查看: 2762|回复: 4
单片机4*4矩阵键盘扫描Proteus仿真程序(含松手检测消抖处理)
ID:964116 发表于 2021-9-9 15:50 | 显示全部楼层 |阅读模式
功能:
        扫描读取4*4矩阵键盘的输入,并显示在数码管上,扫描含消抖处理。包含C源码及Proteus仿真文件,包含原理图;
注:仅实现了0-15的显示,6根数码管显示的数相同。
  1. #include<reg52.h>
  2. #define uint unsigned int
  4. sbit wela = P2^7;          //位选端口
  5. sbit dula = P2^6;          //段选端口
  6. sbit beep = P2^3;          //蜂鸣器端口
  7. uchar temp, num;
  8. void keyscan();
  9. void delay(uchar num);
  10. void display(uchar num);
  11. void initialization();
  12. uchar code Table[] =                //数码管段码数组
  13. {
  14.     0x3F,0x06,0x5B,0x4F,0x66,0x6D,  //共阴极段码 0 1 2 3 4 5
  15.     0x7D,0x07,0x7F,0x6F,0x77,0x7C,  //共阴极段码 6 7 8 9 A b
  16.     0x39,0x5E,0x79,0x71,0x73,0x3E,  //共阴极段码 C d E F P U
  17.     0x31,0x6E,0x76,0x38,0x00        //共阴极段码 T y H L 灭灯
  18. };
  19. void main()
  20. {
  21.     initialization();
  22.     while (1)
  23.     {
  24.         beep = 0;
  25.         keyscan();
  26.     }
  27. }
  28. /************延时函数*************/
  29. void delay(uchar num)        //延时 num ms
  30. {
  31.     uint x, y;
  32.     for(x = num; x > 0; x--)
  33.     {
  34.         for(y = 110; y > 0; y--);
  35.     }
  36. }
  37. /****       键盘扫描函数        ****
  38. ****          函数功能        ****
  39. ****   扫描4*4矩阵键盘的输入    ****/
  40. void keyscan()
  41. {
  42.
  43.     P3 = 0xfe;      //检测第一行矩阵键盘(0-3)
  44.     temp = P3;
  45.     temp = temp & 0xf0;     //判断是否有按键按下
  46.     while(temp != 0xf0)
  47.     {
  48.         delay(5);
  49.         P3 = 0xfe;
  50.         temp = temp & 0xf0;
  51.         while(temp != 0xf0)    //延时消抖 确认有按键按下
  52.         {
  53.             temp = P3;
  54.             switch (temp)
  55.             {
  56.             case 0xee: num = 0;     //检测到第一个键按下
  57.                 break;
  58.             case 0xde: num = 1;     //检测到第二个键按下
  59.                 break;
  60.             case 0xbe: num = 2;     //检测到第三个键按下
  61.                 break;
  62.             case 0x7e: num = 3;     //检测到第四个键按下
  63.                 break;
  64.             }
  65.             while(temp != 0xf0)   //松手检测
  66.             {
  67.                 temp = P3;
  68.                 temp = temp & 0xf0;
  69.             }
  70.             display(num);
  71.         }
  72.     }
  73.     P3 = 0xfd;      //检测第二行矩阵键盘(4-7)
  74.     temp = P3;
  75.     temp = temp & 0xf0;     //判断是否有按键按下
  76.     while(temp != 0xf0)
  77.     {
  78.         delay(5);
  79.         P3 = 0xfd;
  80.         temp = temp & 0xf0;
  81.         while(temp != 0xf0)     //延时消抖 确认有按键按下
  82.         {
  83.             temp = P3;
  84.             switch (temp)
  85.             {
  86.             case 0xed: num = 4;     //检测到第一个键按下
  87.                 break;
  88.             case 0xdd: num = 5;     //检测到第二个键按下
  89.                 break;
  90.             case 0xbd: num = 6;     //检测到第三个键按下
  91.                 break;
  92.             case 0x7d: num = 7;     //检测到第四个键按下
  93.                 break;
  94.             }
  95.             while(temp != 0xf0)    //松手检测
  96.             {
  97.                 temp = P3;
  98.                 temp = temp & 0xf0;
  99.             }
  100.             display(num);
  101.         }
  102.     }
  103.     P3 = 0xfb;      //检测第三行矩阵键盘(8-11)
  104.     temp = P3;
  105.     temp = temp & 0xf0;     //判断是否有按键按下
  106.     while(temp != 0xf0)
  107.     {
  108.         delay(5);
  109.         P3 = 0xfb;
  110.         temp = temp & 0xf0;
  111.         while(temp != 0xf0)     //延时消抖 确认有按键按下
  112.         {
  113.             temp = P3;
  114.             switch (temp)
  115.             {
  116.             case 0xeb: num = 8;     //检测到第一个键按下
  117.                 break;
  118.             case 0xdb: num = 9;     //检测到第二个键按下
  119.                 break;
  120.             case 0xbb: num = 10;     //检测到第三个键按下
  121.                 break;
  122.             case 0x7b: num = 11;     //检测到第四个键按下
  123.                 break;
  124.             }
  125.             while(temp != 0xf0)   //松手检测
  126.             {
  127.                 temp = P3;
  128.                 temp = temp & 0xf0;
  129.             }
  130.             display(num);
  131.         }
  132.     }
  133.
  134.     P3 = 0xf7;      //检测第四行矩阵键盘(12-15)
  135.     temp = P3;
  136.     temp = temp & 0xf0;     //判断是否有按键按下
  137.     while(temp != 0xf0)
  138.     {
  139.         delay(5);
  140.         P3 = 0xf7;
  141.         temp = temp & 0xf0;
  142.         while(temp != 0xf0)     //延时消抖 确认有按键按下
  143.         {
  144.             temp = P3;
  145.             switch (temp)
  146.             {
  147.             case 0xe7: num = 12;     //检测到第一个键按下
  148.                 break;
  149.             case 0xd7: num = 13;     //检测到第二个键按下
  150.                 break;
  151.             case 0xb7: num = 14;     //检测到第三个键按下
  152.                 break;
  153.             case 0x77: num = 15;     //检测到第四个键按下
  154.                 break;
  155.             }
  156.             while(temp != 0xf0)   //松手检测
  157.             {
  158.                 temp = P3;
  159.                 temp = temp & 0xf0;
  160.             }
  161.             display(num);
  162.         }
  163.     }
  164. }
  165. void display(uchar num)      //数码管显示函数
  166. {
  167.     beep = 1;
  168.     dula = 1;
  169.     P0 = Table[num];
  170.     dula = 0;
  171. }
  172. void initialization()       //数码管初始化
  173. {
  174.     dula = 1;       //开段码锁存
  175.     P0 = 0x00;      //设数码管初值
  176.     dula = 0;
  177.     wela = 1;
  178.     P0 = 0xc0;      //选通6根数码管
  179.     wela = 0;
  180. }
所有资料51hei附件下载:
Key_scan.rar (29.94 KB, 下载次数: 43)
ID:928738 发表于 2022-1-14 17:26 | 显示全部楼层
temp = P3;
代码有问题,一直在赋值。试过了,没法判断按键是否按下。
ID:964116 发表于 2022-6-30 19:37 | 显示全部楼层
temp = P3;
temp = temp & 0xf0;     //判断是否有按键按 ...
这个稍等,我看看,过两天回复
ID:964116 发表于 2022-6-30 21:03 | 显示全部楼层
大一王 发表于 2022-6-30 19:37
这个稍等,我看看,过两天回复
验证过了,给的代码没问题,你把给的代码重新烧录进芯片。我打包的芯片里的是另一个。
ID:964116 发表于 2022-6-30 21:06 | 显示全部楼层
矩阵键盘上的数字与数码管有细微差别,改一下就可。
key_scan.rar
92.14 KB, 下载次数: 4, 下载积分: 黑币 -5
