查看: 4188|回复: 6
求助:PT2259电子音量IC寻不到地址。有玩过的大神指导下(附程序)
ID:129964 发表于 2016-7-18 22:34 | 显示全部楼层 |阅读模式
89c52外挂24c02跟一个PT2259;
程序就发送一个地址码,接收ACK信号,并把接收到的ACK信号用液晶显示出来;
发送 0x50 24c02有应答信号;
但我按PT2259资料写的四个地址:0x88;0x89;0x8D;0x8C  都测试一边都没有收到应答信号!
这是什么回事啊?是不是24C02跟PT2259的寻址方式不同?
程序:
LCD1206.C
#include <reg52.h>
#define LCD1602_DB  P0
sbit LCD1602_RS = P1^2;
sbit LCD1602_RW = P1^1;
sbit LCD1602_E  = P1^0;
/* 等待液晶准备好 */
void LcdWaitReady()
    unsigned char sta;
    LCD1602_DB = 0xFF;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do {
        LCD1602_E = 1;
        sta = LCD1602_DB; //读取状态字
        LCD1602_E = 0;
    } while (sta & 0x80); //bit7等于1表示液晶正忙,重复检测直到其等于0为止
/* 向LCD1602液晶写入一字节命令,cmd-待写入命令值 */
void LcdWriteCmd(unsigned char cmd)
    LcdWaitReady();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
/* 向LCD1602液晶写入一字节数据,dat-待写入数据值 */
void LcdWriteDat(unsigned char dat)
    LcdWaitReady();
    LCD1602_RS = 1;
    LCD1602_RW = 0;
    LCD1602_DB = dat;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
/* 设置显示RAM起始地址,亦即光标位置,(x,y)-对应屏幕上的字符坐标 */
void LcdSetCursor(unsigned char x, unsigned char y)
    unsigned char addr;
    if (y == 0)  //由输入的屏幕坐标计算显示RAM的地址
        addr = 0x00 + x;  //第一行字符地址从0x00起始
        addr = 0x40 + x;  //第二行字符地址从0x40起始
    LcdWriteCmd(addr | 0x80);  //设置RAM地址
/* 在液晶上显示字符串,(x,y)-对应屏幕上的起始坐标,str-字符串指针 */
void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str)
    LcdSetCursor(x, y);   //设置起始地址
    while (*str != '\0')  //连续写入字符串数据,直到检测到结束符
        LcdWriteDat(*str++);
/* 初始化1602液晶 */
void InitLcd1602()
    LcdWriteCmd(0x38);  //16*2显示,5*7点阵,8位数据接口
    LcdWriteCmd(0x0C);  //显示器开,光标关闭
    LcdWriteCmd(0x06);  //文字不动,地址自动+1
    LcdWriteCmd(0x01);  //清屏
main.c
#include <reg52.h>
#include <intrins.h>
#define I2CDelay()  {_nop_();_nop_();_nop_();_nop_();}
sbit I2C_SCL = P3^6;
sbit I2C_SDA = P3^7;
extern void InitLcd1602();
extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
bit I2CAddresing(unsigned char addr);
        bit ack = 0;
        unsigned char str[10];
    InitLcd1602();   //初始化液晶
        ack = I2CAddresing(0x88);
        str[0] = '5';
        str[1] = '0';
        str[2] = ':';
        str[3] = (unsigned char)ack + '0';
        str[4] = '\0';
        LcdShowStr(0, 0, str);
        ack = I2CAddresing(0x89);
        str[0] = '6';
        str[1] = '2';
        str[2] = ':';
        str[4] = '\0';
        LcdShowStr(8, 0, str);
    while (1);
void I2CStart()
        I2C_SDA = 1;
        I2C_SCL = 1;
        I2CDelay();
        I2C_SDA = 0;
        I2CDelay();
        I2C_SCL = 0;
void I2CStop()
        I2C_SCL = 0;
        I2C_SDA = 0;
        I2CDelay();
        I2C_SCL = 1;
        I2CDelay();
        I2C_SDA = 1;
        I2CDelay();
bit I2CWrite(unsigned char dat)
        bit ack = 0;
        unsigned char mask;
        for(mask=0x80; mask!=0; mask>>=1)
                if((mask&dat) == 0)
                        I2C_SDA = 0;
                        I2C_SDA = 1;
                I2CDelay();
                I2C_SCL = 1;
                I2CDelay();
                I2C_SCL = 0;
        I2C_SDA = 1;
        I2CDelay();
        I2C_SCL = 1;
        ack = I2C_SDA;
        I2CDelay();
        I2C_SCL = 0;
        return ack;
        bit ack = 0;
        I2CStart();
        ack = I2CWrite(addr << 1);
        I2CStop();
        return ack;
ID:74784 发表于 2016-12-19 16:27 | 显示全部楼层
建议楼主用pga2311吧
ID:129964 发表于 2016-7-18 23:51 | 显示全部楼层
快来人救命啊!!!
ID:129964 发表于 2016-7-19 08:02 | 显示全部楼层
PT2257跟PT2259是不是不同的两种东西啊?
那个更好?我看很多人都是在用2257的。
ID:134182 发表于 2016-7-19 08:57 | 显示全部楼层
不懂,但顶一个,楼主加油
ID:129964 发表于 2016-7-19 16:10 | 显示全部楼层
huayangshiboqi 发表于 2016-7-19 08:57
不懂,但顶一个,楼主加油
嗯嗯 谢谢哈~
ID:211349 发表于 2017-11-24 21:38 | 显示全部楼层
楼主解决了吗?毕业设计得用这个芯片,想参考一下
