#include"lcd.h"
void Read_Busy() //忙检测函数,判断bit7是0,允许执行;1禁止
unsigned char sta; //
LCD1602_DB = 0xff;
LCD1602_RS = 0;
LCD1602_RW = 1;
do
LCD1602_EN = 1;
sta = LCD1602_DB;
LCD1602_EN = 0; //使能,用完就拉低,释放总线
}while(sta & 0x80);
void Lcd1602_Write_Cmd(unsigned char cmd) //写命令
Read_Busy();
LCD1602_RS = 0;
LCD1602_RW = 0;
LCD1602_DB = cmd;
LCD1602_EN = 1;
LCD1602_EN = 0;
void Lcd1602_Write_Data(unsigned char dat) //写数据
Read_Busy();
LCD1602_RS = 1;
LCD1602_RW = 0;
LCD1602_DB = dat;
LCD1602_EN = 1;
LCD1602_EN = 0;
void LcdSetCursor(unsigned char x,unsigned char y) //坐标显示
unsigned char addr;
if(y == 0)
addr = 0x00 + x;
addr = 0x40 + x;
Lcd1602_Write_Cmd(addr|0x80);
//*************************显示字符
void DisplayOneChar (uchar X,uchar Y,uchar DData)
if(Y) X|=0X40; //Y=1显示第二行,Y=0显示第一行
X|=0X80;
Lcd1602_Write_Cmd(X); //X用来选择哪一位
Lcd1602_Write_Data(DData); //DData用来写数据
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str) //显示字符串
LcdSetCursor(x,y); //当前字符的坐标
while(*str != '\0')
Lcd1602_Write_Data(*str++);
void InitLcd1602() //1602初始化
Lcd1602_Write_Cmd(0x38); //打开,5*8,8位数据
Lcd1602_Write_Cmd(0x0c);
Lcd1602_Write_Cmd(0x06);
Lcd1602_Write_Cmd(0x01); //清屏
详见:http://www.51hei.com/bbs/dpj-87250-1.html
