五路按键抢答器,
P3^2~P3^6为抢答人
P3~7为主持人复位
4位数码管显示抢答者序号和倒计时
- #include <reg52.h>
- /***************定 义 参 数***************/
- unsigned char xianshi=88,kaishi=0,daojishi=10,haoma=0,bitdisplay=0,k=0;
- unsigned int i,n=0, bittime=0;
- sbit d1=P3^2; //选手1
- sbit d2=P3^3; //选手2
- sbit d3=P3^4; //选手3
- sbit d4=P3^5; //选手4
- sbit d5=P3^6; //选手5
- sbit start=P3^7; //主持人
- sbit LED=P2^7;
- unsigned char Tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
- /***************延 时 计 数***************/
- void delay (unsigned int t) //t=1时,1ms
- unsigned int a,b;
- for(a=0;a<t;a++)
- for(b=0;b<120;b++);
- /***************中断函数***************/
- void timer0(void)interrupt 1 //5ms中断一次
- TH0 = (65536-5000)/256;
- TL0 = (65536-5000)%256;
- switch(bitdisplay)
- case 0:P1=0xFB;P0=Tab[xianshi/10];break;
- case 1:P1=0xF7;P0=Tab[xianshi%10];break;
- case 2:P1=0xFE;P0=Tab[haoma];break;
- case 3:P1=0xFD;P0=~0x40; break;
- bitdisplay++;
- bittime++;
- if(bitdisplay==4)
- bitdisplay=0;
- if(bittime==200) //5*200=1000ms
- bittime=0;
- xianshi--;
- if(xianshi==0) //如果倒计时结束则蜂鸣器与LED显示
- P1=0xff;
- LED=1;
- delay(1000);
- LED=0;
- TR0=0;
- void djtime() //倒计时间修改
- while(n)
- for(i=0;i<50;i++)
- P1=0xFB;P0=Tab[daojishi/10];
- delay(5);
- P1=0xF7;P0=Tab[daojishi%10];
- delay(5);
- if(d1==0)
- delay(33);
- if(d1==0)
- daojishi--;
- if(daojishi>20)
- daojishi=20;
- if(daojishi<5)
- daojishi=5;
- if(start==0)
- delay(33);
- if(start==0)
- n=0;
- LED=1;
- for(i=0;i<100;i++)
- delay(5);
- delay(5);
- P1=0xff;
- LED=0;
- /***************主 函 数***************/
- void main()
- TMOD=0X01;
- EA=1;
- ET0=1; //定时器中断
- TR0=0; //定时器 ,等待手动开启
- for(i=0;i<6;i++)
- LED=~LED;
- delay(500);
- LED=0;
- while(1)
- djtime();
- if(start==0)
- delay(33);
- if(start==0)
- k=1;
- haoma=0;
- xianshi=kaishi;
- TR0=1;
- while(k)
- while(xianshi)
- if(d1==0)
- delay(33);
- if(d1==0)
- haoma=1;
- break;
- if(d2==0)
- delay(33);
- if(d2==0)
- haoma=2;
- break;
- if(d3==0)
- delay(33);
- if(d3==0)
- haoma=3;
- break;
- if(d4==0)
- delay(33);
- if(d4==0)
- haoma=4;
- break;
- if(d5==0)
- delay(33);
- if(d5==0)
- haoma=5;
- break;
- xianshi=daojishi;
- LED=1;
- delay(400);
- LED=0;
- k=0;
以上程序51hei提供下载:
抢答器.docx
(14.97 KB, 下载次数: 7)
