprintf(text, "\"Humidity2\":%d,",hum2);
- sprintf(text, "\"Temperature3\":%d,",temp3);
- sprintf(text, "\"Humidity3\":%d",hum3);
- strcat(buf1, text);//字符串buf1尾加text的内容
- strcat(buf1, "}");
- sprintf(text,"Content-Length:%d\r\n",strlen(buf1));
- Uart_Sends(text);
- delay1ms(1000);
- delay1ms(1000);
- Uart_Sends(buf1);
- delay1ms(100);
- Uart_Send(0x1a);
- delay1ms(1000);
- void key()
- uchar i=0;
- if(!set) //检测设置按键
- while(!set);
- model++;
- if(model==7)
- model=0;
- if(model==1)//设置模式显示
- WRITE_LCD1602_COM(0x80);
- for(i=0;i<16;i++)
- WRITE_LCD1602_DAT(DIS_TAB3[i]);
- WRITE_LCD1602_COM(0x80+0x40);
- for(i=0;i<16;i++)
- WRITE_LCD1602_DAT(DIS_TAB4[i]);
- WRITE_LCD1602_COM(0x80+0x40+9);
- else if(model==0)//正常模式显示
- for(i=0;i<16;i++)
- WRITE_LCD1602_DAT(DIS_TAB1[i]);
- for(i=0;i<16;i++)
- WRITE_LCD1602_DAT(DIS_TAB2[i]);
- else if(!add)
- while(!add);
- switch(model)
- case 1: if(temp1H<90) temp1H++; break;
- case 2: if(temp2H<90) temp2H++; break;
- case 3: if(temp3H<90) temp3H++; break;
- case 4: if(hum1H<90) hum1H++; break;
- case 5: if(hum2H<90) hum2H++; break;
- case 6: if(hum3H<90) hum3H++; break;
- default:break;
- else if(!min)
- while(!min);
- switch(model)
- case 1: if(temp1H>0) temp1H--; break;
- case 2: if(temp2H>0) temp2H--; break;
- case 3: if(temp3H>0) temp3H--; break;
- case 4: if(hum1H>0) hum1H--; break;
- case 5: if(hum2H>0) hum2H--; break;
- case 6: if(hum3H>0) hum3H--; break;
- default:break;
- void beeps()
- static uchar count;
- count++;
- if(count<20)
- beep=0;
- else if(count<40)
- beep=1;
- else
- count=0;
- void control()//报警检测控制
- static uchar flagsend=0;
- if((temp1>temp1H)||(temp2>temp2H)||(temp3>temp3H)||
- (hum1>hum1H)||(hum2>hum2H)||(hum3>hum3H)) //温度控制
- beeps(); // 蜂鸣器报警
- if(flagsend==0)
- flagsend=1;
- Send_SMS();
- else
- flagsend=0;
- beep=1;// 关闭蜂鸣器报警
- void rec_cc2530data()
- select(2); //选通 cc2530 串口
- ES=1; //串口接收中断
- if(date[0]==0x55)
- date[0]=0;
- if((date[1]==1)&&(date[2]+date[3]==date[4])) //第一路 数据
- date[1]=0;
- temp1=date[2];
- hum1=date[3];
- if((date[1]==2)&&(date[2]+date[3]==date[4])) //第二路
- date[1]=0;
- temp2=date[2];
- hum2=date[3];
- if((date[1]==3)&&(date[2]+date[3]==date[4])) //第三路
- date[1]=0;
- temp3=date[2];
- hum3=date[3];
- void Timer0Init(void) //50毫秒@11.0592MHz
- TMOD &= 0xF0; //设置定时器模式
- TMOD |= 0x01; //设置定时器模式
- TL0 = 0x00; //设置定时初值
- TH0 = 0x4C; //设置定时初值
- TF0 = 0; //清除TF0标志
- TR0 = 1; //定时器0开始计时
- ET0=1;
- void main()
- init_1602();
- TMOD=0x20; // T1定时方式2
- SCON=0x40;//串行工作 方式1
- PCON=0x00; //不加倍
- TH1=TL1=0xfd; //定时器1赋初值 保证波特率9600
- TR1=1; //开定时器1
- REN=1; //允许串口接收
- ES=1; //打开串口中断
- EA=1; //开总中断
- Timer0Init();
- //GPRSInit();
- while(1)
- control(); //控制
- key(); //按键功能
- GPRSInit();
- send_GPRSdata();
- if(sendFlag==0)
- sendFlag=1; //代表已经发过一次,不在发了
- Send_SMS(); //发送短信
- rec_cc2530data();
- delay1ms(50);
- display();
- delay1ms(50);
- void serial()interrupt 4 //串口中断服务函数
- static uchar j;
- if(!RI);
- RI=0; //清楚接收完毕标志
- date[j]=SBUF;
- if(date[0]==0x55) //判断接收到的第一位为传感器所发数据
- j++;
- else
- j=0;
- if(j==5) //接收传感器所发数据字节
- j=0;
- void timer0() interrupt 1 //50ms
- static uchar count=0,miao=0;
- count++;
- if(count>20)
- count=0;
- miao++;
- if(miao>60)
- miao=0;
- fen++;
- if(fen>=1)
- fen=0;
- sendFlag=0;
