查看: 1257|回复: 0
STC单片机延时程序总结
ID:579397 发表于 2023-3-3 02:52 | 显示全部楼层 |阅读模式
                程序名称        :延时函数
//#define MAIN_Fosc 48000000L        //定义主时钟
//#define MAIN_Fosc 44236800L        //定义主时钟
//#define MAIN_Fosc 40000000L        //定义主时钟
//#define MAIN_Fosc 36864000L        //定义主时钟
//#define MAIN_Fosc 35000000L        //定义主时钟
//#define MAIN_Fosc 33177600L        //定义主时钟
//#define MAIN_Fosc 30000000L        //定义主时钟
//#define MAIN_Fosc 27000000L        //定义主时钟
//#define MAIN_Fosc 24000000L        //定义主时钟
//#define MAIN_Fosc 22118400L        //定义主时钟
//#define MAIN_Fosc 20000000L        //定义主时钟
//#define MAIN_Fosc 18432000L        //定义主时钟
#define MAIN_Fosc 12000000L        //定义主时钟
//#define MAIN_Fosc 11059200L        //定义主时钟
//#define MAIN_Fosc 6000000L        //定义主时钟
//#define MAIN_Fosc 5529600L        //定义主时钟
void Delay(unsigned int ms)                //注:ms_max=65536
                unsigned int i;
                do
                                i=MAIN_Fosc/96000L;                //STC89_12T
//                                i=MAIN_Fosc/48000L;                //STC89_6T
//                                i=MAIN_Fosc/14000;                //STC12
//                                i=MAIN_Fosc/13000;                //STC15
//                                i=MAIN_Fosc/10000;                //STC8
//                                i=MAIN_Fosc/6030;                        //STC32
                                while(--i)        ;
                        while(--ms);
