查看: 8321|回复: 1
求教:帮看看无线接收解码程序!
ID:2354 发表于 2008-6-9 16:28 | 显示全部楼层 |阅读模式
uint receive_deco(void) //解码
 uchar j,k1=0,k2=0;
 uint w_receive;
  for(j=16;j;j--)
   gas_led=1;
   while(!wireless_in)//如果接收引脚是低电平 则计时
    delay_50us(1);//计算有几个50us
    k1++;
    k2++;
   while(wireless_in))//如果接收引脚是高电平 则计时
    delay_50us(1);
    k2++;
   if((k2>30)&&(k2<=46)&&(k1<=(k2/3)))//1500us~2300us
    if((k1>6)&&(k1<=11))
    {//300~550us
     w_receive&=0xfffe;
            w_receive<<=1;
    if((k1>=24)&&(k1<36))
    {//1200~1800us
     w_receive|=0x0001;
            w_receive<<=1;
 return="return"  w_receive;
//接收头码、地址和数据
uint wireless_receive(void) //reentrant//使此函数可重入
{ //接收遥控码(解码程序)
 uint="uint"  re_data,i=0,j=0;
//检测50ms内有没有编码接收,因为发送完十六位数据需要1500*16=24ms 头码11ms 延时300us
    while(!wireless_in)
     delay_50us(1);
     i++;
 if((i>=180)&&(i<=260))
 {//如果有9--13毫秒左右的头码 则看延时时间
    while(wireless_in)
   delay_50us(1);
   j++;
  if((j>6)&&(j<=11))
  {//有300--550微秒左右的低电平延时
     re_data=receive_deco(); //解码
   return re_data;
   re_data=0x0000;
  re_data=0x0000;
 return re_data;
ID:34 发表于 2008-6-28 23:54 | 显示全部楼层
有问题??
