可以模拟正弦波、方波、锯齿波和三角波四种波形。
- #include<reg52.h> //包含头文件
- #include<intrins.h>
- #define uchar unsigned char //宏定义
- #define uint unsigned int
- /**************定义按键的接口*************/
- sbit s1=P3^5; //KEY2 频率加
- sbit s2=P3^6; //KEY3 频率减
- sbit s3=P3^7; //KEY1 波形选择
- sbit s4=P3^4; //KEY4 步进值
- sbit led0=P3^0; //正弦波指示灯
- sbit led1=P3^1; //方波指示灯
- sbit led2=P3^2; //三角波指示灯
- sbit led3=P3^3; //锯齿波指示灯
- sbit lcdrs=P2^7;//液晶读数据引脚,还有一个控制脚是RW(读),因为我们只需要向液晶里写数据系那是就好了,所以,我们直接将RW引脚接地
- sbit lcden=P2^6;//使能端
- char num,boxing,u; //定义全局变量
- int pinlv=100,bujin=1,bujin1=1; //定义pinlv(频率)的初始值为10hz,可以根据实际情况修改 bujin表示增减频率按键按下一次的增减值 初始值为0.1
- uchar code table[]="0123456789"; //定义显示频率的数组
- uchar code table1[]="Fout= Wave form:"; //Fout后面显示频率值;Wave form后面显示模拟波形
- unsigned long int m;
- int a,b,h,num1; //a b为定时器初始值变量
- /************自定义字符 用于显示当前示波器显示波形的模拟波形 字符集可通过取模软件获取****************/
- uchar code zifu[]={
- 0x0e,0x11,0x11,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x11,0x11,0x0e,0x00, //正弦波0 1两行
- 0x00,0x07,0x04,0x04,0x04,0x04,0x1c,0x00,
- 0x00,0x1c,0x04,0x04,0x04,0x04,0x07,0x00, //矩形波2 3两行
- 0x00,0x01,0x02,0x04,0x08,0x10,0x00,0x00,
- 0x00,0x10,0x08,0x04,0x02,0x01,0x00,0x00, //三角波4 5两行
- 0x00,0x01,0x03,0x05,0x09,0x11,0x00,0x00, //锯齿波6一行
- uchar code sin[64]={
- 135,145,158,167,176,188,199,209,218,226,234,240,245,249,252,254,254,253,251,247,243,237,230,222,213,204,193,182,170,158,
- 146,133,121,108,96,84,72,61,50,41,32,24,17,11,7,3,1,0,0,2,5,9,14,20,28,36,45,55,66,78,90,102,114,128
- }; //正弦波取码,此数组内的数据为,da输出对应电压值对应的数字量,0是0V,255是5V
- uchar code juxing[64]={
- 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
- 255,255,255,255,255,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
- }; //矩形波取码 一个周期是采样64个点, 所以数组内是64个数据
- uchar code sanjiao[64]={
- 0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,144,152,160,168,176,184,192,200,208,216,224,232,240,248,
- 248,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0
- }; //三角波取码
- uchar code juchi[64]={
- 0,4,8,12,16,20,24,28,32,36,40,45,49,53,57,61,65,69,73,77,81,85,89,93,97,101,105,109,113,117,121,125,130,134,138,142,
- 146,150,154,158,162,166,170,174,178,182,186,190,194,198,202,206,210,215,219,223,227,231,235,239,243,247,251,255
- }; //锯齿波取码
- void delay(uint xms) //延时函数 具体延时时间根据传递的x变量决定
- int a,b;
- for(a=xms;a>0;a--)
- for(b=110;b>0;b--);
- /**********写入指令函数**********/
- void write_com(uchar com)
- lcdrs=0; //读端置0
- P0=com; //往P0口写入指令 即lcd地址
- delay(1); //延时
- lcden=1; //使能端从1变化到0 lcd执行一次读命令
- delay(1);//延时
- lcden=0; //使能端置0
- /***********写入数据函数*********/
- void write_date(uchar date)
- lcdrs=1;//读端口置为1
- P0=date; //数据送入P0口,写入LCD显示
- delay(1); //延时
- lcden=1; //同上
- delay(1);
- lcden=0;
- /************自定义字符集 LCD显示模拟波形**********/
- void Lcd_ram()
- uint i,j,k=0;
- uint temp=0x40;//temp为显示起始地址
- for(i=0;i<7;i++) //将字符集写入
- for(j=0;j<8;j++) //写入8个字节的字符 即zifu[]的一行数据
- write_com(temp+j);
- write_date(zifu[k]);
- k++;
- temp=temp+8; //下一个字符的起始地址
- /**********液晶初始化函数************/
- void init_lcd()
- uchar i;
- lcden=0; //默认开始状态为关使能端,见lcd液晶时序图
- Lcd_ram(); // 写入字符集
- write_com(0x0f); //
- write_com(0x38); //显示模式设置,默认为0x38,不用变。
- write_com(0x01); //显示清屏,将上次的内容清除,默认为0x01.
- write_com(0x0c); //显示功能设置0x0f为开显示,显示光标,光标闪烁;0x0c为开显示,不显光标,光标不闪
- write_com(0x06); //设置光标状态默认0x06,为读一个字符光标加1.
- write_com(0x80); //液晶的第一行首地址
- for(i=10;i<20;i++) //将table1的wave form:显示在第一行
- write_date(table1[i]);
- write_com(0x80+0x40); // 液晶第二行的起始地址
- for(i=0;i<9;i++) //显示初始化 从table1的第1个字符显示,将table1的Fout显示在第二行
- write_com(0x80+10); //初始为正弦波 在wave form后面显示模拟波形
- write_date(0);
- write_date(1);
- write_date(0);
- write_date(1);
- write_date(0);
- write_date(1);
- write_com(0x80+0x40+0x09); //设置初始频率为10hz
- write_date(' ');
- write_date('1');
- write_date('0');
- write_date('.');
- write_date('0');
- write_date('H');
- write_date('z');
- /**********定时器初始化**********/
- void initclock()
- TMOD=0x01; //定时器工作方式1
- TH0=a; //赋初值
- TL0=b;
- EA=1; //打开总中断
- ET0=1; //打开T0中断
- TR0=1; //启动定时器
- /**********显示函数(显示模拟波形和频率以及控制提示小灯)**********/
- void display()
- uchar qian,bai,shi,ge; //只是将频率分成千位,百位,十位,个位四位显示,实际并不是1000的格式
- qian=pinlv/1000; //将频率值拆成一位的数据,将数据除以1000,得到的商是一位数,赋值给qian
- bai=pinlv%1000/100; //将频率除以1000的余数再除以100就得到了频率的百位,赋值给bai
- shi=pinlv%1000%100/10; //得到频率的十位
- ge=pinlv%1000%100%10; //得到频率的个位
- write_com(0x80+0x40+0x09);//显示频率数字起始地址 第二行第九个位置
- if(qian==0) //千位为0
- write_date(' '); //显示空格
- else
- write_date(table[qian]);//查数组显示千位数字
- if(qian==0&&bai==0) //千位和百位都为0
- write_date(' '); //百位不显示
- else
- write_date(table[bai]); //显示百位数
- write_date(table[shi]); //显示十位数
- write_date('.'); //显示小数点
- write_date(table[ge]); //显示个位
- write_date('H');
- write_date('z');
- if(boxing==0) //正弦波
- write_com(0x80+10);//wave form:后面的地址 显示正弦波模拟波形
- write_date(0);
- write_date(1);
- write_date(0);
- write_date(1);
- write_date(0);
- write_date(1);
- led3=1;
- led0=0; //led0小灯亮 提示正弦波
- if(boxing==1) // 方波
- write_com(0x80+10); //显示方波模拟波形
- write_date(2);
- write_date(3);
- write_date(2);
- write_date(3);
- write_date(2);
- write_date(3);
- led0=1;
- led1=0; //led1小灯亮 提示方波
- if(boxing==2) //三角波
- write_com(0x80+10); //显示三角波模拟波形
- write_date(4);
- write_date(5);
- write_date(4);
- write_date(5);
- write_date(4);
- write_date(5);
- led1=1;
- led2=0; //led2小灯亮 提示三角波
- if(boxing==3) //锯齿波
- write_com(0x80+10); //显示锯齿波模拟波形
- write_date(6);
- write_date(6);
- write_date(6);
- write_date(6);
- write_date(6);
- write_date(6);
- led2=1;
- led3=0; //led小灯亮 提示锯齿波
- /*********键盘检测函数************/
- void keyscan()
- if(s1==0) //频率加按键
- EA=0; //关闭定时器总中断
- delay(2); //延时消除键盘抖动
- if(s1==0)
- while(!s1); //等待按键松开
- pinlv+=bujin; //根据步进值增加频率
- if(pinlv>1000) //频率值如果大于100 则重新赋值为100
- pinlv=100;
- display();
- m=65536-(150000/pinlv);/*频率值最小是10Hz,pinlv的值是100(因为要显示小数点后一位),150000/100=1500,这个1500就是定时器需要计时的,单位是us,65536-1500得到的是定时器的初值,
- 先不管初值,先看定时时间,1500us,一个波形的周期是由64个定时(前面四个波形数组)组成的,所以,一个波形周期就是64*1500us=96000,也就是96ms,约等
- 于100ms,也就是10Hz的频率*/
- a=m/256; //将定时器的初值赋值给变量
- b=m%256;
- EA=1; //开启总中断
- if(s2==0) //频率减按键
- delay(5); //延时消抖
- if(s2==0)
- EA=0;
- while(!s2);
- pinlv-=bujin; //根据步进值减频率
- if(pinlv<100)
- pinlv=1000;
- display();
- m=65536-(150000/pinlv); //同上
- a=m/256;
- b=m%256;
- EA=1;
- if(s3==0) //调换波形按键
- delay(5);
- if(s3==0)
- EA=0;
- while(!s3);
- boxing++;
- if(boxing>=4)
- boxing=0;
- display();
- EA=1;
- /*********步进值设置界面显示函数*********/
- void bujindisplay()
- uint bai,shi,ge; //将步进值分百位,十位,个位显示,但是并不是100的形式
- bai=bujin1/100; //将步进值除以100得到百位,也就是频率值的十位,因为有一个小数位
- shi=bujin1%100/10;//将步进值除以100的余数除以十得到十位
- ge=bujin1%100%10; //取余10后得到个位,也就是频率步进值的小数点后一位
- write_com(0x80+11);//选中液晶第一行第十一列
- if(bai==0) //百位是否为0
- write_date(' ');//百位不显示 空格
- else //百位不为0
- write_date(table[bai]); //显示百位数据
- write_date(table[shi]); //显示十位数据
- write_date(table[ge]); //显示个位,也就是小数点后一位
- /**********步进设置按键************/
- void bujinjiance()
- if(s4==0) //步进设置按键按下
- delay(5); //延时去抖
- if(s4==0) //再次判断按键
- while(!s4); //按键释放,按键松开才继续向下执行
- h++; //变量加
- if(h==1) //进入设置状态时
- write_com(0x01); //液晶清屏
- write_com(0x80); //初始化显示步进设置界面
- write_date('S');delay(1); //step value(步进值)
- write_date('t');delay(1);
- write_date('e');delay(1);
- write_date('p');delay(1);
- write_date(' ');delay(1);
- write_date('v');delay(1);
- write_date('a');delay(1);
- write_date('l');delay(1);
- write_date('u');delay(1);
- write_date(':');delay(1);
- bujin1=bujin; //步进值赋值给临时变量
- bujindisplay();//显示步进值
- if(h==2) //退出设置
- h=0;
- bujin=bujin1; //设置好的临时步进值赋值给步进变量
- init_lcd(); //初始化液晶显示
- initclock(); //定时器初始化
- display(); //调用显示程序
- if(h==1) //设置步进值时
- if(s1==0) //加按键按下(此时是加步进值不是加频率)
- delay(5); //延时去抖
- if(s1==0) //再次判断
- while(!s1); //按键释放
- bujin1++; //步进值加1
- if(bujin1>=101) //步进值最大100,也就是10.0Hz
- bujin1=1; //超过最大值就恢复到0.1Hz
- bujindisplay(); //步进值显示
- if(s2==0) //减按键(减步进值),注释与上面同理
- delay(5);
- if(s2==0)
- while(!s2);
- bujin1--;
- if(bujin1<=0)
- bujin1=100;
简易波形发生器.zip
(109.45 KB, 下载次数: 198)
