一下是一个ADC0832模数转换显示,特别是红色不能不明白啥意思,求高手讲解。
#include <reg51.h>
#include <intrins.h>
#define delay4us() {_nop_();_nop_();_nop_();_nop_();}
sbit RS = P2^0;
sbit RW = P2^1;
sbit E = P2^2;
sbit CS = P1^0;
sbit CLK = P1^1;
sbit DIO = P1^2;
uchar Display_Buffer[] = "0.00V";
uchar code Line1[] = "Current Voltage:";
void DelayMS(uint ms)
uchar i;
while(ms--)
for(i=0;i<120;i++);
bit LCD_Busy_Check()
bit result;
RS = 0;
RW = 1;
E = 1;
delay4us();
result = (bit)(P0&0x80);
E = 0;
return result;
void LCD_Write_Command(uchar cmd)
while(LCD_Busy_Check());
RS = 0;
RW = 0;
E = 0;
_nop_();
_nop_();
P0 = cmd;
delay4us();
E = 1;
delay4us();
E = 0;
void Set_Disp_Pos(uchar pos)
LCD_Write_Command(pos | 0x80);
void LCD_Write_Data(uchar dat)
RS = 1;
RW = 0;
E = 0;
P0 = dat;
delay4us();
E = 1;
delay4us();
E = 0;
void LCD_Initialise()
LCD_Write_Command(0x38); DelayMS(1);
LCD_Write_Command(0x0c); DelayMS(1);
LCD_Write_Command(0x06); DelayMS(1);
LCD_Write_Command(0x01); DelayMS(1);
uchar Get_AD_Result()
uchar i,dat1=0,dat2=0;
CS = 0;
CLK = 0;
DIO = 1; _nop_(); _nop_();
CLK = 1; _nop_(); _nop_();
CLK = 0;DIO = 1; _nop_(); _nop_();
CLK = 1;DIO = 1; _nop_(); _nop_();
for(i=0;i<8;i++)
CLK = 0; _nop_(); _nop_();
dat1 = dat1 << 1 | DIO;
for(i=0;i<8;i++)
dat2 = dat2 |((uchar)(DIO)<<i);
CS = 1;
return (dat1 == dat2) ? dat1:0;
uchar i;
uint d;
LCD_Initialise();
DelayMS(10);
d = Get_AD_Result()*500.0/255;
Display_Buffer[0]=d/100+'0';
Display_Buffer[2]=d/10%10+'0';
Display_Buffer[3]=d%10+'0';
Set_Disp_Pos(0x01);
i = 0;
while(Line1!='\0')
LCD_Write_Data(Line1[i+1]);
Set_Disp_Pos(0x46);
i = 0;
while(Display_Buffer!='\0')
LCD_Write_Data(Display_Buffer[i+1]);
