这是要仿真的程序,报错在定义体那里,不知道怎么修改。
#include<reg51.h>
#include "LCD1602.h" //液晶显示器LCD1602头文件
#include "DS1302.h" //时钟/日历芯片DS1302头文件
bit key_flag1=0,key_flag2=0;
SYSTEMTIME adjusted; // 此处为结构体定义
uchar sec_add=0,min_add=0,hou_add=0;
uchar day_add=0,mon_add=0,yea_add=0;
uchar data_alarm[7]={0};
int key_scan() // 函数功能:键盘扫描,判是否有键按下
int i=0;
uint temp;
P1=0xf0;
temp=P1;
if(temp!=0xf0)
{i=1;}
{i=0;}
return i;
uchar key_value() //函数功能:获取按下的按键值
uint m=0,n=0,temp;
uchar value;
uchar v[4][3]={'2','1','0','5','4','3','8','7','6','b','a','9'};
P1=0xfe;temp=P1; if(temp!=0xfe)m=0;
//采用分行、分列扫描的形式获取按键键值
P1=0xfd;temp=P1; if(temp!=0xfd)m=1;
P1=0xfb;temp=P1; if(temp!=0xfb)m=2;
P1=0xf7;temp=P1; if(temp!=0xf7)m=3;
P1=0xef;temp=P1; if(temp!=0xef)n=0;
P1=0xdf;temp=P1; if(temp!=0xdf)n=1;
P1=0xbf;temp=P1; if(temp!=0xbf)n=2;
value=v[m][n];
return value;
void adjust(void) //函数功能:修改各参量
if(key_scan()&&key_flag1)
switch(key_value())
case '0':sec_add++;break;
case '1':min_add++;break;
case '2':hou_add++;break;
case '3':day_add++;break;
case '4':mon_add++;break;
case '5':yea_add++;break;
default: break;
adjusted.Second+=sec_add;
adjusted.Minute+=min_add;
adjusted.Hour+=hou_add;
adjusted.Day+=day_add;
adjusted.Month+=mon_add;
adjusted.Year+=yea_add;
if(adjusted.Second>59)
adjusted.Second=adjusted.Second%60;
adjusted.Minute++;
if(adjusted.Minute>59)
adjusted.Minute=adjusted.Minute%60;
adjusted.Hour++;
if(adjusted.Hour>23)
adjusted.Hour=adjusted.Hour%24;
adjusted.Day++;
if(adjusted.Day>31)
adjusted.Day=adjusted.Day%31;
if(adjusted.Month>12)
adjusted.Month=adjusted.Month%12;
if(adjusted.Year>100)
adjusted.Year=adjusted.Year%100;
void changing(void) interrupt 0 using 0
//中断处理函数,修改参量,或修改确认
if(key_flag1)
key_flag1=0;
key_flag1=1;
main() //主函数
uint i;
uchar p1[]="D:",p2[]="T:";
SYSTEMTIME T;
EA=1;
EX0=1;
IT0=1;
EA=1;
EX1=1;
IT1=1;
init1602();
Initial_DS1302() ;
while(1){
write_com(0x80);
write_string(p1,2);
write_com(0xc0);
write_string(p2,2);
DS1302_GetTime(&T) ;
adjusted.Second=T.Second;
adjusted.Minute=T.Minute;
adjusted.Hour=T.Hour;
adjusted.Week=T.Week;
adjusted.Day=T.Day;
adjusted.Month=T.Month;
adjusted.Year=T.Year;
for(i=0;i<9;i++)
adjusted.DateString[i]=T.DateString[i];
adjusted.TimeString[i]=T.TimeString[i];
adjust();
DateToStr(&adjusted);
TimeToStr(&adjusted);
write_com(0x82);
write_string(adjusted.DateString,8);
write_com(0xc2);
write_string(adjusted.TimeString,8);
delay(10);
ds1302.h
#ifndef __DS1302_h__
#define __DS1302_h__
#define ulong unsigned long
//写指令宏定义地址
#define WRITE_SECOND 0x80//秒钟
#define WRITE_MINUTE 0x82//分钟
#define WRITE_HOUR 0x84//小时
#define WRITE_DATE 0x86//日
#define WRITE_MONTH 0x88//月
#define WRITE_WEEK 0x8a//星期
#define WRITE_YEAR 0x8c//年
//读指令宏定义地址
#define READ_SECOND 0x81//秒钟
#define READ_MINUTE 0x83//分钟
#define READ_HOUR 0x85//小时
#define READ_DATE 0x87//日
#define READ_MONTH 0x89//月
#define READ_WEEK 0x8b//星期
#define READ_YEAR 0x8d//年
//读写保护宏定义地址
#define WRITE_PROTECT 0x8E//写保护
uchar data tab[]={"0123456789"};
char *p;//定义一个指针处理星期字符串
//位寻址寄存器定义
sbit ACC_7 = ACC^7;
//管脚定义
sbit SCLK = P2^0; // DS1302时钟信号7脚
sbit DIO= P2^1; // DS1302数据信号6脚
sbit CE = P2^2; // DS1302片选5脚
uchar second,minute,hour;//时分秒
uint second_1,second_0,minute_1,miunte_0,hour_1,hour_0;
uchar week;//星期
uchar date,month,year;//年月日
uint date_1,date_0,month_1,month_0,year_1,year_0;
/**************************地址、数据发送子程序*************************/
void Write1302 ( unsigned char addr,dat )//写子程序
unsigned char i,temp;
CE=0; //CE引脚为低,数据传送中止
SCLK=0; //清零时钟总线
CE = 1; //CE引脚为高,逻辑控制有效
//发送地址
for ( i=8; i>0; i-- ) //循环8次移位
SCLK = 0;
temp = addr;
DIO = (bit)(temp&0x01); //每次传输低字节
addr >>= 1; //右移一位
SCLK = 1;
//发送数据
SCLK = 0;
temp = dat;
dat >>= 1;
SCLK = 1;
CE = 0;
/****************************数据读取子程序********************************/
unsigned char Read1302 ( unsigned char addr )//读子程序
unsigned char i,temp,dat1,dat2;
CE=0;
SCLK=0;
CE = 1;
//发送地址
SCLK = 0;
temp = addr;
addr >>= 1; //右移一位
SCLK = 1;
//读取数据
ACC_7=DIO;
SCLK = 1;
ACC>>=1;
SCLK = 0;
CE=0;
dat1=ACC;
dat2=dat1/16; //数据进制转换
dat1=dat1%16; //十六进制转十进制
dat1=dat1+dat2*10;
return (dat1);
/*******************************初始化DS1302***********************************/
void Initial(void)//上电初始化化模块2010年12月26号22点10分00秒星期日
Write1302 (WRITE_PROTECT,0X00); //禁止写保护
Write1302 (WRITE_SECOND,0x30); //秒位初始化
Write1302 (WRITE_MINUTE,0x59); //分钟初始化
Write1302 (WRITE_HOUR,0x23); //小时初始化,默认24小时制
Write1302 (WRITE_DATE,0x26); //日期初始化
Write1302 (WRITE_MONTH,0x12); //月初始化
Write1302 (WRITE_WEEK,0x07); //星期初始化,01-07
Write1302 (WRITE_YEAR,0x10); //年初始化00-99
Write1302 (WRITE_PROTECT,0x80); //允许写保护
/*******************************校时初始化*************************************/
/*void correct()//校时模块
Write1302 (WRITE_SECOND,0x00); //秒位初始化
Write1302 (WRITE_MINUTE,0x30); //分钟初始化
Write1302 (WRITE_HOUR,0x21); //小时初始化,默认24小时制
/*******************************星期转化程序***********************************/
void week_c()//星期转化
char *pp;//定义一个局部指针
switch(week)
case 1:pp="Mon 1";break;
case 2:pp="Tue 2";break;
case 3:pp="Wed 3";break;
case 4:pp="Tur 4";break;
case 5:pp="Fri 5";break;
case 6:pp="Sat 6";break;
case 7:pp="Sun 7";break;
default:pp="error";break;
p=pp;//函数地址赋值
/*******************************数据刷新DS1302*********************************/
void freshtime()//读取时间
second=Read1302 (READ_SECOND);//读取十进制数
minute=Read1302 (READ_MINUTE);
hour=Read1302 (READ_HOUR);
date=Read1302 (READ_DATE);
month=Read1302 (READ_MONTH);
week=Read1302 (READ_WEEK);
year=Read1302 (READ_YEAR);
second_1=second/10;//高位赋值
second_0=second-second_1*10;//低位赋值
minute_1=minute/10;
miunte_0=minute-minute_1*10;
hour_1=hour/10;
hour_0=hour-hour_1*10;
date_1=date/10;
date_0=date-date_1*10;
month_1=month/10;
month_0=month-month_1*10;
year_1=year/10;
year_0=year-year_1*10;
#endif
lcd1602.h
#ifndef LCD_CHAR_1602_2005_4_9
#define LCD_CHAR_1602_2005_4_9
sbit lcdrs = P2^0;
sbit lcdrw = P2^1;
sbit lcden = P2^2;
void delay (uint z) //延时函数,11.0592MHZ
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void write_com(uchar com) //写入命令数据到LCD
lcdrw =0;
lcdrs =0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_data(uchar date) //写入字符显示数据到LCD
lcdrw =0;
lcdrs =1;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init1602() //LCD1602初始化设定
lcdrw=0;
lcden=0;
write_com(0x3c);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
void write_string(uchar *pp,uint n) //采用指针的方法输入字符,n为字符数目
int i;
for(i=0;i<n;i++)
write_data(pp[i]);
void write_sfm(uchar add, uchar date) //向指定地址写入数据
uchar shi, ge;
shi = date / 10;
ge = date % 10;
write_com(0x80 + add);
write_data(0x30 + shi);
write_data(0x30 + ge);
#endif
