#include "stm32f10x.h"
#include "oled.h"
#include "sys.h"
#include "lnterface.h"
#include "bmp.h"
#include "24cxx.h"
#include "led.h"
#include "key.h"
#include "usmart.h"
#include "key4_4.h"
#include "usart.h"
unsigned int year=2019,month=8,day=8;//年月日
unsigned int nzs=12,nzf=22;//闹钟时 闹钟分
//unsigned int time=5,branch=8;
//unsigned int second=5,second2=5;//时分秒
unsigned int shi=11,fen=21,miao=50;//时分秒
unsigned int num=0;
unsigned int S;
u8 key=0;
unsigned int Choice=2;
int Bluetooth_Sign=1,WIFI_Sign=33,Flashlight_Sign=1,Electricity_Sign=4;
int Status_Bar_Sgin=0,Content_Column_Sgin=0;
int Key_Selectio=0;
int conu=0;
int Page_Sgin=0;
int count=0;
int Return_Sgin=0;
int Sgin=1;
int text_Buffer[]={00000000};
#define size sizeof(text_Buffer) //读取要写入芯片中的字节数。
void FMQ(void)
fmq=1;//叫
delay_ms(50);
fmq=0;//停
delay_ms(50);
void Timer2_Init_Config(void)
NVIC_InitTypeDef NVIC_InitStructure;
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); //使能Timer2时钟
TIM_TimeBaseStructure.TIM_Period = 9999; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值(计数到10为1ms) 9 1MS计数 99 10ms基计数
TIM_TimeBaseStructure.TIM_Prescaler = 7199; //设置用来作为TIMx时钟频率除数的预分频值(10KHz的计数频率)
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割:TDTS = TIM_CKD_DIV1
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn; //设置中断向量号
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //设置抢先优先级0
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //设置响应优先级0
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //使能NVIC
NVIC_Init(&NVIC_InitStructure);
TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE ); //使能TIM2指定的中断
TIM_Cmd(TIM2, ENABLE);
void TIM2_IRQHandler(void) //定时器2中断服务函数1S一次
if(TIM_GetITStatus(TIM2, TIM_IT_Update) == SET)
TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
miao++;
if(miao==60)
miao=0;
fen++;
if(fen==60)
fen=0;
shi++;
if(shi==24)
shi=0;
if(shi==nzs&&fen==nzf)
FMQ();
int main(void)
unsigned int datatemp[size];
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置NVIC中断分组2:2位抢占优先级,2位响应优先级
delay_init();
uart_init(115200);
IIC_Init();
OLED_Init();
LED_Init();
KEY_Init();
Timer2_Init_Config();
Key_Init();
Key_Test();
//AT24CXX_WriteLenByte(0,miao,size);
//S=AT24CXX_ReadLenByte(0,size);
//printf("%d",S);
WhenTheDisplay2();
//lnterface(); //菜单显示
//WhenTheDisplay();
OLED_P16x32Ch(1*16,2,1); //屏幕中间显示12:28
OLED_P16x32Ch(2*16,2,2);
OLED_P16x32Ch(3*16,2,10);
OLED_P16x32Ch(4*16,2,2);
OLED_P16x32Ch(5*16,2,8);
//OLED_P32x32Ch(1*32,2,0); //您
//OLED_P32x32Ch(2*32,2,1); //好
//OLED_P128x48Ch(0,2,0);//嗨占满屏幕
/* Status_Bar(); // 顶层图标显示
OLED_P8x16Str(1*16,2,"Tomorrow");//第一行
OLED_P8x16Str(1*16,4,"123"); //第二行
OLED_P8x16Str(1*16,6,"123"); //第三行
OLED_P16x16Ch(0*16,Choice,44); //选择箭头
OLED_P16x16Ch(1*16,2,65); //蓝
OLED_P16x16Ch(2*16,2,66); //牙
OLED_P8x16Str(1*16,4,"WIFI"); //WIFI
OLED_P16x16Ch(1*16,6,67); //温
OLED_P16x16Ch(2*16,6,68); //度
OLED_ShowNum(6*16,6,Choice/2,1,12); //右下角页数
OLED_P6x8Str(6.5*16,7,"/");
OLED_P6x8Str(7*16,7,"10");
