这是数码管的例程
LED[0]=1;
LED[1]=2;
LED[2]=3;
LED[3]=4;
主程序的这四句不太理解,也没有注释希望有大佬能解释一下
- #include <AT89X51.H>
- unsigned char code fseg[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
- unsigned char code segbit[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
- unsigned char disbuf[4]={0,0,0,0};
- // 函数原形定义
- #define uchar unsigned char
- void main (void); // 主函数
- void LED4_Display (void); // LED显示
- void LED_OUT(uchar X); // LED单字节串行移位函数
- unsigned char code LED_0F[]; // LED字模表
- sbit DIO = P1^0; //串行数据输入
- sbit RCLK = P1^1; //时钟脉冲信号——上升沿有效
- sbit SCLK = P1^2; //打入信号————上升沿有效
- // 全局变量
- uchar LED[8]; //用于LED的8位显示缓存
- // 主程序
- void main (void)
- LED[0]=1;
- LED[1]=2;
- LED[2]=3;
- LED[3]=4;
- while(1)
- LED4_Display ();
- unsigned char code *led_table; // 查表指针
- uchar i;
- //显示第1位
- led_table = LED_0F + LED[0];
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x01);
- RCLK = 0;
- RCLK = 1;
- //显示第2位
- led_table = LED_0F + LED[1];
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x02);
- RCLK = 0;
- RCLK = 1;
- //显示第3位
- led_table = LED_0F + LED[2];
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x04);
- RCLK = 0;
- RCLK = 1;
- //显示第4位
- led_table = LED_0F + LED[3];
- i = *led_table;
- LED_OUT(i);
- LED_OUT(0x08);
- RCLK = 0;
- RCLK = 1;
- uchar i;
- for(i=8;i>=1;i--)
- if (X&0x80) DIO=1; else DIO=0;
- X<<=1;
- SCLK = 0;
- SCLK = 1;
- unsigned char code LED_0F[] =
- {// 0 1 2 3 4 5 6 7 8 9 A b C d E F -
- 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x8C,0xBF,0xC6,0xA1,0x86,0xFF,0xbf
