查看: 1239|回复: 0
51单片机触摸开关控制9g舵机源程序
STC89C52RC型号的51单片机中触摸开关控制9g舵机,亲测可用,有疑问可以找我呦
制作出来的实物图如下:
   0.5ms--------------0度;
   1.0ms------------45度;
   1.5ms------------90度;
   2.0ms-----------135度;
   2.5ms-----------180度;
  1. #include<reg52.h>
  2. #define unchar unsigned char
  3. unsigned char count;      //0.5ms次数标识
  4. unsigned char jd=0;
  5. sbit pwm1 = P1^0;
  6. unsigned char flag=1;
  7. unsigned char flag1=1;
  8. sbit key1=P2^0;
  9. void Time0_Init()          //定时器初始化
  10. {
  11. TMOD = 0x01;           //定时器0工作在方式1
  12. TH0  =  (65535-500)/256;
  13. TL0  =  (65535-500)%256;    //12MZ晶振,0.5ms
  14. EA=1;            //总中断打开
  15. ET0=1;           //定时器中断打开
  16. TR0=1;           //定时器开关打开
  17. }
  18. void Time0_Int() interrupt 1
  19. {
  20.    static int t=0;
  21.    t++;
  22.   TH0  = (65535-500)/256;             //重新赋值
  23.    TL0  = (65535-500)%256;
  24.     if(count< jd)              //判断0.5ms次数是否小于角度标识
  25.      {
  26.           pwm1=1;                  //确实小于,PWM输出高电平
  27.      }
  28.     else
  29.       {
  30.           pwm1=0;                 //大于则输出低电平
  31.       }
  32.     count++;        //0.5ms次数加1
  33.      if(count>=40)
  34.      count=0;
  35.
  36.
  37. }
  38.    unsigned char count;      //0.5ms次数标识
  39. void keyscan()              //按键扫描
  40. {
  41.     if(key1==0&&flag1)
  42.         {
  43.
  44.            flag=!flag;
  45.            flag1=0;
  46.    }else if(key1) flag1=1;
  47.
  48. }
  49. void main()
  50. {
  51.
  52. count=0;
  53. Time0_Init();
  54. while(1)
  55. {
  56.         keyscan();
  57.         if(flag)
  58.                 {
  59.                   jd=4;
  60.
  61.                 }
  62.                 else
  63.                 jd=1;
  64. }
  65. }
hex文件下载(uv2版本的工程):
51单片机控制舵机.zip (3.9 MB, 下载次数: 20)
收藏收藏1 分享淘帖 顶 踩
