查看: 1870|回复: 1
洒家写的DS1302驱动
ID:80436 发表于 2015-5-21 23:42 | 显示全部楼层 |阅读模式
sbit rst=P2^0;
sbit io=P2^1;
sbit sclk=P2^2;
//--------常数宏-----------//
#define second_write 0x80
#define minute_write 0x82
#define hour_wirte   0x84
#define day_write    0x86
#define week_write   0x8A
#define month_write         0x88
#define year_write   0x8c
#define second_read 0x81
#define minute_read 0x83
#define hour_read   0x85
#define day_read    0x87
#define week_read   0x8b
#define month_read        0x89
#define year_read   0x8d
//--------------操作宏---------//
#define sclk_high sclk=1;
#define sclk_low  sclk=0;
#define io_high io=1;
#define io_low  io=0;
#define io_read io
#define rst_high rst=1;
#define rst_low   rst=0;
//--------保存时间数据结构体--------
struct
  unsigned int Second;
  unsigned int Minute;
  unsigned int Hour;
  unsigned int Day;
  unsigned int Week;
  unsigned int Month;
  unsigned int Year;
CurrentTime;
*Function static void ds1302write(unsigned Content)*
*unsigned content 要写的字节
static void ds1302_write(unsigned int Content)
unsigned int i=8;
for(;i>0;i--)
         if(Content&0x01)
          io_high
           io_low
          Content>>=1;
          sclk_high
          sclk_low
static unsigned ds1302_read(void)
unsigned int i,value;
  io_high
  for(i=8;i>0;i--)
   value>>=1;
   if(io_read)
     value|=0x80;
          value&=0x7f;
         sclk_high
         sclk_low
  return value;
* function :unsingned 1302writebyte(unsigned int addess)
Description:从DS1302指定的地址独处一个字节的内容
addess:数据地址
unsigned int 1302write_byte(unsigned int addess)
unsigned int readvalue;
        rst_low
        sclk_low;
        rst_high
ds1302_wirte(addess);
readvalue=1302_read();
rst_low
sclk_high
return readvalue;
*function void clock_init(void);
*Description:初始化1302时钟寄存器的值
  if(1302read_byte(0xc1)!=0xf0)
   1302write_byte(0x8e,0x00)//允许写操作
   1302write_byte(year_write,0x08);//年
   1302write_byte(week_write,0x04);//星期
   1302write_byte(month_write,0x12);//月
   1302write_byte(day_write,0x011);//日
   1302write_byte(hour_write,0x13);//时
   1302write_byte(minute_write,0x06);//分
   1302write_byte(second_write,0x04);//秒
   1302write_byte(0x90,0xa5);                 //充电
   1302write_byte(0xc0,0xf0);                 //判断是否初始化
   1302write_byte(0x8e,0x80);                 //禁止写操作
void clock_updata(void)
  CurrentTime.Second=1302read_byte(second_read);
  CurrentTime.Minute=1302read_byte(minute_read);
  CurrentTime.Hour=1302read_byte(hour_read);
  CurrentTime.Day=1302read_byte(day_read);
  CurrentTime.Month=1302read_byte(month_read);
  CurrentTime.Week=1302read_byte(week_read);
  CurrentTime.Year=1302read_byte(year_read);
ID:165792 发表于 2017-3-20 22:06 | 显示全部楼层
谢谢分享,不过看不懂。
