本人有一个arduino控制max7219的程序
启动→行扫→竖扫→滚动播放文字→全亮→循环
程序是单个7219的,想改成级联,目前已经知道怎么更改显示的文字,求助大佬帮忙改一下或者指导一下应该改动哪里的参数,多谢,
- #include <avr/io.h>
- #include <util/delay.h>
- //-------------------宏定义-----------------------------------------
- #define SET_BIT(PORT,BIT) PORT|=(1<<BIT)
- #define CLR_BIT(PORT,BIT) PORT&=~(1<<BIT)
- #define BIT_IN(DDR,BIT) DDR&=~(1<<BIT)
- #define BIT_OUT(DDR,BIT) DDR|=(1<<BIT)
- #define READ_BIT(PIN,BIT) (PIN&(1<<BIT))
- /*********************** 定义MAX7219 端口信号 ************************/
- #define DATA 4
- #define LOAD 3
- #define CLK 2
- #define DATA_high digitalWrite(DATA,HIGH)
- #define DATA_low digitalWrite(DATA,LOW)
- #define LOAD_high digitalWrite(LOAD,HIGH)
- #define LOAD_low digitalWrite(LOAD,LOW)
- #define CLK_high digitalWrite(CLK,HIGH)
- #define CLK_low digitalWrite(CLK,LOW)
- /*********************** 定义MAX7219 内部寄存器 **********************/
- #define REG_DECODE 0x09 // 译码方式寄存器
- #define REG_INTENSITY 0x0a // 亮度寄存器
- #define REG_SCAN_LIMIT 0x0b // 扫描界限寄存器
- #define REG_SHUTDOWN 0x0c // 停机寄存器
- #define REG_DISPLAY_TEST 0x0f // 显示测试寄存器
- #define INTENSITY_MIN 0x00 // 最小显示亮度
- #define INTENSITY_MAX 0x0f // 最大显示亮度
- unsigned char logo[]={
- //阴码,逐列式,逆向
- 0x7F,0x08,0x08,0x08,0x7F,0x00,//"h",0//
- 0x01,0x01,0x7F,0x01,0x01,0x00,//"t",0//
- 0x7F,0x09,0x09,0x09,0x06,0x00,//"P",0//
- 0x6C,0x6C,0x00,//":",0//
- 0x30,0x0C,0x63,0x18,0x06,0x00,//"//",0//
- 0x20,0x40,0x41,0x3F,0x01,0x00,//"j",0//
- 0x01,0x02,0x7C,0x02,0x01,0x00,//"y",0//
- 0x08,0x08,0x08,0x08,0x08,0x00,//"-",0//
- 0x7F,0x02,0x0C,0x02,0x7F,0x00,//"m",0//
- 0x3E,0x41,0x41,0x41,0x22,0x00,//"c",0//
- 0x3F,0x40,0x40,0x40,0x3F,0x00,//"u",0//
- 0x60,0x60,0x00,//".",0//
- 0x7E,0x09,0x09,0x09,0x7E,0x00,//"a",0//
- 0x3E,0x41,0x41,0x41,0x3E,0x00,//"o",0//
- 0x7F,0x49,0x49,0x49,0x36,0x00,//"b",0//
- 0,0,0,0,0,0,0,0,
- /************************** 函数原型说明 *****************************/
- void Write (unsigned char, unsigned char);
- void SendByte (unsigned char);
- void Clear (void);
- * 函数原型:void Init()
- * 功 能: 对MAX7219进行初始化,调用任何其他函数之前必需先调用此函数
- void InitMAX7219(void)
- DATA_high;
- LOAD_high;
- CLK_high;
- Write(REG_SCAN_LIMIT, 7); // 扫描8位数字
- Write(REG_DECODE, 0); // 设置不译码方式
- Write(REG_SHUTDOWN,1); // 结束停机方式,正常工作
- Write(REG_DISPLAY_TEST, 0); // 结束显示测试,正常工作
- Write(REG_INTENSITY, 3); // 设置亮度
- Clear(); // 清零全部显示器
- * 函数原型:void Clear()
- * 功 能:关闭全部显示器
- void Clear (void)
- unsigned char i;
- for (i=1;i<=8;i++)
- Write(i, 0); // 关闭全部显示器
- * 函数原型:void Write (unsigned char reg_number, unsigned char dat)
- * 功 能:向指定的MAX7219内部寄存器写入数据
- * 参 数: reg_add = MAX7219内部寄存器地址
- dat = 待写入的数据
- void Write (unsigned char reg_add, unsigned char dat)
- LOAD_low; // 使LOAD变低,启动串行数据发送
- SendByte(reg_add); // 发送MAX7219内部寄存器地址
- if(reg_add>8)
- SendByte(dat); // 发送待写入的数据
- else
- SendByte((dat<<7)|(dat>>1)); //如发送的是显示数据,则根据硬件转换一下数据位
- LOAD_high; // 使LOAD变高,串行数据结束
- * 函数原型:static void SendByte (unsigned char dat)
- * 功 能:向MAX7219发送一个字节串行数据
- * 参 数:dat = 待发送的数据
- void SendByte (unsigned char dat)
- unsigned char i;
- for (i=0; i<8; i++)
- CLK_low; // 使CLK变低
- if(dat&0x80) // 发送一位数据"1"或"0"
- DATA_high;
- else
- DATA_low;
- dat<<=1;
- CLK_high; // 使CLK变高
- void io_init(void)
- DDRB|=(1<<DATA)|(1<<CLK)|(1<<LOAD);
- PORTB|=(1<<DATA)|(1<<CLK)|(1<<LOAD);
- pinMode(DATA,OUTPUT);
- pinMode(CLK,OUTPUT);
- pinMode(LOAD,OUTPUT);
- void setup(void)
- io_init();
- InitMAX7219();
- void loop(void)
- unsigned char i,j;
- while(1)
- for(i=0;i<8;i++) //逐行点亮
- for(j=1;j<9;j++)
- Write(j,1<<i);
- _delay_ms(200);
- for(i=1;i<9;i++) //逐列点亮
- for(j=1;j<9;j++)
- if(j==i)Write(j,0xff);
- else Write(j,0);
- _delay_ms(200);
- for(i=0;i<sizeof(logo)-8;i++)
- for(j=1;j<9;j++)
- Write(j,logo[j+i]);
- _delay_ms(200);
- for(i=1;i<9;i++)Write(i,0xff);
- _delay_ms(10000);
