单片机源程序如下:- #include<reg51.h> //寄存器51的头文件
- #include<intrins.h>
- #define uint unsigned int
- #define uchar unsigned char
- unsigned char LED[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; //共阴极0-9字型码
- unsigned char hour=12,min,sec; //定义并初始化时间为12点整
- unsigned char shi=8,fen,miao; //定义并初始化闹钟为8点整
- unsigned char moshi; //0为闹钟模式,1为时钟模式
- sbit key1=P3^0; //按钮
- sbit key2=P3^1;
- sbit key3=P3^2; // 外部中断0输入
- sbit key4=P3^3; // 外部中断1输入
- sbit key5=P3^4;
- sbit s=P1^0; //蜂鸣器
- void keyscan();
- void delay(uint x) //定义延时函数:延时1ms
- unsigned char i,j;
- for(i=0;i<x;i++);
- for(j=0;j<120;j++);
- void display() //数码时钟管动态显示
- P2=0x7f;
- P0=LED[sec%10];
- delay(5);
- P2=0xbf;
- P0=LED[sec/10];
- delay(5);
- P2=0xdf; //显示“-”
- P0=0x40;
- delay(5);
- P2=0xef;
- P0=LED[min%10];
- delay(5);
- P2=0xf7;
- P0=LED[min/10];
- delay(5);
- P2=0xfb; //显示“-”
- P0=0x40;
- delay(5);
- P2=0xfd;
- P0=LED[hour%10];
- delay(5);
- P2=0xfe;
- P0=LED[hour/10];
- delay(5);
- void dishow() //数码管闹钟动态显示
- P2=0x7f;
- P0=LED[miao%10];
- delay(5);
- P2=0xbf;
- P0=LED[miao/10];
- delay(5);
- P2=0xdf; //显示“-”
- P0=0x40;
- delay(5);
- P2=0xef;
- P0=LED[fen%10];
- delay(5);
- P2=0xf7;
- P0=LED[fen/10];
- delay(5);
- P2=0xfb; //显示“-”
- P0=0x40;
- delay(5);
- P2=0xfd;
- P0=LED[shi%10];
- delay(5);
- P2=0xfe;
- P0=LED[shi/10];
- delay(5);
- void init_timer() //定时器初始化
- TMOD=0x01; //方式1
- TH0=0x77;
- TL0=0x01;
- EA=1; //总中断允许
- ET0=1; //定时器T0中断允许
- TR0=1; //启动定时器T0
- void Time1() //时间累加函数
- sec++; //秒钟:sec
- if(sec==60)
- sec=0;
- min++; //分钟:min
- if(min==60)
- min=0;
- hour++; //时钟:hour
- if(hour==24)
- hour=0;
- void Time0() interrupt 1 //定时器T0中断服务函数
- static unsigned int num;
- TMOD=0x01; //寄存器模式:方式1
- TH0=0x77;
- TL0=0x01;
- num++; //计数5ms,num+1
- if(num==300) //num=300,增加1秒
- sec++; //秒钟:sec
- num=0;
- if(sec==60)
- sec=0;
- min++; //分钟:min
- if(min==60)
- min=0;
- hour++; //时钟:hour
- if(hour==24)
- hour=0;
- void init_INT01() //外部中断初始化
- EA=1; //总中断允许
- EX0=1; //允许外部中断0中断
- EX1=1; //允许外部中断1中断
- IT0=1; //选择外部中断0为跳沿触发方式
- IT1=1; //选择外部中断1为跳沿触发方式
- void INT0_() interrupt 0 //外部中断0服务函数 :P3^2
- EX0=0;
- moshi=0; //闹钟打开,进入闹钟设置模式
- EX0=1;
- void INT1_() interrupt 2 //外部中断1服务函数 : P3^3
- EX1=0;
- moshi=1; //闹钟关闭 ,回归时钟状态
- EX1=1;
- void compare() //时间比较函数:判断时间是否达到闹钟设定时间
- if(shi==hour&&fen==min)
- s=0;
- delay(9);
- void keyscan() //按键判断
- static uchar key1_Temp=1;
- static uchar key2_Temp=1;
- static uchar key5_Temp=1;
- if(moshi==0)
- dishow();
- if(moshi==1)
- display();
- compare();
- if(moshi==1)
- if(key1==0&&key1!=key1_Temp) //key1:秒的加
- delay(10);
- sec++;
- if(sec==60)
- sec=0;
- if(key2==0&&key2!=key2_Temp) //key2:分的加
- delay(10);
- min++;
- if(min==60)
- min=0;
- if(key5==0&&key5!=key5_Temp) //key5:时的加
- delay(10);
- hour++;
- if(hour==24)
- hour=0;
- if(moshi==0)
- delay(10);
- miao++;
- if(miao==60)
- miao=0;
- delay(10);
- fen++;
- if(fen==60)
- fen=0;
- delay(10);
- shi++;
- if(shi==24)
- shi=0;
- key1_Temp=key1; //赋值
- key2_Temp=key2;
- key5_Temp=key5;
- void main()
- init_timer(); //定时器初始化
- init_INT01(); //外部中断初始化
- while(1)
- keyscan(); //按键判断
- Time1(); //时间累加函数
- delay(1);
